Question about Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher
Dishwasher will not power up
My home power went out and now the dishwasher will not turn on. I checked the power and there is power to the plug were I plug the dishwasher in?
  • Anonymous Mar 23, 2014
    there is live power to the dishwasher and the plug is securely plugged in but it won't turn on
Clean light button flashing dishwasher will not start new load
Posted on Aug 10, 2009
  • 56 Answers
Never Use Dishwasher Use Sink
Posted on Aug 07, 2009
6ya staff
SOURCE:
LG LDS5811BB power cord is good, however the dishwasher is not getting any power. No lights no nothing.
There is a fuse on power unit, that should be tested first, check also a different outlet.
Aug 09, 2008 | LG Dishwashers
Error 21h
possible cause dishwasher is set on time delay clear the code by holding down the start button for 5 seconds.If this does not wok turn off at power source and pull plug out for 5 minutes.Re-fit plug and switch power back on hopes this helps let me know how you went.
Apr 19, 2011 | Miele Dishwashers
How to install new door spring on portable dishwasher
Things You'll Need:
  • Owner's manual
  • Screwdriver
  • Replacement spring (optional)
  1. Turn off the power to your Kenmore dishwasher before attempting any repairs. If you have a portable Kenmore dishwasher, you can just unplug the power cord from the wall. Built-in dishwashers are hard-wired into the cabinet, so you will have to turn off the breaker switch at the home's circuit breaker box to cut the power.
  2. 2 Remove the screws that hold the kickplate onto the lower front of the Kenmore dishwasher. Take the kickplate off to access the door springs.
  3. Check the door springs to make sure they have not come loose from the door support or the adjustment holes on the dishwasher. Re-attach any ends that have slipped off their connections.
  4. Replace the springs if they are connected at both ends but still do not have enough tension to support the weight of the door. Once a Kenmore dishwasher door spring is stretched out, it cannot be restored to its original condition. Unhook one end of the old spring from the adjustment hole. Unhook the other end from the door support and discard the spring. Insert one end of the replacement spring into the adjustment hole and the other end into the hook on the door support.
  5. Open and close the door a few times to make sure the spring is now working properly. The door should not bounce up and down or sag on the hinges when it is in the open position.
  6. Restore power to your Kenmore dishwasher by plugging it back in or turning on the switch at the home's circuit breaker panel.
Dec 21, 2010 | Maytag Dishwashers
Our dishwasher doesn't turn on--no power. I have
There is sometimes a switch mext to the disposall that switches the dishwasher on & off. if no luck revers the 2 plugs just to see if it will come on if not then check that the plug is hooked up under the front of the dishwasher behind the cover at the bottem.
Sep 12, 2009 | KitchenAid Dishwashers
Will not turn on
check the following to address this issue.
1. No power to the dishwasher
Make sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced.
2. Door switch
Replace if defective.
3. Timer
Replace if defective (note: uncommon problem).
4. Selector switch
Jun 19, 2009 | LG 24 in. LDS 5811ST Stainless Steel...
Power went out and when cut back on the dishwasher is beeping
Did you check the breaker that controls this device.....and there may be a rest on the unit...also turn of the breaker and turn it back on as well unplugging the the DW and plugging it back in.
Hope this helps...The Fang
Mar 27, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
Dishwasher not starting when door closes
What your saying is suggesting a water supply issue. The Model number you've given can not be found on the Neff website.
You will need to disconnect power, turn the water supply off (under sink or behind dishwasher), disconnect the water line, put the end of the hose in a bucket or cup, turn water back on slowly and make sure water flows. Turn back off. If water flows -
Then check that there is not a restriction in the water solenoid valve. If you know how to use a multimeter, check the water valve solenoid for continuity.
Plug the unit back in, and initiate a wash cycle, and watch for voltage applied to the water solenoid valve. If you get voltage, you should hear the valve open.
Power the unit off, connect the water line, and repower the unit. Check again if water does or doesnt flow.
Let me know what you find.
Jan 25, 2009 | Neff 24 in. S5456 Built-in Dishwasher
Dishwasher stopped working..!!..!! please help
Hi crystal245,
I'm Harvey the Master Plumber.
Your problem is: GE Nautilus Dishwasher suddenly stopped working. NOTHING!! it was fine one day then went kaput the next. I checked the plug in and the circuit breaker but still NOTHING
I run into this often. Ends up being loose, broken or burnt ellectrical connection in d/w junction box most of the time. It's under the d/w behind the kick plate on the right or center. Turn the power off first and remove the wire nuts. Replace wire nuts and/or repair wire ends as nessessary. Beyond that you're looking at a bad control board or failed connection in the unit.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 09, 2008 | Dishwashers
My Dishwasher has no power.
have you check at the junction box behind the front bottom panel?? is the breaker ok?/ most newer homes have a switch above the counter to kill the power is that on ?? check that and let me know
Mar 15, 2008 | Bosch 24 in. SHX46A05 Stainless Steel...
Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher Logo
570 people viewed this question
Top Kenmore Dishwashers Experts
Ron Rak
Ron Rak
Marvin
Marvin
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
