Question about Camping, Backpacking & Hiking
I have a stove top percolator. Can I use it on a propane stove as long as I'm careful not to melt the handle on a camping trip? It's a white pot with a chrome top and black plastic handle.
Posted by Ron Kapellen on
Steve F
  • 1,360 Answers
Depends... Check with the Owners book if its designed for electric stovetop only or both gas and electric. AGs tops will disperse more heat around the sides of the pot. It may or may not damage the plastic handle and it may discolour the white finish. If you cant find the info, it will be a risk you have to take. Try it and keep an eye on it while its percolating to see if the plastic is getting too hot or the white is starting to discolour.
Posted on May 03, 2019
5 Related Answers
Anonymous
  • 3 Answers
SOURCE: coleman instastart propane stove regulator wanted
Check to see if Coleman has an attachment to replace the regulator, so that you can use a five gallon cylinder with your stove and your own regulator.
Posted on Jun 29, 2008
mikedem7
Michael DeMondo
  • 25 Answers
SOURCE: why is my stove causing a thick coat of soot to buildup on my pots?
you have to adjust the air intake holes at the valves. this will give you a blue flame.
Posted on Aug 19, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: Need plastic handle on Rival Crockpot lid.
For what it's worth, when the handle on my mother-in-law's crockpot broke, I went to Home Depot and bought a cheap wooden drawer knob (about $1 as I recall). I put a plastic washer between the knob and the glass and another under the screw head from the bottom (to prevent cracking the lid), tightened the screw and good as new.
Posted on Feb 20, 2009
cactus bob
BOB BROWER
  • 267 Answers
SOURCE: Burned Copper Bottom Pot on Glass Stove Top
sorry to say no , if you try to peal it off or scrape ot off you will crack the cooktop . this keeps happening i have seen it at around 4 times for some reason revere ware melts . there should be a warning in the manual ( i know ge does have the warning about copper bottoms ) . replaceing the cooktop or the whole stove is the only "true" answer .... sorry .....Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob
Posted on Mar 02, 2009
Anonymous
I looked this model up on the Rival website, and it had been recalled, so I have followed the directions to send in the plug for a new unit. According to others with similar issues, once they sent in the plug, they were sent an entire new crock pot, including the crock and lid. I am hoping that they do send me an entire new unit, however, if not, at least I will have a different model number and could order a lid for that model. I will never buy another Rival product, based on their poor customer service. Thanks for your help!!
Posted on Mar 26, 2009
Can I buy a replacement grill?
You could try Coleman, they might be able to supply one.
The Coleman Company, Inc.
3600 North Hydraulic
Wichita, KS 67219
1-800-835-3278
TDD:316-832-8707
Jul 03, 2014 | Coleman Vintage Bernzomatic Deluxe Propane...
Coleman 5423b701
Try Coleman directly.
Wichita, KS 67219
1-800-835-3278
Sep 01, 2013 | Coleman Camping Stove 2 Burner Propane W/...
413e coleman stove
Is there a reason or a need? I cannot imagine why you would want to, except as a point of interest for your camp kitchen. A new propane stove would work better and not cost all that much, relative to the work and cost of putting fittings, pipes and burners into the old stove box.
Jul 28, 2013 | Camping, Backpacking & Hiking
Need parts
If there is no nearby repair dept, try Colemn.
Wichita, KS 67219
1-800-835-3278
Mar 31, 2013 | Coleman Vintage Bernzomatic Deluxe Propane...
How do you convert a coleman 425e into a propane stove
Feb 07, 2013 | Coleman 425e 2 Burner Vintage Used Camping...
What kind of gas do most camping stoves use?
almost all use propane or white gas, if you look in the small print on your stove it should tell you
Jan 30, 2013 | Kitchen Ranges
For camping with large groups, what is the recommended stove?
The recommended stove for large group camping I advise you to purchase the liquid-fuel stove.
Sep 10, 2012 | Coleman Camping, Backpacking & Hiking
Can I use butane in a propane camping stove?
No. You should only use propane, as directed, in a propane camping stove.
Jul 09, 2012 | Camping, Backpacking & Hiking
How do I make coffee in the corning ware coffee pot? It is the top of the stove maker and does not have any electrical cord.
This is a stove top percolator and you can use the great directions here:
http://www.talkaboutcoffee.com/how-to-make-coffee-in-a-percolator.html
Nov 19, 2009 | CorningWare Crock Pots & Slow Cookers
Replaceing glass top on a stove
The top can be replaced but it is expensive. Your range is less than a year old call a local servicer to see if there may be warranty available to cover this problem it may not cost you anything. Good luck.
Jan 15, 2009 | GE JBP64 CleanDesign Electric Kitchen...
Camping, Backpacking & Hiking Logo
138 people viewed this question
Top Camping, Backpacking & Hiking Experts
Tom Chichester
Kardoc
ray gallant
Are you a Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
