Question about Water Water Heaters
I have a R85 and the control does not light up, I have checked the breaker and the fuses in the hot water heater
Posted by Sam Haginas on
ray gallant
    Top Expert:
  • Water Master
  • 68,648 Answers
WE HAVE NO IDEA WHAT AN R 85 IS WHO MADE IT CALL YOUR LOCAL PLUMBING REPAIR SERVICE
Posted on May 02, 2020
5 Related Answers
Anonymous
  • 68 Answers
SOURCE: Kenmore Electric Water Heater/ Economizer 6
it usaly takes a few hours to heat up depending on water size check our breaker to see if it tripped out make sure all your wire connections are good u could take the front plate off and hit reset if you dont get hot water in a few hours ull probibly have to replace the trermostats and maby the elements its not hard to do good luck
Posted on Mar 07, 2009
gizmonix
  • 13 Answers
SOURCE: My Rinnai R85 heater will not heat; it is leaking
I just fixed a leaky R85. Fortunately it's the bypass valve, not the heat exchanger. Did your heater freeze up in this snow storm? Unplug the power, open the cover and see where it leaks. If water comes from the top, means crack on the heat exchanger, then it would be too costly to replace. If you can see the water gushing out of a valve, on the bottom of the heater, then it's an easy fix. The valve is fixable, you don't have to replace it. But still need to find out what causes the flame fail (error 12). I suspect the igniter got wet, dry it with a towel after you take out the valve. Removing the fan first will give you more room to work inside.
Posted on Feb 12, 2010
Anonymous
SOURCE: I have a GE hot water heater, SE40M12AA01, dual
1) You posted under Rheem-GE electric water heater.
If upper element is burned out, then water heater will not heat any water.
http://waterheatertimer.org/How-it-works.html
2) Replace upper element:
http://waterheatertimer.org/How-to-replace-water-heater-element.html
3) Open following link for complete troubleshoot:
This troubleshoot assumes you have standard thermostats and elements.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
4) Manuals and links. I do not see 'smart lights' in the manual.
http://products.geappliances.com/ApplProducts/html/GEAResults.htm#Category=Standard_Water_Heaters
Troubleshooting starts page 15.
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=AP12168-7%20%28GE%20Elec%29.pdf
5) Add a comment with your experience so other with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Mar 26, 2011
mizrach612
SOLOMON
  • 102 Answers
SOURCE: have a reliance electric water heater model 606; have no hot water. I am having a problem finding the reset switch.
If it was working and recently stopped working, the heating element that heats the water probably went bad, no longer functioning. Check to make sure that there is or is not a reset button, and if there is, press and reset the heater. It's not difficult to remove the old heater element and replace it, but make sure the circuit breaker power to the water heater is off when you remove it. Take it to a water heating supply store, or large hardware store with the Brand and model number of your water heater (Reliance RELIANCE ELECTRIC WATER HEATER,model 606 ) to buy another one.
Posted on Sep 21, 2012
Gene Haynes
  • 5391 Answers
SOURCE: Rheem 50 gallon Electric Water Heater 81V52D C repair ideas needed
It could be element shorted to ground through steel tank, so don't touch tank when breaker is ON.
Or you have undersized 12 gauge wire and 20 amp breaker and the heat has loosened breaker on the busbar. Breaker trips when heat exceeds breaker limit. Jiggle breaker and listen for crackling sound.
To restore hot water now:
Turn off circuit breaker, and open top cover then Push in reset button on top of heater to restore functionality. Put back insulation and factory cover.
To fix water heater: test and replace bad element.
http://waterheatertimer.org/How-to-test-water-heater-element.html
If problems continue
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#trip-breaker
http://waterheatertimer.org/Troubleshoot-household-electricity.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Posted on Sep 25, 2012
I have a Rinnai R85 water heater and my temperature controller doesn't have any power.
You will only get power out of the controller when there is a call for hot water. If you have power into the controller, and you still get no power out when there is a demand, then the controller is bad and must be replaced.
Feb 27, 2018 | Rinnai Water Heaters
Richmond hot water heater
Turn off the power at the fuse box (circuit Breaker Box) relative to the Water Heater. Allow for a few minutes rest and flip the breaker back on again. Go to the Heater and check it again. If it works ok, you good to go. If the same problem exists, then the controller board to the heater is either defective or the limiting switch has been compromised. Before getting a professional to test it, contact Richmond directly and see if they have a fix.
Feb 04, 2018 | Water Heaters
Rinnai R85 starts to warm then stops and blinks 61??
I went to the Rinnai website and this is what I found for error code 61.
Error Code 61 Problem: Fan failure
Solution: Measure the resistance on the fan motor, check the damaged or loose wiring and connections. Make sure that the fan spins freely.
Sounds like either your fan is broken or something is keeping it from spinning freely.
Hope this helps.
Gary
Feb 24, 2015 | Rinnai R85ePLUS Tankless Water Heater
I just put in 2 new breakers in mybreaker box mystove works but not my hot water heater. Imay havegotten my breakers mixed up does a hot water heater take a 15 or 30 size breaker????
They both take a 30Amp breaker or fuse as they are fed off of the 220V. They both have demands above 20Amps when they are fully used. in particular the hot water heater has a fast recovery mode in which both cal rods are heating at the same time.
Feb 12, 2011 | Water Heaters
No hot water. Circuit breaker not the problem. Which plate do I open to check the eco?
Remove access panels on water heater's side the top thermostat has a red reset button on it.
Press reset button and it will take about 30 mins or more to get hot water. If you have a meter or test light check wires to elements for power.
This would be the first thing to check on the water heater.
May 21, 2010 | Rheem 30 GAL ELEC SHORT Water Heater 6YR...
My Rinnai R85 heater will not heat; it is leaking water. I installed the unit 24-26 months ago, and had no problem until today. The automatic starter will engage but the flame (pilot) will not ignite. The...
Feb 09, 2010 | Rinnai Digital Remote Water Heater Control...
My hot water isnt working and i need to know if the pilots go off on an electric water heater like gas if so how do i re lite the water heater
  1. if your hot water heater is electric there is no open flame or pilot light. They have electric heating coils,normally they are 220 volts.Follow the metal conduit up and back to the box check the breakers there will be two of them in for the hot water heater if it is 220 there will be only one fuse/breaker if it is 110. Check to see that they are on.
Dec 23, 2009 | Rheem Water Heaters
Hot water isnt getting hot
Check your fuses or circuit breaker, then check the reset button located behind the top side door.
Oct 09, 2009 | RELIANCE ELECTRIC WATER HEATER
My r85 rinnai water heater vibrates significantly and makes
Sounds like there is something loose in the line.Like cut off valve,check valve.
Mar 09, 2009 | Rinnai Digital Remote Water Heater Control...
Water Heaters Logo
137 people viewed this question
Top Water Heaters Experts
Don Walper
Level 1 Expert
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Water Heater Expert? Answer questions, earn points and help others
