Question about Garden
I recently bought a battery powered weed eater it’s the lite trimmer.I broke the cap that goes over the string roll where can I get a replacement
Posted by Elaine on
john h
    Top Expert:
  • Garden Master
  • 23,424 Answers
Notify manufacturer or online search
Posted on May 01, 2019
5 Related Answers
pumpkinman
Steve Sweetleaf
  • 1176 Answers
SOURCE: How do i replace a rewind spring in a stihl fs 45 weed eater
you have to kake sure u wind it the rite way there should be tension on the spring when it is wound and if let go should return if it does that u have it rite...the little plastic peice must be connected to the hooh on the spring
Posted on Jul 25, 2009
itsman
  • 89 Answers
SOURCE: String-trimmer (weed eater) won't start.
the only thing left is the coil that is inside the cover right next to the flywheel with a gap of 10 thousand of a inch a business card will work but a new coil is almost thr price of a new trimmer unless you have a used one
Posted on Nov 05, 2009
Testimonial: "Thanks for the help. We did look at the coil. Got about 30 volts out of it when we pulled the starter. I hope that means it's OK."
Anonymous
  • 13 Answers
SOURCE: replace pull cord Big Wheeled weed EaterString
First, remove the recoil assembly but dont disassemble!
You'll need about 3 1/2 ft. of the same size rope. Tie a knot into one end of the rope. While holding the pulley in place observe the direction the pulley moves when rope is pulled. Release pulley and cut and remove old rope. Continue winding pulley in direction rope would pull it. Do no wind too tight. Line up holes in recoil housing and pulley then push rope through pulley and out housing. Tie on handle and install recall in reverse order.
Posted on May 06, 2010
emissionwiz
Marvin
  • 85239 Answers
SOURCE: Weed Eater Electra Lite 9 - re - stringing
It unscrews.
Posted on Jun 07, 2016
What type of string do I buy for my homelike weed eater
Without knowing your model number, the typical string for the Homelite trimmers is .080" string.These types of units use that:
http://dl.owneriq.net/7/7d91348b-6b05-4cce-ad47-08aad2e1f2dd.pdf
Apr 09, 2011 | Homelite Mighty Lite Lawn Trimmer
My starter pulley was broke i replaced it with a
If it was installed correctly, it is a defect. Have your supplier replace it. You may have to pay freight. Good luck...Lee
Oct 01, 2009 | Homelite Mighty Lite Lawn Trimmer
WEED EATER STRING
you have the string in backwards, or the gear is not ingauged.
Aug 13, 2009 | Poulan/Weed Eater No. Te475 952711797 17"...
I can not put the string on my weed eater
Remove the bolt holding the spool in place. Unscrew the cap and turn the spool. that should give you access to the spindle that holds the line. Put the new line in the starter hole and reverse the process. You should be ready to go now
Jun 13, 2009 | Homelite Mighty Lite Lawn Trimmer
Ryobi weed trimmer
I have one of this trimmers. It is simple to replace the line.
-First line up the arrows on the bottom of the spindle.
-Then feed the line back in one of the holes in the side of the spindle (this is the same hole that the cutting string comes out of).
-You will see the line come out of the bottom of the spindle.
-Take that line a place it in the hole on the bottom of the spindle.
-Leave about 9 feet of string hanging out of the weed eater (do the same with the other side).
-Then turn the inside wheel (I can't remember if it is clock wise or counter clock-wise but it will only turn one way) most of the string is rolled into the spindle.
-Cut the string of about 5 inches out of the weed eater. You're ready to cut!
May 24, 2008 | Ryobi 15" Electric Factory Reconditioned...
Garden Logo
22 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
