Question about Bunn Coffee Makers & Espresso Machines
My 2018 Bunn multicup coffeemaker's power button is flickering. The power is working, but should I be concerned about the flickering?
Posted by Trent Jenkins on
Peter Hall
    Habit-Forming:
    Scholar:
  • 67 Answers
This sounds like the light flickering rather than a faulty connection. You can check for a bad connection by tuning a nearby radio receiver to no station in the AM band. If there is a bad connection causing this you'll hear the sparking (in time with the flickering) on the radio.
Flickering is a common effect seen with neon indicator lights when they age and does not affect the switch function at all, so can be safely ignored.
Posted on May 02, 2019
5 Related Answers
Anonymous
  • 152 Answers
SOURCE: Warming Plate
actually the warming plate have heating element... they stop working only when the heating element gets open circuited or wire to that plate gets cut....
Posted on Jan 31, 2008
Gord Thurston
  • 131 Answers
SOURCE: empty bunn coffeemaker
The easiest way to empty these brewers is to turn them upside down over the sink. Turn it on it's side, always keeping the fill hole down toward the sink, and keep on going until you have the unit completely upside down. If there is a push switch under the lid to stop water from going into the pot until the lid is closed, you will have to keep this pushed in until the unit is empty
Posted on Feb 11, 2009
atbsmmom
  • 189 Answers
SOURCE: I mislaid my instruction booklet, how do I clean
With your brewer still turned on and full of water, pour 1 quart of white vinegar into the top and place the decanter on the base and close the lid. Allow the vinegar to stay in there for 2 hours. Then you will need to flush out the machine with 8-10 decanters of water. There is a manual located on the website www.bunn.com. Select @ home then go to products. Select the model and then there is an option to download the manual. Or you can call customer service with the model and code date and a manual can be sent out to you.
Posted on May 19, 2010
atbsmmom
  • 189 Answers
SOURCE: Unable to remove our sprayhead from our Bunn NHB Coffeemaker
You might try putting a butter knife underneath the sprayhead to remove it. If this doesn't work, then please contact customer service and request a tool that can be provided to remove the sprayhead.
lgritten48771
Lin Gritten
SOURCE: Bunn nhb coffeemaker warming plate
Don't bother calling the customer service number they are not at all helpful. just want you to buy a new pot at discount price they have no kits to fix the leak and no tech to help me fix it so no to calling customer service and I will never buy another bunn and ill advise my friends and family the same
Posted on Feb 27, 2014
Bunn automatic coffeemaker leaks water after making a pot
Tank and tank components should be delimed regularly
depending on local water conditions. Excessive mineral build-up
on stainless steel surfaces can initiate corrosive reactions resulting in serious leaks.
Feb 02, 2013 | Bunnomatic Corp. 10c Professional Brewer...
Overheating water boiling dry
if it is not adjustable you will need a new thermostat. Any bunn service centre should be able to help you out or if the coffeemaker is older it might be worth your while to buy a new one.
Sep 06, 2011 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
May 14, 2009 | Bunn NHB Coffee Maker
Bunn pour omtic 3 burner commerical coffe maker model 666L (pin # 658) Coffee maker will not brew red light comes on and flickers followed th set up insturctions still nothing, even put a pot of vinegar...
I'm going to presume that your brewer is a VPS series pour-over brewer. This problem can be caused by several things, so I'll list the most common ones.
1) The on/off switch for the lower warmer could be burnt out.This switch also operates the heating element.
2) The high limit thermostat quite offen blows on the older VPS brewers. this is a small unit held down to the top of the tank and has 2 wires voming to it.
3) Look for burnt-off wires. These models sometimes burn off wires on the top of the heating element.
4) If none of these work, then your problem will be your heating element itself.
Parts for these models are readily available from your local Bunn repair shop.
Dec 31, 2008 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
I cleaned my Bunn pour o matic
If the unit works okay, there is no damage. I would suggest using vinegar, or better to use a recommended cleaner from an appliance dealer, rather than something as strong as CLR.
After cleaning the coffeemaker with any type of cleaner make sure it is properly rinsed out!
Jerry G.
Dec 12, 2008 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Lost manual need cleaning instructions
You can download the operating manual for your machine in pdf format right to your computer from www.bunn.com By the way, I wouldn't personally put vinigar in any Bunn machine, as it takes forever to run enough water through them to get rid of the vinigar taste.
Jul 15, 2008 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Empty bunn coffeemaker
May 30, 2008 | Bunn Cuisinart Coffeemaker: Pour-Omatic...
Warming Plate
Jan 31, 2008 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Coffee Makers & Espresso Machines Logo
107 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
gbob59
Marvin
Marvin
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
