Question about Samsung Dishwashers
My Samsung dishwasher is only 2 months old but am having trouble with it. The cutlery shelf isn’t washing. No idea why as the rest of it seems to be ok (although not brilliant). Not sure if i’m Doing something wrong. Any ideas? Thank you
Curt Mueller
    Dedicated:
    Visited the website for 20 consecutive days.
  • 154 Answers
Are you choosing the right cycles? Are you using generic detergent? Make sure both spinners move freely every time you go to start.
Posted on May 02, 2019
Roger
    Habit-Forming:
    New Friend:
  • 45 Answers
I assume it's still under warranty, I would take it back
Hello can you help? Miele G 665 SC Not washing too tray and cutlery tray. The rest seems fine. Any pointers much appreciated.
check the jets and tips of the spray bars to see if there is food debris stuck in them.
Jun 07, 2013 | Dishwashers
I have a whirlpool Du810SWRQ0 dishwasher. Whwn we wash the dishes, it is ok until the drying process start. Then it has smoke from inside. So, we can not use heat dry anymore.
smoke from inside the dishwasher or the panel?
if smoke is from inside the dishwasher... firstly check that the element is clean? is there any evidence of melting on your lower basket shelf or cutlery basket? if so the thermostat or rhe heating element control may be faulty and will require repair. If its an old dishwasher, sometimes its just easier to bite the bullet and buy a new one.
Dec 17, 2010 | Whirlpool 24 in. DU810CWD Built-in...
Dishwasher not cleaning/rinsing properly
try connect a water filter (carbon and particle), and connect the machine on output filter, mormaly resolve this problem. Some old houses has water supplie problems, as dirty water, and contamined problems, check for water purity.
Jan 14, 2010 | Dishwashers
I have an kenmore elite "ultra wash" model 665. not sure the rest.. about 7/8 years old, making loud buzzing sound during wash cycles,starts about 5 minutes into the normal wash cycle. i removed the inlet...
I have the same problem as those who stated their dishes are not getting clean. If you listen to the wash cycle you should hear water sloshing around inside. If you hear just a humming sound the washer has no water. I have this problem. I had a tech come and he told me the water is syphoning out my drain and I need to change my plumbing, then he charged me $65. I have lived in this house for ten years. 6 with the washer that came with house and 4 with this Kenmore Elite. This problem started about 6 months ago. So what I have been doing is opening the door, after the humming starts and the sloshing stops, and adding about 2 L of water. It seems to wash just fine after that.
Jan 12, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
After it fills and starts to wash my dishwasher
Reseat the little rubber gasket along the door. Pull it out a little bit
Aug 16, 2009 | Whirlpool DU930PWS Built-in Dishwasher
My dishwasher won't close - and there's nothing in the way to block it. It doesn't seem to be the catch either!
there are 2 reasons for this if someone has fallen onto the door and bent it down too far it will not close,also try removing top and bottom baskets alternately, see if that helps could be cutlery shelf too far forward
Aug 06, 2009 | Dishwashers
In built dishwasher, Electrolux ESI6220, is not heating the water and therefor not washing the cutlery properly. What may be the problem and how does one remidy same?
You have to test the heating element with an ohm-meter. It should read very low ohms. If the element seems ok, you have to test the controller to see if it is powering the element (probably should be 120 volts)
May 05, 2009 | Electrolux Dishwashers
My indesit DI620 isnt rinsing the contents properly
its the same water that rinses both sections just different arms, the one directly under the top basket usually cleans both cutlery and top basket. it could be a posibility that the arm itself is contaminated with waste that is too large to push through the holes and is now breaking up making a mess on teh glasses. (I have seen it before with melon seeds) remove the arm and rinse backward under a tap.
make sure that the salts are topped up as well this is very important if the salts run out you will not regenerate the resin beads which are used for water purification on the last rinse so this could also rinse with dirty water.
Nov 21, 2008 | Indesit 24 in. IDL500 Built-In Dishwasher
Cutlery going rusty
2 solutions here. Firstly your cutlery is of poor quality - sorry!! Or try using more rinse aid, but I suspect the quality of the cutlery
Oct 24, 2008 | Belling 24 in. IDW603 Built-in Dishwasher
Dishwashers Logo
52 people viewed this question
Top Samsung Dishwashers Experts
Marvin
Marvin
Are you a Samsung Dishwasher Expert? Answer questions, earn points and help others
