Question about Whirlpool ET8WTKXK Top Freezer Refrigerator
Have a whirlpool refigerator. Model ET8BPKXKZOO. Serial VSM4854552. Manf Date 11 - 02. Won't cool. Blows cool air not cold. Everything in freezer thawed and unit is warm throughout. Hearing a clicking noise from bottom backside. This noise is every 20 seconds to a minute. Cooling tubes are cool to touch. Compressor is hot to touch.
Posted by grandpa3 on
Mike Smith
  • Whirlpool Master
  • 1,606 Answers
The overload/relay which pluggs onto the side of the compressor is bad . Pt # 2262181
Posted on Aug 07, 2009
Need schematic Amana frig SQD25VW-P1314202WW
Hello Ron Carlson
Page 6 of 6...
Pretty straight forward refrigerator!
Although I agree with the first answer you got from Todd Marr...a lot of available volunteers here have been around a lot of blocks...
Can call out the Whirlpool & Frigidaire units you share parts with... and how to very cheaply you can
test various parts to bring you to your very quick victory...
I'm just saying, ice-maker, defrost issues, warm refrigerator side... Fast frost build-up... puddles?
If you'll pardon the pun ...
FROST FREE REFIGERATOR/FREEZERS are pretty cool...!
Amana SCD25TBW Technical Information Wiring Diagram
Apr 06, 2016 | Amana Refrigerators
Freezer works but refigerator won't get cold
IF YOU HAVE ALOT OF FROST ON THE BACK PANEL OF THE FREEZER IT IS A DEFROST T-STAT THAT CAN BE BAD IF THERE IS NO FROST FELL UP IN THE LEFT UPPER CORN OF THE FRIG SIDE SEE IF YOU CAN FILL THE AIR COMING OUT OF IT
Nov 01, 2012 | Frigidaire Ffhs2313Ls 23 Cu Ft Side By...
I have a Whirlpool Refigerator (double door, freezer over cooler). Its model number is WBM35 IX (made in 2003). Lately I have problems in the fridge. The freezer freezes the items. But there is no...
My guess is the fan has gone on it. Mine did the same thing. The fridge gets its cold air from the freezer compartment via a fan that is usually in the back of the freezer. It's not a hard replacement, if you're tech-savvy (took me about 1/2 hr.) and the part will cost you about 40 to 70 dollars, depending on where you buy it (priced mine out at $70, I think, but found a local guy who sold me one for $40. It's called an "Evaporator Fan" and I believe this link will show you a possible replacement for it (The crappy part is that you need to take the old one out to look at it to be sure).http://tinyurl.com/3so7a86 Good luck.
May 26, 2011 | Whirlpool Refrigerators
Refigerator is not cooling. Freezer is working
You didn't provide a model number, so it's not easy. In most of modern refrigerators, the fridge side draws cold air from the freezer. Look for obstructions of the air vents.
Smith Brother Appliance Repair reviews
Apr 13, 2011 | Refrigerators
Freezer works fine but the refigerator does not get cool
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
Oct 11, 2010 | Frigidaire FRT17G4B Top Freezer...
Hi, I have a problem with my refigerator, the freezer works great but the refrigerator dosen't work. The fan that blows cold air from the freezer down to the refrigerator dosen't start, so thats why it...
You will have to replace the fan. Its a cheap fix and you can do it its not hard just pay attention to your wiring and turn off the power first. good luck
Aug 08, 2010 | Whirlpool Refrigerators
Whirlpool Gold GD5SHAXLQ02- Serial number SP3131657 just stopped cooling. Neither the fridge and freezer seems to be cooling. This unitl is about 7 years old.
Hi!!
Check
temp. control knobs,
Small fan in freezer
Remove freezer back panel (where the little fan is) and check for iced evaporator coil, if so, unplug unit and use a heat gun or hair dryer to melt ice, make sure the air duct going to the fridge is clear. Once this is done, restart unit.
If evaporator is not covered w/ice, then you may have a freon leak, Call a Service Center to get a repair estimate.
Don't forget to rate this post!! Good Luck
Aug 04, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Jenn Air JCD2389GTB side-by-side refrigerator freezing & cooling
Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Jul 13, 2010 | Jenn-Air JCD2389G Side by Side...
Problems with Whirlpool 21.0 cu. ft.
checklist: freezer fan running, compressor fan running, compressor running, any frost buildup on back wall of freezer. you may have to take a rag and touch the compressor to feel if its vibrating to see if its running unless you can hear it. please reply
Jun 12, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Frigidaire FRS23H5AS refrigerator - freezer not cold
Humming noise would be your compressor going bad. The noise from the fan is because they are over working to try and keep everything cool
Feb 12, 2009 | Frigidaire FRS23H5AS Side by Side...
Whirlpool ET8WTKXK Top Freezer Refrigerator Logo
283 people viewed this question
Top Whirlpool Refrigerators Experts
Michael Thomas
Michael Thomas
jdthefixer
Marvin
Marvin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
