Question about Watches
Smart bracelet manual - Watches
Posted by Carol Stowe on
I need instructions for setting up a z18 smart bracelet
search google online Shop. I think you can get it
Feb 17, 2018 | Watches
Hi there, I bought through Amazon VeryVit (smart band). It was delivered to me 3 days ago.
go back on amazon and find your order history and find the seller of the product on that page and contact them, of you could contact amazons customer support
Jun 20, 2017 | The Watches
How to set up PBTW155-ASST1 proscan smart bracelet
don't know how to start using it
Jan 19, 2015 | Watches
How do I connect to kogan Bluetooth vibrating bracelet
I had the same problem myself
Go to this:
http://media.kogan.com/files/usermanuals/KABRCBTXXXA-A.pdf
it's the user manual for the bracelet and it has the steps in there
when it says to "hold down button two until 'pairing...' appears" just keep holding button two down (it might take 30+ seconds)
Dec 20, 2012 | Watches
I need to buy new bracelet
mcdevito75 here, BEST BET for your Ebel watch, look for a small watch repair shop in your area, to order a new bracelet.
Jul 13, 2010 | Ebel Type E Stainless Steel Rubber Strap...
Cannot open bracelet on Bulova 11606355 watch
Try taking your watch to a local watch shop.
If there is something wrong with it, you can only tell by handling it. Alternatively if there is a special way to do it they will probably know it.
Apr 24, 2010 | Bulova Watch
How to adjust expandable bracelet pleaseI would like to remove links to make it smaller.
If you are ready to take that risk, here is how you can do that.
First- get watch on your wrist and by squeezing the bracelet count how many links you have to take out to make it tight enough (say 4 for example).
Check the sides of a bracelet. You will notice that the upper band metal is flipped over the bracelet side. Take tweezers or small pliers and unbend one of these. Try to do as little damage as possible.
When it's done, you will see two metal staples inserted into the bracelet. You have to pull them out. While pulling out, remember how they where positioned, as you will need to drive them back in the same manner.
So, when the staples are out, do the same on the other side of bracelet. Now you have bracelet in two halves.
Count off 4 links and undo the staples in joint of 4th and 5th link in the same manner as previously.
When links are out, take the staples and drive them back into the bracelet joining two ends together. You have to do that exactly the same way and position as you took them out.
When all staples are in place, bend the metal back over the bracelet sides.
BE WARNED: as you gonna do it first time, be ready that you can damage the bracelet or can not put it back together.
Good luck.
Jul 29, 2009 | Casio Watches
Self-adjustable bracelet watch
Check the sides of a bracelet. You will notice that the upper bands metal is flipped over the bracelets side. Take tweezers or small pliers and unbend one of these. Try to do as little damage as possible.
When links are out, take the staples and drive them back into the bracelet koining two ends together. You have to do that exactly the same way and position as you took them out.
When all staples are in place, bend the metal back over to the bracelet sides.
Good luck.
Rate me, please.
Mar 19, 2009 | Timex 2J611 Watch
I have a bracelet link bracelet expansion bracelet watch I need to remove some links
Good luck
Dec 21, 2008 | Timex 2J611 Watch
Watches Logo
109 people viewed this question
Top Watches Experts
Janelle Schoonover
Janelle Schoonover
Bruce Robin
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
