SOURCE: waste toner container on canon imagerunner 330s
It is located below like a small box/ press beside the box to release /
www.justmanuals.com
SOURCE: Toner waste container location
The waste toner is in the front, open front cover and the white bottle in the middle is the waste toner cartridge. Remove the black screw, and empty or replace the cartridge.
SOURCE: Canon IR2018 keeps saying waste toner full
...the waste compartment is same unit in the drum unit...if you know how to take out the drum unit then you can see the waste compartment...but be carefull not to damage the drum...couse its will cost you a lot, the price of a drum is high...and if you can change the blade in the drum unit then you can emptying the waste toner...better call for the expert technician...
SOURCE: Waste toner collection IR 5570
remove the small lower( rear)right side cover 2screw then you will see the waste bottle youcan pull it out and throw away the waste toner
SOURCE: My Oki B2200 is repeatedly showing Toner is empty.
Hi there
I not know your printer but I can say this that after refilling it your chip will still thing it emty so some where on the printer Menu there is a way to reset the it back to 0 so it starts like new again.
Sorry cant be any more use to you than this, try looking up the net or the manual to how to reset.
All the best : Pineworks
