Color calibration is performed automatically with power on. Anyway, you can start it manually as described on the user manual here:
https://www.manualslib.com/manual/761008/Kyocera-Ecosys-P6030cdn.html?page=193#manual
If nothing helps, there should be mechanical problem with the positioning of the imaging drums.
SOURCE: MP 160 IS PRINTING ONLY BLACK AND PINK COLLORS
Maintenance your cartridge with head clean or deep clean. If you don't get full colour, then change the colour cartridge.
SOURCE: how do i print envelopes on a kyocera ecosys FS-1300d
Just a suggestion but in the application you are using, make sure the "Page Setup" is set to the envelope you need and the source for the envelope is correct.
Also, check the driver settings to make sure they match what the application needs.
Don
SOURCE: What location on the kyocera
Pull the multipurpose tray open in the front of the printer. There you will find adjustable side guides
to align the envelop as it feeds into the printer
