Question about AT&T Cell Phones
My AT&T app wont update on my S7 edge - it keeps saying that there is application found to handle this action.
Posted by Kimberly Musgrave on
4 Related Answers
ish singh
  • 105 Answers
SOURCE: nokia 5530 xpressmusic it wont let me read new
if your phone is not showing msg and memoy is full.
you need to do one thing that creat an back up for your phon memroy and your contact number in your sim card. then go to setting and last option restore
factory setting click ok.if it wants security code type 12345 and press ok your phone will restart.
Posted on Dec 29, 2009
kid_ant
kid_ant
  • 881 Answers
SOURCE: wont update apps
You need to authorize iTunes in order for it to proceed with the update. Do that going to Store> Authorize this Computer...
You will then be asked for your log in information (Apple ID and password). Click Authorize after providing the necessary info.
There's another way. Go to iTunes Store which you'll find at the sidebar. And on the top-right corner, you will see "Sign In", just below the search bar.
Sign in there.
Note, the account you used to purchase those apps should be the account that will use to Sign In or Authorize in iTunes on your PC.
Posted on Aug 19, 2010
GULSHANclt
abdul rauf
  • 483 Answers
SOURCE: I keep getting the error message on my new Samsung S7 edge when I insert a new SD card it keeps coming up corrupted ? Please help !
hi,
same happened in my S7, i formatted it now it is good.
you try this way.
Posted on May 09, 2016
honeybun1986
  • 329 Answers
SOURCE: galaxy s7 edge
Check with your sim card first whether it's working or not. If it is working, Try a factory reset.
If that doesn't work either,dial the following code and see whether you gets your 15 digit IMEI ( Don't post it here. Just see whether it is coming)
CODE : *#06#
If you see only a bunch of "0"s or just a "0" or an empty space, you'll need to restore your IMEI
If it is not the case, it should be a hardware fault.
Posted on Jun 22, 2017
.After software update the battery drains very fast. Second time that this happens. PLEASE HELP!
There is some tips that could save the battery life for your reference:
1) Use Low Power Mode
2) Restrict Unimportant Notifications
3) Turn off Wi-fi if You Don't Need It
4) Do not Activate Location Service
5) Lower Screen Brightness
6) Limit Background Refresh for Applications
7) Tighten Up Auto-Lock the shortest period for your device, namely 30 seconds.
Jun 18, 2018 | Samsung Cell Phones
Tip
How to hard reset your samsung s7 or s7 edge
How to hard reset Galaxy S7 and S7 edge
Please note that hard resetting erases all the data on your device. Text messages, photos, videos, settings, everything will be removed in the process. So, don't forget to create a backup of your Samsung Galaxy S7 or S7 edge before proceeding.
Also make sure to juice up your smartphone to at least 60% or keep it plugged in during the process. You don't want to have your device turned off when you hard reset Galaxy S7 or S7 edge, or it will create further issues.
Factory reset Galaxy S7 or S7 edge the easy way
  • Open the Settings app.
  • Choose Backup & Restore > Factory Data Reset.
  • Now select Reset Device > Erase Everything.
  • Confirm the warnings and wait for the process to finish.
  • Once done, reboot your phone.
Hard reset Galaxy S7 or S7 edge using recovery mode
  • Power off your device.
  • Wait for a few seconds while your phone is shutting down.
  • Press and hold the Power, Volume Up and Home buttons simultaneously to get into Recovery mode. (read: how to get into Galaxy S7 or S7 edge recovery mode)
  • Use Volume keys to navigate and Power button to select an option in Recovery mode.
  • Once in, from the main menu, using Power key, select wipe data factory reset.
  • If you want to clear app data cache too, choose wipe cache partition. Clearing cache often fixes various software related issues.
  • When done, go back to main recovery menu.
  • Select reboot system now and that's about it.
Hope the above tips help you fix Galaxy S7 issues and bugs.
on Jan 16, 2017 | Cell Phones
Trying to reload The Weather Channel app to my Kindle Fire HD that the Geek Squad member deleted from my device in order to get weather video working again. Unfortunately, think I'm out of luck now.
I don't own a Kindle Fire, but, I'll take a shot at an answer.
In Google Play...my Samsung Galaxy S4 and S7 Edge phones have a tab called "LIBRARY" . Tapping this tab causes every app that was installed on my S4, S7 Edge and my now long gone Samsung Galaxy Note 10.1 (2012).
If such a tab exists in the Kindle's store app, check to see if the Weather Channel app is listed there. If it is, download it to the Kindle.
I'm going under the assumption that attempts were made to reload the current app from the app store, and it didn't work.
