Question about Refrigerators
How to defrost drive mechanism in the freezer where the ice tray sits. It will not turn at all
Posted by Carolyn Damon on
David Biebinger
    New Friend:
  • 26 Answers
Or you have a bad freezer door seal ,the ice shoot door that is letting warm air inside of your freezer n causing it to ice up or your water spout that pours water into your ice maker is leaking, but I seem to run more into the door seal I'd bad
Posted on May 02, 2019
Testimonial: "I did it! I fixed it!! Thanks for your responses"
  • David Biebinger
    David Biebinger May 02, 2019
  • David Biebinger
Jude24
    Master:
  • 313 Answers
Need a little more info, but it should have a removable container that hold the ice. That comes out. If it is too jammed up with ice to move it, you will have to carefully chip away at some of it, or let it thaw. Once you are able, take the container out and empty it completely dry it out. If that doesn't do it, there is a problem with the mechanism.
Posted on May 01, 2019
5 Related Answers
Anonymous
  • 245 Answers
SOURCE: Freezer compartment ice build-up
too defrost just open the doors for a day with the unit unplugged. as far as why it is frosting up check door seals make sure they are all good and seal it up well and that should take care of it.
Posted on Jun 26, 2009
woodchuck789
Charles T Nevin
  • 4070 Answers
SOURCE: Icemaker won't fill tray,
Was the inlet tube frozen. If so your water inlet valve on the back where the water supply comes in is probably leaking and when the water reaches the freezer it freezes, blocking the inlet tube. Replace the water inlet valve.
You can Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Posted on Aug 29, 2009
woodchuck789
Charles T Nevin
  • 4070 Answers
SOURCE: Samsung RS253BAVQ freezer Keeps defrosting, and wont dump ice
One posibility is that it is not defrosting a all and that the ice is building up on the evaporator coil behind the rear cover inside the freezer. This condition will block the flow of cold air. Remove the back panel to see what your have. Either no ice , light frost, partial icing or heavy icing blocking the fins. Complete light frosting is normal.
Posted on Sep 09, 2009
woodchuck789
Charles T Nevin
  • 4070 Answers
SOURCE: My Kenmore refrigerator coldspot #70192001 is not
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
If you need help finding your model number see here> http://www.appliancepartspros.com/modelnumber_locator.aspx
To locate your timer, motherboard, control or adaptive defrost control , enter your model number and search for the part or post back on Fixya.
http://www.searspartsdirect.com/partsdirect/index.action?psid=26129238&sid=PSx20071217x00001a
Posted on Oct 01, 2009
aasc
Mike Smith
  • 1606 Answers
SOURCE: DSS25KSRD SS GE Adora refrigerator- ice in tray
It sounds like the # 4 thermistor is bad . You will have to remove the lower inside rear freezer panel ( 2 or 4 screws ) and on the top of the coils , you will see a 1 " long torpedo looking piece , clipped on , with 2 white wires going to it . Part number WR55X10025 . This thermistor , tells the maon control board , the temperature of the freezer coils ( evaporator ) and when to defrost and when to stop defrosting and turn the compressor back on . There is also a defrost thermostat which cuts the heater off to keep from over heating , but I do not believe this is part of your problem . You should also replace the # 5 thermistor , located behind the oval grill , mounted on the lower right side of the freezer . This thermistor , tells the main control board , the temperature of the freezer section .
Posted on Oct 21, 2009
Machine will not stop making ice...solution?
The mechanism that senses when the ice tray is full is not working. Different ice-makers have different sensing mechanisms. I think yours has a thermistor (a temperature sensing device) near the top of the tray to sense when cold ice reaches it. The thermistor could be faulty or for some reason not contacting the ice. The best solution is to remove the ice-maker, let all of the ice melt and water evaporate at room temperature, inspect, and re-install. If you are not comfortable with that, completely defrost your freezer (you will probably have to have your refrigerator off and the freezer door open for a few hours). Ice-makers of all types can get bits of frozen water (ice) in places where it fouls things up, so a thorough defrosting can cure many different problems.
