SOURCE: machine error E04-01
error e04-01 means fuser warm up temperature
problems could be
-fuser thermister dirty ir defective
-fuser lamp is disconnected or defective
-fuser thermostat is defective
SOURCE: My Panasonic DP-2330 .... Is Showing Error Code E04-02
How enter to service mode in panasonic DP2330 copier.
SOURCE: Danby dpac120068 blue light flashing
E04 refers to Overheating. There might be plenty of reasons. You might have seen, if you shut down the ac for few minutes and again start it, It would work for few minutes and the same E04 display is there.
This is tech's job. I am sorry, i am not discouraging you but it requires certain testing that actually what makes ac overheated.
This is dangerous. So, better to call a tech and get it checked!!
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
SOURCE: GOT A AUTOSHOT 200X CC6363 THAT EVERY TIME YOU
E04 - Battery in Safeguard mode.
The most common problem with this kind of model. there actually no fix for this problem. Unless of course your a jvc technician and can manage to open and clean all the sensor inside.
Have you tried to most popular solution for that.. tapping a little bit on the side of that camera. lol.
Look closely with the memory card, make sure it is inserted properly. push it a little more.
You may need to remove the battery from the battery pack and then reinsert again before turning it on. Doing it a few times may help solve the problem.
I do suggest you remove the battery when not in use. Leaving the battery inside is the usual cause for having the E04 when turning it on.
Hope this helps.
Mace1Mace