Feb 03, 2018 | Tablets & eReaders
Spammer changed again today bonniebaba77. Can't FIXYA moderators help block this spammer? Restart your phone to undo any unauthorized unauthorized changes. How can I fix?
link at the bottom has the fix or here
https://www.youtube.com/watch?v=Zu8E6WuQmII
How to fix Samsung Galaxy S6 Edge "Unauthorized actions have ...
https://thedroidguy.com > Mailbag
Aug 11, 2015 - How to fix Samsung Galaxy S6 Edge "Unauthorized actions have been detected" error. This post will address an issue with Samsung Galaxy S6 Edge involving the error message "Security Notice: Unauthorized actions have been detected. Restart your phone to undo any unauthorized changes."
How to fix unauthorized actions have been detected - YouTube
? 3:22
Apr 1, 2017 - Uploaded by AndroidHowTo
This video will show you "How to fix unauthorized actions have been detected". It happened During regular ...
Galaxy S6/S6 Edge "Unauthorized actions have been detected" Fix ...
? 2:10
https://www.youtube.com/watch?v=PjX2xd6_Bds Jul 25, 2015 - Uploaded by SneakySonBeach
dont restart phone make it go away! ... How To Disable Samsung "SecurityLogAgent" Security Notice ...
UNAUTHORIZED ACTIONS HAVE BEEN DETECTED - Samsung ...
https://us.community.samsung.com/.../UNAUTHORIZED-ACTIONS-HAVE-BEEN-D... Jun 18, 2017 - When you attempted to root your phone you tripped the Knox Counter. ... The unlocked lock you are describing indicates the phone has been modified with an unauthorized action (the root). The "Unauthorized Action" notification you are receiving is because the device had been tampered with in a way that was not intended.
Oct 03, 2017 | Facebook Apps
Hi i have just bought a samsung s7 edge and it wont let me update or download anything from the playstore. keeps saying not enough storage??
hmm seems like the phone is having an issue with its own internal storage try seeing if the phone connects with your pc by USB and try to place files such as music onto the device if it doesnt let you it seems the internal storage for the phone is corrupted and the device may need to be reset if it fails to reset the device is defective and needs replacing
Dec 27, 2016 | Samsung Cell Phones
2009 Lucerne is blowing the ECM 10 amp fuse. Seems to do it after a right turn and acceleration. The circuit has ben traced but no issue was found. Said it could be a short that is hard to find.
  • GALAXY S7 EDGE CASE: Combination of clear hard back panel + soft flexible edges = excellent protection showcasing your Galaxy S7 Edge. Compatible only with Galaxy S7 Edge.
  • BEST PROTECTION: The lips on both front and back protect the screen and the back panel from scratches
  • SCRATCH RESISTANT BACK COVER: Premium Japanese polycarbonate with scratch-resistant coating will keep your help your case endure scratches and scuff marks more than a regular case. Longer life and cleaner look for your case and for your Galaxy S7
  • IMPROVED GRIP: Flexible rubber edges of this clear case for Galaxy S7 Edge hugs each and every corner of your Samsung Galaxy S7 Edge and allows you to get a better grip
  • German TPU rubber bumper edges and Japanese polycarbonate back cover are infused using the latest technology.
AmanStino Galaxy S7 Edge Case Hybrid Scratch Resistant Back Cover with...
Nov 27, 2016 | 2009 Buick Lucerne
How to root samsung galaxy S7 SM-G930FD
Samsung Galaxy S7 and S7 Edge are the popular ones of the latest Samsung smart phones. Although the new duo is armed with the latest technology, many S7 or S7 Edge users still want to use the devices as their own likes. Rooting is just to fit their needs. Rooting S7 or S7 Edge allows users to give more functions to their devices. It means that users will have access to their Samsung. Here this tutorial will show you how to root Samsung Galaxy S7 or S7 Edge and undelete files from them.
http://samsung-deleted-data-recovery.blogspot.com/2016/11/how-to-root-samsung-galaxy-s7-and.html
Mar 18, 2016 | Samsung Cell Phones
My Facebook keep frezzing and saying Facebook has stopped running. I have a Note 4 .
1-Go to Settings > Application manager
(and scroll to the All tab. Find your Facebook app and tap Clear cache and Force stop).
2-Restart your Note 4, and see if the issue is resolved.
3-Check in the Google+ app. (Tap the three dots at the top right and choose Settings, then tap your name under Account Settings and choose Facebook).
4-Try unchecking Keep Facebook up to date.
Some people report that they resolved the issue by disabling Google+ or uninstalling updates for it.
The options can be found in Settings > Application manager > All > Google+.
Aug 21, 2015 | Facebook Computers & Internet
Cell Phones Logo
Top AT&T Cell Phones Experts
William Alequin
Muntejaya Ginting
Muntejaya Ginting
Vincent G
Vincent G
Are you an AT&T Cell Phone Expert? Answer questions, earn points and help others
