Press the SOURCE button on the main unit or on the remote control to display the Input Source list.
Press {up} or {down} buttons to select your desired input source among: TV/
Component/AV/HDMI1/HDMI2/HDMI3/VGA and then press OK
button to confirm. (The individual ports should be marked on the tv adjacent to port).
SOURCE: How do I change the input without the remote
If there is no nutton on the TV to do so then you have to have the remote for it. You can try a universal remote but, usually functions like that don't work. Here is a link to the remote you need. http://www.electronicadventure.us/Merchant2/merchant.mv?screen=prod&store_code=EA&product_code=6450348129
SOURCE: AV input selection without a remote
I had the same problem. I hooked up the DVD player and then got into the set up. I used the add/erase feature to go through all of the channels. At channel 91, I saw the logo for the dvd player. I added that channel and now the dvd player works.
SOURCE: i need to switch my tv to input without a remote
Hi
please use the menu button in your front panel then search the video, Air, or Cable selection!
Thanks!
SOURCE: Direct TV remote "tv input" button won't work with my Sony TV
I came across this looking for a similar solution for my Samsung TV, and I found the solution on ehow.com. Apparently after you program the remote for your TV you have to hold mute and select again until it flashes twice then put in 960 to make the remote control TV input too. Note you're remote should be in TV mode while you do this. It seems silly that the DirectTV guy wouldn't do this when programming the remote.
SOURCE: Sylvania 6420FF TV - SELECTING AUDIO/VIDEO INPUT w/o remote
During a recent move the remote was lost. I have the 6420FF in my son's room and trying to set up dvd and wi console set up, but cannot adjust tv via menu button on tv. Is there any way to set-up game system and/or dvd without remote?
