Question about LG Washing Machines
Lg top loading washing machine serial no. 405kww1A457 wont fill with water when i turn it on, it tries to wash but. o water is coming in
Posted by Alice bourgoin on
  • Jr Millar
    Jr Millar May 01, 2019
    You may have a bad HOT/COLD Water inlet valve.
    If you have checked the the screen/filter and there is no sediment build up,then that is the culprit. You can check on Ebay, but you need to have the model number of your machine. The only problem is that you will need to dismantle the top panel of your washer. Theres are alot of videos posted on youtube that may help you with that.
brian williams
    Genius:
  • 1,864 Answers
Make sure water is on. If so water valve on washer may be shot.
Posted on May 01, 2019
  • brian williams May 01, 2019
kevin r mccurdy
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 10 Answers
Check that water is available from the hose
Posted on Apr 30, 2019
5 Related Answers
Jimster
James Greene
  • 240 Answers
SOURCE: kenmore top load (model # 110 82370120) drain problem
Good AM. I see here that you have a fairly old belt drive Kenmore washer. The real problem with these is that the parts for them are so very expensive anymore to get. A timer (which you may be needing) will run you around $100.00 to $175.00 depending on where you live. Very expensive repairs on these, but if you want to go for it, here are some hints to help. Sounds like you have one of three problems. First off PLEASE UNPLUG YOUR MACHINE BEFORE WORKING ON IT. Your timer may have lost or has a stuck contact inside (unrepairable in most cases) which is making it do something is shouldnt be doing in that area of the timer. This would probably be the most expensive of your repair. The next thing is it could be the water level switch could be going bad. This one is highly doubtful since it fills and stops filling, but I have heard (but never have seen) that they can short out sometimes and cause wacky operation. Both these issues can be fixed by remove the console rear panel and front knobs to remove both. The next item could be a defective wig-wag in the bottom of the unit. One of the positioning solinoids maybe going bad and sending bad signals back to the timer.
None of these problems are really hard to fix. And truthfully (even though some of these guys will be mad) you can sometimes find these parts on ebay for a halfway good price. Part numbers for each are:
Timer: 381860
Water Level Switch: 359712
Wig-Wag: 89814
Good luck with this one, and if you know how to use one, try to run resistance with an ohm-meter on your wig-wag to be sure your getting power flow through the soilnoids (you will have 2, be sure to unplug the solinoids before testing to be sure its a true test) before replacing.
Posted on Dec 06, 2007
Ian Greenland
  • 351 Answers
SOURCE: hoover 600mb 6.0 kg top load washing machine (not as below)
timer or timer module fault
Posted on Mar 02, 2008
Anonymous
  • 512 Answers
SOURCE: GE Profile Washing Machine wont fill with water top loader
disconnect water lines from washer and check to see if sedement from water plugged up little screen filters
Posted on Jun 13, 2009
Anonymous
  • 9 Answers
SOURCE: Leak from under the washer
tub seal has gone bad, will only get worse. Expensive fix,
Posted on Jul 02, 2009
SirQuincy
SOURCE: it fills up..washes..but wont drain or spin out..
I had the same problem. Checked the pump and it ran fine. Took off the door locking mechanism and put 120 ohms into the wax motor part and it tested fine too. I read about problems with that wax motor so I replaced the complete door switch today for $71.00 and the washer runs perfectly now. If it won't spin or even fully drain I suggest replacing the door switch.
Posted on Jan 09, 2010
There comes black stuff out of the washer when i spin. Isit the stasoft?
Fill your machine with hot water (if you only have cold water connected, then add hot water with a bucket) until the machine is filled to the top mark. Add a cup of dishwasher powder and stir it to dissolve. You can also let you machine run a short while, but be carefull that the water is not pumped out. Turn the machine off and let it stand overnight. Then turn it on the next morning and let it wash a complete cycle. You don't have to let the rinse part of the cycle complete. Just turn the machine off when the first water has been pumped out.
What this does: The machine builds of a residue between the drum and outer housing which is not removed in the normal wash cycle, especially if you don't wash with hot water. LG recommends that the machine is cleaned in the above way once "fluff" or black residue is starting to show in clothes after washing.
Mar 11, 2015 | LG WFT1071TP Top Load Washer
The water wont come out
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Aug 13, 2011 | Roper RAS8445KQ Top Load Washer
Wont fill with water
Here is a tip that I wrote about no water coming into the washing machine2_bing.gif...
http://www.fixya.com/support/r3880845-washing_machine_problems_no_water
http://www.fixya.com/support/r3880533-washing_machine_fix_washing_machine_no
heatman101
May 13, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
I don't seem to be getting Hot water to the LG Front Load washing machine.
AK Techno Service is one of the best http://aktechnoservice.com/lg-washing-machine-service-center-in-hyderabad/ . Front load top load semi-automatic drum failure, PCB repair service etc.
Here,you can find any type of solutions for your LG Washing Machine.
Apr 08, 2010 | LG WM2688H Front Load Washer
Errorcode de
heatman101
ar
Feb 16, 2010 | LG WM-2277HW Front Load Washer
Water will not shut off in washing machine
Check to load size selector switch, sounds like tube came off of it. The tube goes from switch to bottom of tube, tells machine what size load and when to turn off water.
Jul 19, 2009 | GE WBSR3140DW Top Load Washer
Flashing FE and wont stop filling with water
FE means Fill Error, but you already figured that out. If you unplug the machine and it still fills, and the only way to stop the filling is to turn off the valves supplying the water to the fill hose(s), then you need to replace a fill valve. It is best to figure out which one by turning one off at a time while the machine is in that FE condition. There is a separate hot and cold valve. (they are the part that the hose screws onto on the machine.) To replace valve, cover comes off machine by removing two screws at the back of the top. (not the two which go into the top, the ones just below them) Then, standing in front of the machine, use the palms of your hands to give the top a sharp push to the rear to slide the top back about two inches. Then lift the top off.
May 31, 2009 | LG Washing Machines
My washing machine wont stop filling with water
sounds like the hot cold water valve is bad,you also have the water level switch,the switch has a water level hose on it,some times the hose comes loose,chech y=that also,let me know what you find-mike
Mar 17, 2009 | Kenmore Washing Machines
Clean LG WF-T652a Top Loader Washing Machine
I have this problem too and I solved it easily !!!!
I hypothesised that something was blocked by dried up lint/silt. So I filled the machine with very hot water and also poured hot water down the lint filter outlets. I left it for 5 minutes and then started a wash cycle - and the water now comes out of the lint filter ducts. ! :-)
Jan 13, 2009 | LG WFT1071TP Top Load Washer
LG washer uses so little water, clothes aren't even damp and not clean
You will need to have a qualified LG technician come out and see what the problem is.  You may have a water level switch issue.
Jul 11, 2008 | LG WM1815CS Front Load Washer
Washing Machines Logo
118 people viewed this question
Top LG Washing Machines Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
