Question about Optics
Value and age of my beautiful Ritmuller G?ttinngen serial Numbers 17839 Thank you ?ke from Sweden
Posted by Ake Blomdahl on
neilybod
    Problem Solver:
  • 18 Answers
Value depends on its condition and and type (upright, baby grand, full grand etc.)
Serial number suggests around the year 1900 but certainly before 1910
Posted on Apr 29, 2019
5 Related Answers
tombones
  • 3567 Answers
SOURCE: Looking to find age of yamaha bike using serial number
Get the vin number off the front downtube that the steering triple tree mounts to. Call a Yamaha dealer with the vin # and they can tell the year, engine size and model of bike.
Please rate this solution.
Posted on Mar 30, 2009
HondaCRX
Dan Martin
  • 252 Answers
SOURCE: browning shotgun sweet sixteen age and value
In general, a 1950s Sweet Sixteen is a valuable gun. Measure the distance from the trigger to the end of the **** stock to get the "legnth of pull" (LOP). this was 14 1/14 " when it left the factory. If it is shorter, the value will be less.
Without seeing it, although many have been altered which would bring a price $350 - $450 area.
This guide might help if you can determine the condition : OS is 1958.
AUTO-5 SWEET 16
- 16 ga., 2 9/16 in. chamber from 1937-1940, and 2 3/4 in. chamber from 1947-1975, similar configuration to Lightweight, 12 and 20 ga., gold plated trigger, 10 oz. lighter than Standardweight Model 16 ga., 1937-1940 mfg. Sweet Sixteens were available in pre-war Grades I, III, and IV. Mfg. 1937-1975 by F.N.
Grading ...............98% ....95% ....90% ........80% ........70%
Plain Barrel .......$950 ...$825 .......$725...... $625 .......$500
Solid Matte Rib $1,300 .$1,075 ....$950 .......$825 .......$700
Vent. Rib .........$2,100 .$1,650 .....$1,225 ...$1,050 ....$875
Subtract 20% for front safety.
Subtract 20% for 2 9/16 in. chamber.
Posted on Jun 25, 2010
jyackle5
Jyackle5
  • 8197 Answers
SOURCE: I am requesting the value
May I get the make and serial # to help you more. You forgot to put that info in your question.
Posted on Oct 01, 2010
paultech8226
  • 109 Answers
SOURCE: Age of a Hobart Stand Mixer by Serial No.
the ML or spec number would be trackable from the resource site.
Enter the model number and check the date of the corresponding build number.
https://my.hobartcorp.com/resourcecenter/Pages/FilterByModel.aspx
If it does not have a safety cage fitted, there are some areas of the countyr where it can not be used commercially, untill one is fitted. Depending on the model, that would be a thousand dollars or more.
Posted on Mar 23, 2014
rhodesworks
  • 3157 Answers
SOURCE: What is age and value of a Vose & Sons antique piano?
We would need the serial number to get the age.Value will be dependent on various factors such as condition, location, etc
Posted on Oct 11, 2016
I have a Singer Sewing Machine with the Serial Number D1299909....what is it worth?
Try this for info:
Singer Sewing Machine Company Serial Numbers
Very difficult to give value because it depends on a lot of things--age, condition, rarity, accessories included, mechanically sound...
Apr 06, 2017 | Singer Sewing Machines
Hello...i have a black gibson les paul custom. Serial number 00117886. what year is it and would this be considered a black beauty? any idea of value too?
The term 'Black Beauty' has been well overused by now. It was originally the 1957 black Les Paul Custom model, but by now is any black Les Paul Custom. In addition Gibson themselves are cashing in by doing reissues, finished to look older.
So if it is a black Les Paul Custom, then yes, it is a Black Beauty, according to someone somewhere. On top of that, Gibson has reused serial numbers, in different years for different models.
If the serial number is stamped on the headstock with 'Made In USA' the guitar was made at the Kalamazoo or Nashville Plant, in 1976.
Those guitars are worth US$3000-4000 depending on condition.
Otherwise it was made at the Nashville Plant, TN, on January 11th, 2007.
Those newer reissue guitars sell for similar prices.
Feb 24, 2017 | Gibson Music
Oct 10, 2016 | Music
Value and age of Singer Sewing machine?
This may help:
If it is the K number, there were 20,000 machines made. So, the likelihood is that there are still a lot of them around. Value is very subjective based on several things including the physical and mechanical condition, accessories included, rarity of the model, etc. FWIW, it seems that the wood cabinets really don't appear to add much, if anything, to the value.
