I would suggest trying new batteries as well as making sure the receiver is about 8in to 12in from the mouse and at least 6in from the monitor. If you are still not able to connect, uninstall any drivers you have install for this mouse, reboot your pc and reinstall the software 1st, then connect the hardware and reboot your pc.
Good Luck
C2Solutions
Hardware Installation
Please keep these directions in a safe place. Each time you replace
the batteries you will need to re-Iink your mouse.
1) Insert the enclosed batteries into the battery compartment of
your mouse following the directions in Section 3.
2) Plug the Optical Mini Mouse receiver into an available USB
port on your computer or USB hub. It is not necessary to
reboot your computer.
3) If prompted, insert your Windows disk and follow the on
screen instructions. (This step is not necessary for all
operating systems. Your system will prompt you if it is
necessary. )
4) Press the link button on your receiver.
5) Press the link button on the bottom of your mouse.
6) Your mouse should !lOW function nonnally. Move your mouse
to test functionality.
Battery Installation
1) Grip the front of the mouse (the end with the buttons) with
your left hand. " , .
2) With your right hand horaihleiilad{ rifthemrius~ (Jrid Opposite
the' buttons) wIth yoUr thumb oil the bottom, and your index
finger and middle finger resting on top.
3) Griptbe molise firinIy, pressingd6wti.'slightlyontheGE logo
, 'on top of the mouse with the index and ririddle finger of your
right hand, then pull back to release the battery cover.
4) Set the battery compartment cover aside. Insert 2 AAA
batteries, being sure to match the polarity of the batteries with
the polarity markings inside the battery compartment.
5) Replace the battery compartment cover.
6) Re-link your mouse. See Hardware Installation (above)
Posted by MicroWiz Rep ([email protected] ) microwiz.us
