Question about Watches
I have Pravda t950 brand new was boxed battery will not charge I presume watch has been in box a few years ?...
Posted by jenn bowden on
2 Related Answers
David Tolond
  • 2501 Answers
SOURCE: juts got the watch, wound it, worked then stoped, wound dead
These watches are self winding (mechanical spring), so need to be worn (or gently oscillated) to wind them up.
The catalogue for this watch says it should run for 72 hours when fully wound.
Depending on when the watch was made, it could be that it needs a clean.
Try wearing it for a few days to see if it keeps going.
Posted on Feb 02, 2010
Testimonial: "I'll try that, thanks for the info!"
John Cunningham
  • 6771 Answers
SOURCE: My Casio Gw-300 G- Shock
From your description the solar cell charges the battery and keeps it topped up. I think the rechargeable battery is the problem because when the screen goes blank the battery level drops to low and the LCD blanks out which would explain the intermittent operation of the watch. I think it is worth getting it checked out with an estimate.
Posted on Jan 11, 2011
Pocket watch hands try to move but just can,t
Hi.
Pull the hand adjust out and move the hands back and forward to make it hasn't seized up, also try another battery just in case the other one is not fully charged up.
Regards.
Dec 08, 2011 | Colibri Watches
SEIKO KINETIC SQ 50 HAVE USE MY WATCH FOR 14 YRS
It is unlikely that the capacitor will have any charge on it so you should shake it gently to charge it up. You certainly can't do any harm by charging it, even if the capacitor did have any charge.
Feb 20, 2011 | Seiko Kinetic watch
I bought the G by Guess watch G99005G1 and it won't start. It's brand new, never used out of the box. How do I get it to start?
The watch should be working when you take it out of the box, unless there is something stated in your owners manual. The battery is probably flat or there is an other issue, either way the watch should be returned for exchange.
Dec 31, 2010 | Watches
Brand new technomarine watch chronograph csx wont work? do i need to dosomethin to start it??
Change battery. Watch can be brand new, but battery is fitted when watch left production line.
Nov 05, 2010 | TechnoMarine Cruise Watch
I have lost my instructions, have had my timex expedition at least 10 years, just need instructions on re-setting, as I have put a new battery in it. Also I've not used it for a few years, but the new...
You can get instructions from the Timex web site "timex.com".
At the bottom of the screen click on "manuals/downloads", then on "product
manual download"
Enter your watch type in the search box and click on "search"
Oct 04, 2010 | Watches
It' just out of the box new and the second hand jumps about 4 seconds at the time. How do I get it to not do that.
You can not do anything. At the point of sale your watch is brand new, but the battery was fitted when it left the manufacturer. So, put the new battery in and you will be sorted.
Apr 01, 2010 | Bulova Wrist Accutron Lucerne White M. Of...
My watch was on when i opened the box, but i hit a few buttons on the side and the screen went blank. trying to turn it on, but don't know how. does it need charging or something? confused.
Most likely you jostled the battery loose or the battery coincidentally ran out.
Take it to a repair shop to get a new battery. If you want to try and do it yourself, you can. But be prepared -- there are lots of small parts and small screws you may have to deal with.
Jan 06, 2010 | Adidas Response II Watch for Men
Internal battery seems to have no power
Battery in your watch is called ''CAPACITOR'' and it gets charged by light. The best source, of course, is sunlight and the worst is ordinary lamp.
By placing your watch for a few hours in a sunny window should keep your watch going for about 5 - 7 days.
As this is not happening, you need to replace capacitor. After doing that your watch will keep working and charging as brand new.
Capacitor replacement is not complicated job and any decent watchmaker can do it for you.
Do not forget to rate, please.
Feb 24, 2009 | Citizen Eco-Drive BL006056H Wrist Watch
Invicta Speedway 9223 not keeping time
It sounds to me as it is a quartz chronograph and it is right that the centre seconds hand moves only if the pushbutton is pressed. If you look close enough, you will notice that the small subdial finger is ticking and counting seconds. It is recommended to replace battery, as sometimes watches been laying in stores for a few years before selling and the battery is flat or underpowered.
Want to know more about your watch? Go to www.invictawatches.com and find out.
Regards
Arthur
Dec 16, 2008 | Invicta Speedway 9223 Wrist Watch
Citizen Eco Drive
A "non" fully charged watch will sometimes "jump" seconds rather than indicate one second intervals. Charging these small solar panel watches takes forever, in BRIGHT sun. Have you tried leaving it outside, in the sunlight, for at least 12 hours?
Jan 05, 2008 | Citizen Eco-Drive BL006056H Wrist Watch
Watches Logo
109 people viewed this question
Top Watches Experts
Janelle Schoonover
Janelle Schoonover
Bruce Robin
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