Oct 03, 2016 | Singer Sewing Machines
The approximate age and worth of a singer 99k28209
Try this:
Unless it is a rare machine, the value is probably not much as Singer made thousands of machines and, since they are such good machines, there are still many left in use.
Sep 28, 2016 | Singer Sewing Machines
Serial #3506979
any one of these sites will help you find the serial number and date of manufacturer. The forums will help with values, or the Blue Book of Gun Values.
  • Model 1894 (Mod 94 ) - Winchester Dates of Manufacture www.oldguns.net/sn_php/windateslookup.php?file=win1894.dat Winchester Model 1894 (Mod 94): Covering numbers: 1 - 5103249. Please enter a serial number and click the submit button.
  • Winchester Model 1894/94 Dates of Manufacture www.savage99.com/winchester1894_dates.htm Dates of Manufacture* for: Winchester Model 1894/94. Winchester Lever Action Repeating Firearms, Vol. 3, The Models of 1894 and 1895 by Arthur Pirkle.
  • Winchester Model 94 Serial Numbers - Gun Collections Online guncollectionsonline.com/winchestermodel94.htm 41 rows · Gun Collections Online. Specialists in Marketing Your Gun Collections ...
  • Related searches for winchester model 94 serial numbers
  • Serial Number info for Winchester Model 94 - The Firing ... https://thefiringline.com/forums/showthread.php?t=322230
    • 109 POSTS
    • FIRST POST: 2008-11-27
    2012-08-04 · I have a Winchester model 94 serial # 2775xx3. The chart in this thread for serial # id show a lapse between 64 and 65 models. The 65 models all start with ...
  • How can you find the age of a Winchester Model 94 - Answers www.answers.com > ... > Firearms > Winchester Firearms What is the age and value of a Winchester Model 94 serial number 3910875? ... What is the age of a Winchester model 94 serial no 1929746?
  • Winchester Model 94 Identification - 8's Garage 8sgarage.com/Armory/Rifle/Data/Manuals/Winchester 94 Identification... · PDF file Winchester Model 94 Identification PRE-64: The Winchester model 1894 was introduced in October of 1894 apparently starting at serial number 1.
  • What Is The Year And Value Of My Winchester Model 94 ... www.gunvaluesboard.com/what-is-the-year-and-value-of-my-winchester... What is the year and value of my Winchester model 94 serial number 5271797?
  • Value Of A Model 94 Winchester Rifle 30-30 Serial Number ... www.gunvaluesboard.com/value-of-a-model-94-winchester-rifle-30-30... also have 3 winchester model 94 32 specials all are in fair condition stocks are worn and bluing has light scratches serial numbers are 3133157...2822367...2889678 ...
  • Model 1894 ' Winchester Collector winchestercollector.org/models/model-1894 ... the Model 1894 became the first Winchester ... The 1,000,000th Model 94 was presented ... from serial number 1 thru 353999. The Winchester Model ...
  • Jul 19, 2016 | Winchester Model 94 Short Rifle .30-30 20...
    Chas f. Netzow upright piano Serial number 47686
    I should write this out to save me keep typing it. Remove the front of the piano and the lid for the keyboard. Remove the middle C key completely. You may find the manufacture date and its full service history written in pencil on the side of the key.
    Netzow Piano Co. Brand Name: Netzow Piano Co. Parent company: Netzow Piano Co. Location: Milwaukee, Wisconsin Serial Numbers Available: yes First date listed: 1904 Last date listed: 1931 Other brands:
    Answer
    Hi Robyn:
    serial 10305
    This was one of the original pianos made by this company in 1904. The serial number is the determining factor in telling a piano's age.
    The worth rests on the piano's viability, configuration, and age.
    Old uprights are generally worth little, especially if they are not serviceable. The furniture value is secondary.
    If your piano is in perfect condition, inside and out, the value would top out around 200.00, USD.
    What you have there is a typical upright piano, which more than likely has more furniture value than instrument value.
    Age is not good in the piano world and pianos deteriorate year by year whether they are played or not.
    Are you using this piece as furniture, or instrument?
    9k= 3 yearsy ago #3 jim H. Guest I have a Netzow upright #41459. What is the manufacture date?
    Made in 1913.
    Netzow Piano Serial 13072 What is its manufacture dat
    Feb 07, 2016 | Music
    Optics Logo
    122 people viewed this question
    Top Optics Experts
    Marvin
    Marvin
    ray gallant
    Are you an Optic Expert? Answer questions, earn points and help others
