Question about Refrigerators
WHY THE REFRIGERATOR COMPRESSOR TURNS ON AN IMMEDIATELY TURNS OFF?
Posted by Joshua Masokwe on
john h
    Top Expert:
  • Refrigerators Master
  • 23,424 Answers
Short -seized--thermal safety fail electrical circuit problem
Posted on Apr 30, 2019
The unit turns on for 15 seconds and then clicks off immediately, I took the backing off and the compressor looks normal nothing looks fried
If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 21, 2011 | Maytag MFI2569VE Bottom Freezer French...
Refrigerator comes on and immediately shuts off. will not keep foods in freezer. not sure if it is affecting food in refrigerator
Sounds like the compressor overload is opening. have compressor checked, a"hard start kit" may solve problem. If compressor is bad then replace refrigerator
Jun 22, 2011 | Kenmore Refrigerators
I have an old TRUE refrigerator (S/N 1-160481). How can I find the Model number and replacement compressor part number? Breaker trips immediately when turned on. Reaonably sure the compressor is...
GDM-41 would be the unit model number???
If you want to get a compressor model number that would be on the compressor tag on the compressor itself. I would not bother with a True part number just get the Copeland or Tecumseh number off of the compressor and get a replacement from a local wholesaler. On this old box do not rule out brittle or shorted wires. I haven't had success with converting a box like this to R-134a unless I change the entire condensing unit and would tend to go with an interim replacement like Hot Shot or R-409A or something like that. The box probably won't last long enough to make R-134a conversion viable.
Aug 11, 2010 | True GDM-41 Refrigerator
How do i remove the ac condenser on a mazda 3
B3E071161450W02
1. Disconnect the negative battery cable.
2. Discharge the refrigerant. (See REFRIGERANT CHARGING.)
3. Remove the splash shield.
4. Remove the A/C drive belt. (See DRIVE BELT REPLACEMENT [LF].)
5. Detach the two wiring harness clamps.
6. Disconnect the magnetic clutch connector.
7. Remove the A/C compressor protector.
8. Disconnect the cooler hose (LO) and cooler hose (HI). Do not allow remaining compressor oil in the refrigerant line to spill. (See Refrigerant Line Removal Note.) (See Refrigerant Line Installation Note.)
Caution • If moisture or foreign material enters the refrigeration cycle, cooling ability will be lowered and abnormal noise or other malfunction could occur. Always plug open fittings immediately after removing any refrigeration cycle parts. 9. Remove the compressor protector.
10. Remove in the order indicated in the table. Do not allow remaining compressor oil in the A/C compressor to spill.
11. Install in the reverse order of removal.
12. Perform the refrigerant system performance test. (See REFRIGERANT SYSTEM PERFORMANCE TEST.)
A/C Compressor Installation Note 1. When replacing the A/C compressor, remove the following amount of compressor oil from the new A/C compressor.
Amount drained (approx. quantity) • 155 ml {155 cc, 5.24 fl oz} - [compressor oil from old A/C compressor + 15 ml {15 cc, 0.5 fl oz}]
Aug 10, 2010 | 2007 Mazda 3
My (very old) Beverage-Air MT45 refrigerator just stopped cooling. The compressor seems to switch on, then immediately turn off. Is the compressor bad or just the start circuit? Anyone know how to...
turn it off let it cool go to parts house get a pro41 relay if that don't work the compressors frozen is it less than 5 years old it may be under warranty
Aug 02, 2009 | Refrigerators
Same problem
I had the same problem. The thing is you need to have the air on while you're recharging it and the compressor won't turn on. I was able to recharge the air by disconnecting the positive battery cable and reconnecting to reset the computer and immediately have someone inside the vehicle turn the air on before the computer can recognize that the refrigerant is too low and disable the compressor again. This will allow for the compressor to turn on and for you to recharge the air. Make sure that you have the replacement refrigerant connected before you turn the ac on so the refrigerant goes in and keeps the compressor on before the computer catches it again.
Jun 23, 2009 | 1997 Cadillac Seville
Works fine, but every couple of days I will notice that it will not be cooling, as the fan or compressor will not be working. I will turn the temp controler off, then back on and the compressor and fa
Check the condenser coil to make sure it is free of any dust, which will cause the compressor to overheat. The fan underneath may still be running, but until the compressor cools down it will not start.
If the unit always immediately begins running when you turn the control off and back on, then it may be you have a bad control. Have a servixe tech look at it, as you cannot repair the control...it's a throw away device.
May 29, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Hotpoint refrigerator ctx18; blower is on but when
you are goung to probebly need te install a three-in-1 relay on the compressor to assist in getting the unit to stay running and npot brealk down.
Mar 21, 2009 | GE Refrigerators
Loud, continuous buzz from Imperial heavy duty commercial freezer
Sounds like bad compressor. Turn off t/stat. If buzz starts when you turn it on then that is what is wrong. May be under mfr wty. Call Maytag to find out.
Nov 28, 2008 | Maytag MZD2766GES Side by Side...
Refrigerators Logo
397 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
john h
