Question about Hayward Pool & Spa
Hayward 400 series propane pool heater. Will not ignite. Propane full and line is open. It clicks a few times, blower starts, makes sound like it will ignite, but it does not ignite.
Posted by Douglas Bonoff on
john h
    Top Expert:
  • Hayward Master
  • 23,504 Answers
Check and test thermocouple
Posted on Apr 30, 2019
5 Related Answers
john224
John Prohaska
  • 1378 Answers
SOURCE: Hayward model H100ID1 pool heater
The diverter inside your manifold is likely broken. You should stop using the heater immediately as the nocking is from water starting to boil in your heat exchanger. This can lead to a dangerous situation if a limit switch does not act in time.
Pull the inlet hose from the heater and you should see a plate just inside. If you can move it around it is broken and the fix is a new exchanger assembly.
You can fin these online and we sell them at www.arrowmotor.net
Posted on Jun 18, 2009
john224
John Prohaska
  • 1378 Answers
SOURCE: Hooking up a pool heater to propane.
A pressure regulator and pipe or hose. Whoever is selling you the tank/propane should be able to help you size everything based on the tank hook-up and tank pressure. The heater nameplate will tell you the proper inlet gas pressure that the regulator will need to reduce the tank pressure to.
Posted on Sep 08, 2009
Anonymous
  • 64 Answers
SOURCE: H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1: how do i fix the AO code on my hayward heater?...
AO will apply to your blower, blower tubing, or blower vacuum switch. You need to check these items.
Posted on May 20, 2010
Anonymous
  • 78 Answers
SOURCE: I'm receiving an error code CE on my Hayward H
Open up the control panel access door on the front. (the display). Remove the 2 screws at the top and tilt the assembly out. There should be a tab on the bottom that helps keep the assembly stable. Check all the connections on both boards for fit and broken wires. If all is ok, I would shut the supply power off, then back on and see if the data transfer works. If not, bad boards.
Posted on Jul 25, 2010
Testimonial: "Great advice. Working like a charm. No loose wiring. 2 large beetles between the circuit board and the display. Blew them out and it works great."
DBKOHL299
SOURCE: Conversion for Hayward H200 Ing Pool heater from propane to NG
I have a hayward h-2001 natural gas heater that I wish to change to propane. perhaps we can swap parts. [email protected] 920-324-5652
Posted on Jun 24, 2011
Why won't my Hayward H Series H200 pool heater not lite, what is the most likely problem
there are a few things you can check. make sure you have a good fuel supply. make sure the pilot light is lit. (just because the pilot is on doesnt mean you have good fuel supply). the pilot may be out of adjustment from the burner rail. the igniting burner rail may be dirty or blocked
Aug 13, 2014 | Hayward H Series Pool & Spa Heater 200k...
Hayward h400 pool heater blower not starting
it could be a bad blower vac switch, and you may look at the rubber tubing going into the switch to ensure it hasnt dry rotted.
Apr 07, 2014 | Hayward H Series Pool & Spa Heater 400k...
Error code A0
Just left of center inside the top of the front cabnit.(where the hayward label is) It's about 2 1/2" around and has two small hoses coming from it.
Jul 14, 2010 | Hayward H Series Pool & Spa Heater 400k...
Error AO ON MY HAYWORD H SERIES POOL HEATER
The AO mindicates an open prover switch ,, here from Hawward site .
If the blower prover switch opens unexpectedly during operation the control will
shut down and attempt to re-light. If the switch does not close after the blower
starts the control will go into lockout with the blower running. Automatic reset is
immediate after error is corrected.
If the blower prover switch does not close after the blower starts the control will
stop the ignition trial go into lockout. The blower will continue to run. Automatic
reset is immediate after the switch closes.
May 08, 2010 | Hayward H Series Pool & Spa Heater 400k...
Pool heater will not ignite
My heater worked ok , btu made a clicking sound, now it shows a AO error? What can I do I dont have enough money to call a pool man again.
Jul 03, 2009 | Hayward H Series Pool & Spa Heater 400k...
Trouble shooting Hayward pool furnace
Big enough propane tank? proper pressure reducing valve on the propane? Check both of those.
May 30, 2009 | Hayward H Series Pool & Spa Heater 400k...
Pool & Spa Logo
121 people viewed this question
Top Hayward Pool & Spa Experts
john h
Marvin
Marvin
Paul Carew
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
