Hopefully the website will translate.
Remove throttle handle from shaft trying to keep all parts in one side and once removed place together and install a couple of screws, remove shaft from part no 42 by loosening screw no. 43, item 45 has either a allen head or star head screw in it will probably loosen ccw. Remove item 45, remove item 46 should be arrow to show which way to turn you will need to use copper or brass pin to hit with hammer to remove to prevent damage. Now remove item no. 41 and you are at the starter cord. You will now have to remove spool no 51 and notice how rope is wound if possible, remove old rope install new rope place spool back in place to where it catches spring as it should now wind in same direction as rope wound about 5 turns hold and run rope through eyelet of starter housing. Now install keeper 52 with screw 53.
Sorry link did not work just go to link below and type in your ut no.
then select homelite.
https://www.ereplacementparts.com/homelite-hlt17c-ut205
