Question about Toys
6 volts battery for 1980 riding train no.4505
Posted by Loretta Nelson on
  • Rick Hickerson
    Rick Hickerson Apr 29, 2019
    Hi Loretta Nelson, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
2 Related Answers
Anonymous
SOURCE: I have two Little Tikes 6 volt battery operated
http://www.kidswheels.com/index.php?page=shop.product_details&flypage=shop.flypage&product_id=54237&category_id=205&manufacturer_id=0&option=com_virtuemart&Itemid=47&vmcchk=1&Itemid=47
Posted on Jul 22, 2010
James Van Wyk
SOURCE: I have the Little Tikes train 4505 and need a battery, charger and a new connector to the battery. Where can I find these parts or is there another way to fix these problems?
Janice We also have a little tikes train circa 1980's that we would would llike to get running for our grandson. I have ordered a battery from Apex Battery.com. I believe that The Elpower EP695 battery should work. It is the right dimensions and is a 13 Amp hour battery vs the 9.5 amp hour that was installed. We do not have the connectors for the cars and wonder how they connect together. Could take a photo of the car connectors and post it so that we would have an idea of what we are looking for. Thanks
Posted on Nov 12, 2011
I bought the peg perego train 2nd hand and the black button does not work to move the train
first of all check for at least 6 volts from the battery and the charger, you can test this using a multimeter, if the battery doesn't show any volts, lift up one side of the plastic housing on the top and verify that both the positive and negative wires are plugged in
Nov 11, 2012 | Peg Perego Santa Fe Express Ride On Train
Nov 04, 2011 | Toys
Our choo choo express train won't start...is it the battery...how can i fix the battery that has charged at least 24 hours
check the battery and the charger with a multimeter and make sure that its putting out at least 6 volts
Nov 07, 2010 | Peg Perego Santa Fe Express Ride On Train
I have two Little Tikes 6 volt battery operated riding toys that were probably purchased in the 1980's (Cruiser motorcycle/bike and 4505 Railroad). Since then, the electrical connection on present day 6...
Jul 16, 2010 | Toys
Battery issue with santa fe express train from peg perego?
yep use a multimeter and make sure its showing at least 6 volts
May 05, 2010 | Peg Perego Choo Choo Express Train Set
Santa Fe Express Train not working
check the charger first and make sure that it isn't bad, you can check it with a multimeter and make sure that its putting out at least 6 volts
Apr 19, 2010 | Peg Perego Santa Fe Express Ride On Train
I have charged the battery and it still does not work please help
check the battery and charger with a multimeter and make sure that its putting out at least 6 volts
Jun 24, 2009 | Peg Perego Santa Fe Express Ride On Train
My son poured water in his peg perego santa fe ride on train
It might have shorted out the motor under the seat.
I would contact the repair help at
http://www.shopjandl.com/
Jun 19, 2009 | Peg Perego Santa Fe Express Ride On Train
Toys Logo
133 people viewed this question
Top Toys Experts
Marvin
Marvin
Tom Chichester
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
