Question about Pioneer Car Audio & Video
I have paired my phone with my Pioneer FH-S705BT car radio. The phone works fine, but I cannot access the phone book names
Posted by Herman Treurnich on
Alphanso Tee
    New Friend:
  • 169 Answers
YOU HAVE ALLOW PHONE BOOK ACCESS
FROM THE SETTING AND IT WILL WORK
Posted on May 13, 2019
5 Related Answers
Anonymous
  • 43 Answers
SOURCE: Cannot access phone book
haha simple flash back with any flex compatible with your phone SW.
Posted on Aug 30, 2007
Anonymous
  • 94 Answers
SOURCE: locked out of phone book
its not the problem go into securites and unlock ur phonebook ur code is 0000 and ur securite code is 00000
Posted on Jun 05, 2008
Anonymous
SOURCE: pioneer fph85
you can press the DSp button for 2 sec, then use the FF and Rev buttons to adjust the contrast.
this is a great unit i have owned mine for 12 years. only thing the cd does not work.
Posted on Jul 23, 2008
Anonymous
SOURCE: Instruction Book doesn't give guidance for pairing
The instruction book was not translated correctly. Here are easy instructions on pairing your phone to this unit:
http://www.teamclarion.com/sharedwebdbs/clarionsupport.nsf/74b3961cc7f08a658825719c00129eae/e73edb7fe51f33c3882576410055b7f9/$FILE/Product%20Bulletin%20(CZ509%20CX609%20Bluetooth%20Phone%20Pairing%20-%20WAIT).xls
Posted on Dec 05, 2009
e-Guru
e-Guru
  • 3917 Answers
SOURCE: I have Dual XDVDN 8190(auto
Hi
Some Bluetooth systems sync the address book on pairing. Some need you to transfer contacts after pairing. It really depends on the BT system. When the two sync with each other, watch your phone...right at the top it should say "Phone Book Access Request." Hit that notification, select Allow and your address book should sync to the head unit.
Please check the link bellow related to your query:-
http://social.answers.microsoft.com/Forums/en-US/windowsmobile/thread/5fea68e7-48c7-486b-b5de-2be8826c30c3
Please accept the solution if it’s helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Posted on Sep 12, 2010
How to remove paired devices on pioneer fh x700bt
Push and hold the phone button until you get a display, now using the big round button in the middle turn to your right until you get to the Bluetooth set up it will say program or delete and you delete the the paired device, and that takes it back to the factory reset.
Jun 13, 2014 | Pioneer FH-X700BT
When useing bluetooth i cannot hear anyone and they cannot hear me
Your stereo has to be on for Bluetooth, and your phone has to be set on for Bluetooth and scan, it should fine the code off your phone, when it does you would see it on the CD player, it would show the name or the model of your phone.
Mar 15, 2014 | Pioneer FH-X700BT
PROGRAMING RADIO STATIONS\
In the recent Pioneer models there is a function called BSM, in which it automatically programs all the radio stations, give it a try!
Nov 15, 2013 | Pioneer FH-P404
Installed Pioneer DEH P6200BT. Experiencing BT problem. Everything seems to work correctly, locating, pairing, receiving calls, dowloading address books, all of that works correctly. The problem I have is...
Hi! I just figured this out myself. The radio only sends the phone call audio to the front speakers. My car only has wires for one set of speakers, so I chose the rear channels. I just rewired to the front channels instead. Solved! Bad on Pioneer, there is absolutely no mention of this in the installation or operation manual.
Dec 07, 2010 | Pioneer Car Audio & Video
I have 2 users who drive BMW's and the phone keeps loosing its bluetooth connection. Previous Nokia phone was fine so I don't think it is a car problem
I had the some problem. After pairing with my BMW X1 bussines radio the connection lost after appr. 1Minute. Then the phone tried to re-connect but failed and the bluetooth connection don't respond anymore also if i switched off the radio. Only a restart of the phone could solve the freezing and then the same story happens again.
The problem was solved after I cleaned up my phone book. Cleaning means, no double items, each item with maximal 4 numbers, not more than 100 names, each item on the SIM card. One of that had finally solved the problem. Now it works very fine!
regards,
Skyflyer
Feb 17, 2010 | Nokia E71 Smartphone
Paring
how did u pair/connect ur voyager to ur deh-p9800bt? i tried from the head unit and from the phone.. read both books.. just cant seem to figure it out.. can u email me what u did plz? [email protected]
Dec 27, 2008 | Pioneer DEH-P9800BT CD/MP3/WMA Player/Blue...
BT phone book transfer
if you have paired the 2 devices then all you need to do is go into phonebook , pick the number, then I think it is options and send via bluetooth.
the phone should then ask which device you wish to send it to and give you a list of options that it is paired to.
sellect your pioneer and send
Feb 09, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Car Audio & Video Logo
69 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
