Question about Canon PIXMA MP780 All-In-One InkJet Printer
On my Canon Pixma MP780 a vertical line appears on copies made using ADF
Posted by SEBBY on
  • 1 more comment
  • Anonymous Nov 28, 2007
    Same problem with MF4150. Actually have two lines. Funny thing no lines when doc placed on doc tray.
  • cwcarlile Dec 05, 2007
    MP780
    I have a problem with alternate lines not printing when I send a document to the printer but not when I copy from the glass platen. But the copy quality sucks anyway and it wasn't like this in the past. I have auto aligned the heads, checked the nozzles and done a clean to no avail. When I did align heads it didn't print the full number so I did an auto align since I didn't know how to align them manually.
  • lindamandy May 05, 2009
    I had the same problem with the ADF. Thin line vertically down the paper when I copied using this option. I thoroughly cleaned the rollers, glass, etc. of the ADF with alcohol and now it works great! Thank you for your help!
shredlew
  • 3 Answers
I tried the other solutions listed here - and no luck. After cleaning the inside of the ADF, like the manual suggested - no change. How are you supposed to do that anyway? Deep cleaning the inside of the machine also has nothing to do with it.
I finally figured out why things that I copied with the ADF had lines/marks on them, but those placed directly on the platen (big glass) were fine. When you copy with the ADF, the copy is not being made from the large glass area. Rather, there is a thin glass area right next to it.
Turns out, there were a couple of smudges (goo) on that thin piece of glass which were creating long vertical lines down every sheet. Cleaned the glass - problem solved!
Gosh, I hope this helps someone else save some time, and frustration.
Posted on Dec 03, 2008
  • jhj1250 Dec 09, 2010
    thanks, it helps very much. it cost me a whole day to figure this out, after following your suggestions it works great. yeah, looks like its the small screen next to flat bed that needs to be cleaned up.
    thanks anyway.
Anonymous
Same problem with my Canon MF4150. One vertical line when using the ADF only. I just followed the Manuel and it worked! Lift up the ADF cover. Use a damped cloth to clean the whole area including the rollers. One of the rollers which causes it is little hard to get to but make sure you get it. wipe all the grooves just in case. It worked perfect.
Posted on Nov 01, 2008
Rishi Roshan Ali
  • 2,427 Answers
RUN A FEW DEEP CLEANING, if that dont work remove the ink well and clean it manually, you can eighter submerge it in rubbing alcohol for a few minutes then blow out the ink well (the passage where the ink flows through or you can boil it in rubbing alcohol
http://www.nodevice.com/manual/newmans/1164257699mp750780smpdf/get13922.html
thats the service manual
Posted on Dec 31, 2007
I am scanning a photo. I have translucent lines running horizontal through the picture before i print it.
Documents scanned/copied from the document feeder pass over a thin glass area where scanning occurs. Clean this area if sent faxes, copies or scans have black or white vertical lines.
  1. Lift the document cover to expose the platen glass.
  2. Wipe the ADF scan area (C) with a clean, soft, lint-free cloth moistened with water.
  3. Then wipe with a clean, soft, dry, lint-free cloth making sure there are no residues left, especially on the platen glass.
  4. Close the document cover and make a copy of a text document to confirm the black line has disappeared.
Dec 20, 2010 | Canon PIXMA MP780 All-In-One InkJet...
When I make a photocopy I get a dark vertical line down the page. In fact, now I get two dark lines. It has something to do with the scanner, because it happens when I send someone a fax as well. ...
Do you use the automatic document feeder (ADF) when you photocopy and fax? Do you use the platen (lift the cover up) when you scan a document? If so, you probably have some dirt or foreign material in the ADF scanner area, which is a thin glass area to the left of the glass platen. Clean this area with a damp cloth and dry it before trying again. There is a plastic strip covering this area, and if this is scratched it can be removed and replaced.
Jan 19, 2010 | Canon PIXMA MP780 All-In-One InkJet...
I have a Canon Pixma MP780, keep getting "clear ADF" messages. changed the settings to off. Also, scanner is giving me some error messages #2, #178
Try Canon support. Type your query. Click "Search"
Example: Type "clear ADF" (You may have paper or some obstruction in the Auto Document Feeder).
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=238&modelid=10444#SupportDetailAct
Nov 30, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Red vertical lines, scanning to computer
I had one red line appear when i used the duplex. I happened to notice that the thinner glass window on the scanner was dirty. I cleaned it and now no line appears.
Nov 24, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Vertical line on page
i have the same problem although its a horizontal line
Jun 19, 2008 | Canon PIXMA MP830 All-In-One InkJet...
MP780 vertical lines on photos
Hi. the problem is the print head, maybe is clogged or damage, try this remove the cartridges , and the print head and submerge the print head in hot water for 3 minutes, dry the print head and reinstall it, if problem persist replace the print head.
TCT How to remove and clean Canon Printhead
May 02, 2017 | Canon PIXMA MP780 All-In-One InkJet...
MP780 photocopies made using ADF have a line which obscures content
I tried the other solutions listed her - and no luck. After cleaning the ADF rollers, like the manual suggested - no change.
I finally figured out why things that I coped with the ADF had lines/marks on them, but those placed directly on the platen (glass) were fine. When you copy with the ADF, the copy is not being made from the large glass area. Rather, there is a thin glass area right next to it.
Nov 24, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Canon pixma mp780 - vertical line on printing
Not sure if this will help but there is a small glass panel to the left of your flatbed scanner- this must be clean or else I get a black vertical line in my printing.
Jul 04, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Canon Pixma MP780 Fax Problem (horizontal line)
Solution is here: http://www.fixya.com/support/t136826-printer_problem
Mar 05, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Verical line(s) problem with canon mp780
Hi Nick, It's ONLY when you copy? I start by cleaning the platen glass. Wipe the Platen Glass with a clean, soft, lint-free cloth moistened with water. Then wipe with a clean, soft, dry, lint-free cloth making sure not to leave any residue, especially on the Platen Glass. If you have trouble getting the scanning area clean, wipe with diluted mild detergent (for dish washing). Do the same thing for the white area under the platen lid. If this does not resolve the problem let me know. His Dudeness
Nov 15, 2006 | Canon PIXMA MP780 All-In-One InkJet...
Canon PIXMA MP780 All-In-One InkJet Printer Logo
599 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Ekse