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_f6ca18ca1db028ed
Feb 24, 2016 | Kenmore 51lb. Clear Ice Maker
Electrolux american fridge freezer cooling problem
There is a defrost timer on the unit. It is supposed to come on and melt the ice that forms on the coils in the evaporator. IF you get a lot of ice built up or something is wrong with the timer, it wont melt the ice or it wont come back on to cool the unit.
Dec 09, 2013 | Electrolux Refrigerators
Fghb2844lf3 no ice
Is it not making ice in ice maker at top in the fridge or ice maker below in the freezer? If fridge try using a hot air hair dryer for about five minutes to defrost the freezing tray mechanism.
Nov 13, 2013 | Frigidaire Refrigerators
GE ESS25XGMB Ice tray dispenser not turning.
In the future you can use a steamer to defrost that drain line takes 5 minutes. I don't think your bucket is sitting correctly check and make sure it has contact with the auger motor and is not sitting too high. If you hear the motor turning but the coil is not its not seated correctly. Also it will not move if the door is open.
Jul 25, 2013 | Refrigerators
Water doesn't fill the ice maker trays
Most ice makers need to be at 8 to 13 degrees to make ice. If you had to defrost coil, then it's a defrost issue. Could be timer, bi-metal our heater.
Aug 17, 2012 | Refrigerators
I have a Daewoo FRN U20DA type american fridge freezer. The Ice maker has sropped working. There is no water getting into it. There is water getting through to the water dispenser in the front door. the...
The water filter should be changed every six months, not two years.
The water lines may still be frozen even though you turned the unit off, but most likely you are not getting water flow due to a clogged filter. Change it.
Feb 26, 2011 | Daewoo Freezers
Kenmore 52552100 Side by Side ice in bottom of freezer
I had the same problem. And after some research I went at it yesterday. I unplugged the refrigerator and removed the bottom two racks in the freezer. The tray at the bottom of the defrost assembly was caked with ice. I didn't know where the drain plug was. I started melting the ice using a hair dryer. I also carefully broke up the ice using a knife. After the ice was removed I could locate the drain hole. I used a copper wire shaped like an "L" and tried chipping away at it with no luck. I then poured a 1/3 of a cup of very hot water in the tray and let it sit. After a few minutes I used the hair drier again and soaked up the water with a paper towel. I added another 1/3 cup of hot water. I noticed the ice in the drain hole was beginning to melt and used the wire again. Finally, I got my compressed air gun and blew out the hole. I wanted to just blow the water out of there but it must have shot the ice out into the evaporator tray. I poured more hot water in the tray and it disappeared immediately into the evaporator tray (checked the tray and could see water). I then blew out the hole with compressed air and dried the area with the hair drier. Plugged in the refrigerator, replaced the baskets and was done. Whole thing took 30-45 minutes. No idea why it clogged up in the first place but if it happens again I should be able to cut 10 minutes off the time.
Feb 01, 2010 | Kenmore Refrigerators
Freezer leaks water even with ice maker water turned off
The only water that can come out of the freezer if the water is turned off is defrosted ice that cannot go to the tray at the bottom of the machine since the drain hole is blocked. See if any water is in the tray under the machine. Probably dry as a bone. If so carefully remove the back panel in the freezer, after you have defrosted some of the ice buildup. If you find lots of Ice the defrost circuit isn't working. If you find frosty ice the circuit may be OK but the drain blocked. You MUST melt ALL ice on the coils, and in the drain pan below the coils. Use a turkey baster to shoot hot water into the drain hole until it is free of ice and water flows freely into pan below. Find the defrost thermostat and turn it manually with a screwdriver and see if the defrost heater gets hot (be careful, gets very hot) timer should turn very slowly when powered. If not hot but timer turns on its own the defrost thermostat is probably defective.
Sep 20, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Kenmore elite french door freezer on bottom
Odds are due to the fact the ice maker was left on for an extended time with a full tray of ice the mechanisms froze. You can take a hand held hair dryer and defrost the parts, just be careful not to get too over zealous and melt the plastic parts. It should only take a few minutes to defrost.
To avoid this problem from occurring again, I turn the ice maker off when the ice tray is full.
Regards,
Ann
Nov 05, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerators Logo
427 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
john h
