Microwave Ovens Logo
j
janet hanley Posted on May 01, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kenmore over the range microwave. Model # 401.80082700. where is the fuse
Microwave was cooking and then just died
Terry
Level 3:
  • Kenmore Master 11,377 Answers
  • Posted on May 01, 2019
Terry
Kenmore Master
Level 3:
Answers
11377
Questions
Helped
4626538
Points
152765
Electricity is stored in the microwave, and before removing the panel to remove the fuse, you must wait several hours with the power off, and the power plug disconnected. You really may not be the right person to attempt this, as you could be seriously injured if shocked.
https://www.searspartsdirect.com/model/1koh14z3g3-000582
5 Related Answers
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Oct 22, 2007
SOURCE: kenmore microwave range hood model 665.61612100 manufactured 2001
The problem is likely on the control panel, which we repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This often can affect the exhaust fan operation, too. The lights and fan can be inopoerable or stuck on.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Anonymous
  • Posted on Mar 17, 2009
SOURCE: Microwave stopped working while cooking. Is there a fuse?
If unit is built-in reove screws holding unit to cabinet.
Slide out about 2 inches to access 3 screws holding grill.
Remove grill to get to two screws holding control panel.
Fuse is behind control panel,
Anonymous
  • 4088 Answers
  • Posted on Aug 19, 2009
SOURCE: Tappan TMV151FS over range microwave starts to work and then dies
Never run the microwave without a load (something to heat)!!! That kills the microwave generating parts.
Sounds like a 'thermal' protect switch is activating after running. Make sure that (if the unit is mounted in a cabinet) that there is sufficient space around the unit for proper air flow and that nothing is blocking the vents. Try setting it on a counter top and heat something. If it works properly and doesn't shut off, the venting space is the problem. You may have to have the cabinet that it sits in redesigned for more clearance.
AZBen
AZBen
  • 220 Answers
  • Posted on Dec 12, 2009
SOURCE: How do I turn off Kenmore Microwave Beeping?
I've got a Honda Civic hybrid with the same noisy beeper. I can't have the parking lights on and the door open. I can't leave the key in the switch while making a phone call etc. I think we have to presume that like the Honda, there is no software controlled override on you microwave beeper... they know best and want you to feel safe and secure that no burglar will be able to make a cup-o-soup in your kitchen without waking you. A few screws and you should be able to expose the main circuit board and apply a layer of bubble gum or silicone caulk or JB Weld to the beeping device. Most have a small hole in a black plastic cylinder... so cover the hole and then test for loudness. For absolute silence, desolder the device from the circuit board and replace with a resistor matching the amount you measure across the beeper contacts with an ohm meter.
Anonymous
  • 534 Answers
  • Posted on Mar 31, 2010
SOURCE: Microwave turns on but doesn't cook
There is an inline fuse that is accessed by removing the outer casing. Follow the power line in to the magnatron and you should see the fuse. Make sure the fuse that you replace it with is the same as the one you removed. If this doesnt work then the magnatron has gone out.
Dave
Kenmore 790.8033 over the range micro lost power after opening door while cooking. Outlet & breaker ok. Does my model have both line & thermal fuses?no diagram so far
First off there is supposed to be no possible way to open the door while running. I would think that something in that circuit that you can't repair so that it is repaired the proper way, I will get to searching for you.
Kenmore elite microwave
Was it just the exhaust fan that came on? If so this is normal when cooking on the stove for long period of time without the fan running. The heat builds up under the microwave and eventually activates the fan.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jeffrey_634abadf963e31e5
Kenmore microwave model 721.80033700 won't heat
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
3helpful
Dave
Kenmore Over the Range 1000 watt Microwave with no power.
I have the same problem now did you come up with anything for this model
1helpful
I've got a Kenmore microwave that just stopped working in the middle of a timed cooking. The model # is 721.69200890. Is there a fuse to change or something like that? Thanks, Roland
If the oven is completely dead, (no light or display) it probally is a fuse problem. It does have a 20 Amp fuse. With that being said, I would stress that a qualified service technician check it out. There are some high voltage components inside and a person who is unfamilar with high voltage components can seriously get hurt or even die if they don't take the proper precautions working with this type of appliance.
2helpful
2answers
Kenmore microwave 721.80593402 died
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If you or someone you know wants to look into this, we have critical safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can probably find exploded views and order parts by entering your model number here: http://www.searspartsdirect.com
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
We're happy to help and we appreciate your thoughtful rating of our answer.
Top Kenmore Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
