Standby light continuously flashes with no picture or sound
I can't get any picture or sound on my 53" Sony TV, and the Standby light flashes continuously. I have unplugged and re-plugged it in with no change. I can't seem to find a RESET button anywhere. PLEASE HELP?
Re: Standby light continuously flashes with no picture or...
Count the number of blinks; you may have to unplug the set and try to turn on again--if it does not blink in a sequence(3 blinks, a pause etc) the set is in shutdown and many things can cause this.
Jan 12, 2013 - I need help with my Sony TV. The red flashing light keeps going on and off. ITs on standby. can someone guide me as to how to fix the problem. ... I have a Bravia KDL52W3000 with a 7" wide dead pix... Television - Picture & Sound ... What is the exact model number of the Sony TV? Check if the same issue ...
http://www.moduslinkptstvboards.com/search.php?search_query=A+1316+295+A&x=7&y=13 try this....may have to send board to them for repair.....good success, meder's tv service
Hi, The Standby/Power light of the TV blinks when there is any internal malfunction in the TV. The self-diagnostic function of the projection TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue. As per the two examples below, some of the issues may be resolved without the need for service. If the STANDBY light flashes three times in sequence, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue. If the STANDBY light flashes four times in sequence, the TV may be overheating. To resolve this issue, ensure that the back of the TV is well ventilated. If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset: Try the following steps to check if the issue can be resolved. Turn off the television. Unplug the television power cord from the electrical outlet. Let the television remain without power for 60 seconds. Plug the power cord back into the electrical outlet. If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television. If the issue continues to occur, service may be required.
(i) Disconnect all the cables from the TV including the power cable then reconnect them after a few minutes. (ii) Make sure that the power cord from the TV is directly connected to a functional wall outlet.
If the standby light keeps flashing then service will be required.
My Sony trinitron has the stero lite on steady and standby lite flashes four times then pauses and repeats. Can you tell me the circuit/condition causing the set to not turn on.
Please post both the exact model number (on the back) and the blink count. The standby light should be blinking a repeated pattern. That info will indicate the problem circuit and allow us to provide you with the proper parts/steps to resolve this.
