Dryers Logo
Candi Hollifield Posted on May 01, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi, my 20 in lasko wind tunnel fan is on the blink again.A few months ago I cleaned it & it wouldnt turn back on, finally after days of trying everything & even trying to reason with the thing-out of the blue plugged it in & it came on. GENTLY cleaned it a couple months later-same result. Last week I brought it into another room & have yet to get it to turn back on. Nothing, not a hum, nothing.Someone please help me, I'm recently widowed & it seems like everything I have I is falling apart & am not able to go out & purchase a new one. Thanks everyone, Candi aka/Sweating in N.C.
Steve F
Level 3:
  • Master 1,361 Answers
  • Posted on May 03, 2019
Steve F
Master
Level 3:
Answers
1361
Questions
Helped
566842
Points
3788
Unfortunately, it could be a number of things. I assume you have tried something else in the same power point to see that power is there? If the unit is dead, it could be a safety device has tripped out. Check if there is a reset button or similar on the fan. If not, the fan will need to be taken apart to find out what it is. There may be a broken cable or loose wire.
5 Related Answers
Anonymous
  • 90 Answers
  • Posted on Aug 01, 2009
SOURCE: Fan will not turn on when you plug it in.
that could be the problem.just cut of the plug and attach a new one.
Anonymous
  • Posted on Jun 10, 2010
SOURCE: Lasko Box Fan Stinks!
same thing with my lasko box fan awful oil smell
Anonymous
  • Posted on Sep 04, 2008
SOURCE: LASKO fan problem
Check for a loose wire in the wiring harness
Anonymous
  • 62 Answers
  • Posted on Oct 07, 2008
SOURCE: riding mower problem
What is the name brand and model? On most riding mowers there are several switches that must be actuated before it will start. First, make sure that blades are disengaged. If there is a handle that engages and disengages them, you might try holding it in the dis-engage position in case the switch is out of adjustment. There is probably one under the seat also. This switch kills everything if you are not sitting in the seat for safety reasons. Also, make sure the parking brake is set, and the gear is in neutral, and not forward or reverse. Also, you should check the battery. It is possible that you left the key on by mistake and drained it.
Hope some of this helps.
C
Anonymous
  • Posted on Dec 14, 2008
SOURCE: T.V. TURNING OFF AFTER ABOUT 5 MINUTES.
Go to Samsung.com for solution. There is a switch that just needs to be repositioned behind access door on rear. Fixed my HL-S5086W ok.
How do i remove the actual blade unit from the backing on my lasko wind tunnel remote?
the blades are held on with a left handed thread for the center
undo tat by turning it clockwise and then the blades will slide off the shaft
Lasko tower
it will need the bearing changed. you can get copper bearings off ebay you just need to know the size or motor number.
1helpful
2answers
Cleaning my 2554
there are 20 screws to take apart the fan.
but try this
something to wedge the blade and blow out the fan. it will work jus the same
Problem with a Lasko 3440 Floor/Box Fan.
light is on ,but there is no movement from the fan. I think I need a fan motor.Lasko 20" fan motor part #3440.
7helpful
How To Clean
On the back of the fan there are 6 recessed phillips head screws around the circumfrence of the fan. You must use a longer screwdriver as the screws are set in a couple of inches.
The two screws on the bottom are a little harder to see.
There are also two clips on the sides front cover. Squeeze on the sides gently to release these.
Fan seems to go and stop and then go again is this normal o
I have one of these. It sounds like you have it on breeze (the 3 wavy lines on the remote) Push that button, then push the run button(first button on the right bottom) for it to run normally. The circle with the blades in the middle(left button on bottom row) will turn the fan from low (1) to (3) high. The icons are the same on the remote and the fan itself. Hope this helps.
1helpful
LASKO fan problem
Top Lasko Dryers Experts
Jay Finke
Jay Finke
ADMIN Andrew
ADMIN Andrew
Are you a Lasko Dryer Expert? Answer questions, earn points and help others
