Question about Honeywell Heating & Cooling
Honeywell pro series thermastat for coleman heatpump andd straight air stopped working when i unknowingly messed up thermastat settings. Yes, i have checked circuit breakers. Thank you.
Posted by Mary Loflin on
Paul G
    Scholar:
  • 161 Answers
Check the high and low limits on the stat
Posted on Apr 30, 2019
Allen
  • 31 Answers
Did you check the batteries too? And do you have the temperature settings right for each program?
Posted on Apr 29, 2019
5 Related Answers
Anonymous
SOURCE: AC fan not blowing/ Honeywell T87F thermastat
if you have a voltmeter that checks capacitance, check the capacitor ( silver looking battery) that is mounted on the side of the blower housing in the furnace. You need to take the wires off!! A bad Cap will slow down the fan and if its blown/dead the fan will not run.
If youre more than 1 MFD off the rating stamped on the capacitor, Replace it.
Posted on Jul 08, 2008
Anonymous
  • 85 Answers
SOURCE: ruud air to air heatpump
Make sure fan relay is wired correctly (G) wire. Ensure the fan on therm is not on, it should be on Auto or off.
If your furnace is short cycling because it has to keep heating your home, the delay in the control board may be staying on to compensate for the exchangers getting hot. If it heats normally, then put your attention to your thermostat.
Set the heating system on aux heat only. Fan should not be on, if it does stay on after a heating cycle, see if the furnace is heating normally, and reaching temp as desired before the heat comes off. Then check the therm wiring, pull the face of the therm, disconnect green wire (fan) and try the heating again.
Posted on Dec 06, 2008
Anonymous
  • 56 Answers
SOURCE: Went from Analog thermosat to
Look to see if you have it wired correctly with the o terminal be used and then check to see if you have a jumper wire between the Y and W terminal on the Base of the tstat where you hooked all the wires up.
Posted on Feb 14, 2009
Anonymous
  • 190 Answers
SOURCE: Dryer not generating heat and drying clothes...
Dear customer,
                We recommend you to do the following checks when your dryer isnt generating heat..
  1. Check for proper air flow
  2. Test the safety fuse
  3. Test the thermostats
  4. Test the centrifugal switch
  5. Test the timer motor
  6. Test the heating element.
Thank you.
Posted on May 09, 2009
Anonymous
SOURCE: Kitchen Aid Double Convection Oven blows circuit breaker
the kehc359jss mircowave won't start, it says "door" on the display but the door is closed.
Posted on Jun 13, 2009
How do I reset the temp my heat pump switches from electric to gas. It runs much more economically on electri than on propane. The thermostat is a Honeywell th8000. Code 350 setting I believe. Thanks
Heatpumps are more complex than an AC unit. Yes, there is a difference between a heatpump and an air conditioner. Where the real difference lies is out side in the condenser unit. There's a defrost board out in the unit, and depending on the brand and model, one of the wires will need to be changed so that the gas furnace will not come on. The problem with this, heatpumps use the heat that is available from the outdoors and transfers it to indoor. When the temps outside drop below 50 degrees, there's not enough latent heat to transfer, thus calling the propane furnace to operate. Without the addition of the furnace, you will not be able to heat the area properly. The only way to remedy this, is to remove the propane furnace and replace it with an electric airhandler with a heat strip for "emergency heat". The emergency heat term is used when the temps drop below the temps I mentioned above and calls for the heat strips to come on.
Feb 03, 2017 | Honeywell Heating & Cooling
Honeywell wifi thermastat 6980??
Try using the calendar and not the cakender set up. Just kidding make sure your press save after you change your settings. Also if that doesn't help doubt it will much try contacting Honeywell either by phone or web site they are very good at assisting contractors or homeowners with questions about a honeywell product.
Nov 22, 2014 | Honeywell Heating & Cooling
I have a Honeywell Focus pro Series 5000 Model Th5320U. How often should this thermostat cycle in an hour?
Hi, That depends....some on how you have it set up and some on how the building is responding to the unit....bottom line, I cannot give a definitive answer...
Here is a tip that tells you how to get a manual for most any Honeywell productonline...
Manual Honeywell How to Find Honeywell Manuals
heatman101
Aug 05, 2011 | Honeywell Heating & Cooling
How to set the day with the Honeywell vision pro TH800 series thermostat screen
Press the "system" button
Then press and hold the center blank button till the advanced functions menu comes up...
Then set the year, month, and date and the day will be correct
Check out pages 21 and 22 of this manual...
http://www.honeywell-thermostat.com/manuals/th8321u1006manual.pdf
heatman101
May 11, 2011 | Honeywell Heating & Cooling
What type of thermostat do I get for my goodman model GPG13420901AA? Can i use a honeywell digital one?
yes you can use a honeywell,certain types work...is it a heatpump or straight air unit...
Jun 09, 2010 | Goodman GPC1342H21A Air Conditioner
I put in a new honeywell thermastat my heat works but not my central air no power at all. when I turn it to cool will not even turn on air
What da ya got electric heat or gas heat? Did you buy the correct base for the thermostat? Who connected it? Honeywell is awesome but you need a pro to hook that sucka up.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 25, 2009 | Weather King 10AJA2501AH Air Conditioner
Honeywell HZ517 Electric Baseboard Heater not powering up
first.... did they work in the past?? if so... you may have a defective thermastat. if not, usually it is a incorrect wiring problem. wiring in two baseboard heaters to one thermastat can be tricky if you do not know what you are doing. baseboard heaters by design seldom go bad.... if wired correctly the problem could be a defective thermastat or safety limit switch.
Feb 09, 2009 | Honeywell HZ517 Baseboard Heater
Manual Thermostat replcaement with Programmable Digital unit.
Hopefully there are markings on the old t-stat as to what terminal is what.
on the honeywell 8000 use the heat pump labeling and then the standard wiring would be
R- red
AUX-white
Y- yellow
B- O/B
C- black
G- green
There should not be a bare wire, it probably just has the insulation stripped back way too far.
You should probably open the furnace and compare the terminal label in the furnace to the wire color. normally yellow and blue pass through the furnace and are wire nutted to wires going to the outdoor unit. In the furnace the white wire will connect to the w or w1 terminal. also, you will need to set the Honeywell stat to have the following parameters.
170-7
190-1
200-0
other parameters that I did not specify, you may read the manual and make your own decision but I recommend factory settings for the other parameters
Jun 14, 2008 | Ruud UBHC Air Conditioner
Heating & Cooling Logo
47 people viewed this question
Top Honeywell Heating & Cooling Experts
Paul Carew
Sean
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
