Question about Danby Refrigerators
The fan in my Danby portable ice maker is not working and unit is getting hot.
Posted by Cynthia Jenkins on
antoniorojas
    Dedicated:
    Visited the website for 20 consecutive days.
  • 280 Answers
Hi before you may damage
install a new fan this can solve your problem
Posted on May 01, 2019
5 Related Answers
Anonymous
SOURCE: Ice maker not working
I replaced both silinoids and the ice maker. The ice maker will freeze water but not fill with water. My refridgeratoor is an a Amana
Posted on Mar 08, 2008
Anonymous
  • 1665 Answers
SOURCE: no water to ice maker
  • The water line that's attached to the back of the refrigerator. Make sure you have good water flow. If the flow is poor, repair, clean, or replace the tubing or the shut-off valve that supplies the water.
  • The water-inlet valve. Replace it if it has failed.
  • Posted on Jul 28, 2008
    aborcass
    Ron Coons
    • 2651 Answers
    SOURCE: refrigerator failed keeping food cold, ice maker stopped working
    i would look on the back panel of freezer section, is it iced over???? either its iced over and you have a defrost issue, or if there is no frost at all behind the rear panel yo uhave a sealed system/compressor issue
    Posted on Nov 16, 2008
    Anonymous
    I recently had trouble with both my water dispenser and my ice maker. I determined that my filter was clogged, so I replaced it. That fixed the water dispenser but the ice maker still wasn't working. I investigated further and found that the water inlet tube was frozen solid. Aparently, when the filter was clogged the water came in so slowly that it froze before it got to the icetray. I tried pouring hot water over the inlet tube to melt it and it mostly worked, but there was still some ice in the tube further back where I couldn't reach. Finally I defrosted the freezer so all the ice could melt and turned it back on and now it works great! Hope this might help.
    Posted on Mar 31, 2009
    Fahr Quad
    • 774 Answers
    SOURCE: Danby ALSO does not cool 3 days old
    Take it back where you bought it. A 12,000 BTU unit should be more than enough for a 192 square foot room, so there is some problem with the unit.
    Posted on Jul 10, 2009
    Won't pump water to tray.
    How a Portable Ice Maker Works - NewAir
    www.newair.com/articles/how-a-portable-ice-maker-works/
    Look inside to find out how a portable ice maker works, and get some tips about ...Just fill a tray with water, stick it in the freezer, wait 30 minutes or so and, bam, ice! ...Power supply - if the unit won't turn on, make sure if it is plugged into an ... Leakingwater - If the pump is operating but no water is reaching the freeze tray, ...
    Customer Reviews: Igloo Portable Countertop Ice Maker ...
    https://www.walmart.com/reviews/product/15162429
    WalmartIgloo Portable Countertop Ice Maker ... My wife is lazy and never refills the ice traysto put back in the freezer. ... Great ice maker for camping trips and parties. ... even though the thing is completely empty so it won't make anymore ice, and 1/3 of .... My satisfaction was quickly marred by the sheer volume of the water pump in ...
    Igloo Portable Countertop Ice Maker - Walmart.com
    www.walmart.com/.../Igloo-Portable-Countertop-Ice-Maker/151...
    Walmart
    Rating: 4 - ‎350 votes - ‎In stock
    Buy Igloo Portable Countertop Ice Maker at Walmart.com. ... It features a 3.1L capacity water reservoir that can make up to 26lbs of ice in 24 hours. You need not drain the melted ice ..... A. yes, the ice tray that hold the finished made ice is right about the water reservoir. .... A. Jogie: No, it won't make crushed ice, only cubes.
    EdgeStar Portable Ice Maker - Troubleshooting Help ...
    blog.edgestar.com/.../edgestar-portable-ice-maker-troubleshooting-help/
    Jan 31, 2016 | Igloo Cooler Igloo Portable Countertop Ice...
    Emerson icemaker gets hot checked it out it's the compressor can this be a reason why my machine want make ice
    Heat cannot produce ice
    How To Fix Refrigerator That's Not Making Ice ' Fridge Repair
    www.partselect.com/Repair/Refrigerator/Not-Making-Ice/
    Find out how to repair a refrigerator ice maker that's not making ice by troubleshooting common problems and parts like water inlet valves and water filters.
    1 How to fix a portable ice machine part 1 of 3 - YouTube
    ? 8:44
    https://www.youtube.com/watch?v=oyaO_Q6CBUM
    Apr 18, 2009 - Uploaded by SteveJ619
    Part 1 of 3 on how to fix your portable ice machine. ... Fanstopped working on mine, is it an easy repair? ... Dumping theice maker upside down can damage the refrigeration compressor ! .... Emerson Portable Ice Maker - Emerson Portable Ice MakerVideo Review -portable ice maker - Duration: 3:57.
    Jan 07, 2016 | Emerson Refrigerators
    LOST MANUAL - WHAT IS RED BLINKING LIGHT
    What is the brand of your ice machine?
    I usually get Scotsman doing this ,
    Mostly it's because of the clogging of the air filter, and even after cleaning it needed to be reset.
    To reset you need only to push the signal button for 5 sec.
    And it's done .
    Jun 08, 2015 | Danby DIM2500WDB Portable Maker White
    Why is my igloo portable ice maker hot?
    The heat that is being removed from within the unit has to be extracted towards the outside. A lot of times the condenser coils are on the surface just underneath the exterior panels.
    Mar 19, 2015 | Igloo Cooler Igloo Portable Countertop Ice...
    My 26lb silver portable ice maker wont make ice?? Any suggestions???
    does it run? does the compressor run, does the fan run, is the air flowing across the outside radiator, is the air comiing out warm? is there a waterpump and does it run? Does anything get cold and does anything get hot?, it should be. These are my suggestions to look for in your unit
    Dec 31, 2014 | Igloo Cooler Igloo Portable Countertop Ice...
    Machine only makes ice cubes on a few coils
    Without knowing the type of ice maker you have there could be several causes for this. Low charge, metering device problem, make up water constant fill or to warm. Need more info to help.
    Jan 08, 2013 | Danby DIM1524W Ice N Easy Portable Ice...
    I have a danby(simplicity) portable airconditioner,was working fine till i heard ice droping into the fan(crunching noise).after that,it does not blow cold air anymore.any ideas what the problem could
    Is the fan no longer running, or is it now blowing room temperature air? If it iced up enough to drop ice into the fan it may have simply gone into defrost mode. Unplug it and make sure it has completely defrosted - if it ices up quickly when powered up again, you likely have a problem with the condenser lines.
    Jul 14, 2012 | Danby Heating & Cooling
    I HAVE DABY ICE MAKER DIM1524 AND THE FAN TO COOL
    I REPLACED THE FAN AND THE ICE MAKER IS WORKING JUST FINE.
    Jun 10, 2009 | Danby D9604 Refrigerator With Ice Box
    Refrigerators Logo
    Top Danby Refrigerators Experts
    William Miller
    William Miller
    Marvin
    Marvin
    Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
