SOURCE: ice build up in back section of a Whirlpool no frost top freezer refrigerator 66"hx30"wx27"d
your sure the defrost cycle works? sounds to me its not. you need to remove the freezer back and check the defrost components. or put it in the defrost cycle and see if it is working. to get that much frost as you describe the dor would have to be left open. also check all door seals. let me know what you find and we can go from there
SOURCE: Model is GSS25WGMD WW No cooling in freezer or refrigerator
look for ice or forst build up on the rear wall of freezer compartment, sounds like you may have a defrost problem. this will affect temps in freezer and refrig. the most common def problems for GE are bad defrost heaters. these are model specific and fairly easy to replace your self. i got this part number form Sears.com WR51X10055 good luck peyton
SOURCE: Chemical odor in refrigerator/freezer
put coffeee grains or orange peeles this will take the smell away thanks from gilles
SOURCE: Warm Fridge Section, Cool freezer section
Problem seems to be solved. I unplugged it for a short time and plugged it back in. I'm guessing it needed to be re-set.
SOURCE: Does not cool. Compressor is running, fans are
Hi, Look in the freezer section and see if there is frost building up on the rear inside panel. If the is frost, on of three parts are bad in the automatic defrost.
If there is no frost, the compressor might be weak and not pumping the coolant as strong as it should.
Remove the rear inside panel in the freezer sevtion and see if the evaporator is frosting at all.
Please let me know what you find so I can assist you further with this issue.
Vic
