Question about Danby Refrigerators
How do I know if the thermostat needs to be replaced on my Danby Mini fridge I just got? The thermostat comes on and then shuts right back off. The Model # is; DAR0266A1BDD-3
Posted by Christina Kautzman on
5 Related Answers
Anonymous
SOURCE: need to replace thermostat in
just bought new refrigerator
Posted on Jul 16, 2008
kfinlay1969
  • 30 Answers
SOURCE: wiring diagram for danby thermostat freezer
Doesn't matter thermostat is just a switch operated by temperature.
Posted on Jul 11, 2009
Richie_asg1
Richard Perkins
  • 1036 Answers
SOURCE: danby mini fridge model dcr054w
This is a problem with the 'Motor Run Capacitor'
What you suggest is exactly what happens when this part fails.
Unplug - and look carefully around the connections to the compressor - there should be a cylinder with 2 connections on it. Read what value it says (like 250V 50pf) - and order a replacement from a parts store.
Fit it any way round - it doesnt matter.
plug back in and should work 100%
Cost about - $5
Posted on Dec 27, 2010
raj somaiya
  • 5370 Answers
SOURCE: I wish to replace the
Its fitted by screws and clips are holding it.This clips are to be un-clipped and screws needs to be removed.Also a thin knife will help to loosen the thermostat housing.This is the thermostat,which you have to remove:--- helpmech_28.jpg
------------------ Also click this link directly,to check more images of the part :--- http://www.espares.co.uk/part/fridges-and-freezers/whirlpool/art472/3-(856447215010)/p/1084/278/0/709510/208951/whirlpool-service-w4-frid.html ------------- This should help. Thanks.Helpmech.
Posted on Dec 29, 2010
oldTech2332
Gene Meier
  • 2341 Answers
SOURCE: is 6 or 1 the
1 is the warmest setting
6 is the coldest
Posted on Sep 04, 2011
Danby Silhouette frig freezing everything regardless of thermostat setting.
It's the thermostat that's failed.
You'll need to buy a replacement unit, then fit it into the fridge.
If you can do this yourself, by all means get on with it.
If you can't do this yourself, you'll need to pay an engineer to do this for you,
or let everything freeze.?
best of luck
Mar 14, 2018 | Danby Refrigerators
I can't get a regular temperature in my old brown Danby Inglis frig . It is freezing every item in the frig even at the lowest ajustement. Can you help me?
Most likely temperature control thermostat needs replacing. Also check damper between fridge and freezer. If mechanical, adjust where less air is going in fridge section. If not mechanical, but electric, damper door may not be closing.
Sep 23, 2017 | Danby Refrigerators
What is the red push button for in the middle of the temperature control on danby mini fridge
If you go here
https://www.danby.com/support/#product-manuals
select compact fridges, and then your model, you can read the user manual for it.
Oct 01, 2016 | Danby Refrigerators
Haier HSW02C runs ALL the time
Yes your thermostat is shorted. It's just not shutting the unit off ever. A thermostat is something you can touch as a user, so no it's not that hard to get to for replacement. Also have the unit unplugged while learning how to repair your appliance.
Apr 27, 2013 | Haier Refrigerators
I have a danby dcr412 fridge the compressor comes on but it doesnt get cold
you may have a gas leak or you need to get new gas in it or it could be the thermostat. prety much if the compressor is running but it doesnt get cold these are the two most obvious things to check. hope that helps, let me know how you go.
Feb 04, 2011 | Danby (DAR604BLS) Refrigerator
Danby compact 482 fridge is freezing everything. thermostat switch seems to check out.
Hello tbrown7777
Welcome.
You said, Your Danby compact 482 fridge is freezing everything. thermostat switch seems to check out.
Just 482 is incomplete!!!!!!!!!
Can you send me the complete model number off the sticker in the fridge or on the rear of the fridge?
and the year of it! waiting your response!
Huuum
Oct 20, 2008 | Danby Refrigerators
Temperature control
I have a danby mini fridge and freezer and noticed the same problem. The temperature dial has NO NUMBERS ON IT! it just has a strip that goes from light to dark blue. That's it. I looked in the manual and it doesn't say anywhere which way is colder...it makes sense that the darker the blue the colder the temperature but why keep us guessing?
Mar 15, 2008 | Danby 3.6 cu. ft. / 102 liter Chest...
Pressed a button, now fridge won't work
you have pressed the defrost button that is why the compressor stops and would not come back on. there could be a temperature sensor on the thermostat or a timer where in it would only reset back after the temperature of the fridge warms up. try to remove all the food and let is sit for a while, plugged and watch if the compressor would kick in after about two hours or untill the fridge warms up. if the button is stuck, you may have to spray lubricant in the thermostat or replace the thermostat .
Feb 21, 2008 | Danby DCR34 Compact Refrigerator
Refrigerators Logo
61 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Marvin
Marvin
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
