Question about Home
How do I get this valve out of here. Goes to a garden tub handle. Any help is appreciated
Posted by Kennie montgomery on
ray gallant
    Top Expert:
  • Home Master
  • 68,645 Answers
TURN ON THE WATER PRESSURE WILL PUSH IT OUT
Posted on Apr 28, 2019
1 Related Answer
Anonymous
  • 11 Answers
SOURCE: Compatible replacement handles for Moen Garden Tub faucet
I dont know if moen made chrome handles for that valve back then. If they did then they will probably be lever handles but they wont turn correctly unless you remove the cartridges and turn them. Iwould suggest probably replacing the whole unit.
Posted on May 07, 2009
Replace handle with different style
One of those big-box home suppliers might have something you can use or can order something. Likewise, a plumbing supplier could have just what you are looking for. Moen is a common brand which makes compatibility more likely
Feb 09, 2013 | Moen T999P Chateau Two-Handle Low Arc...
When i'm filling the tub with water, the water back feeds up to the shower head and sprays out. I changed the spout and also moved the shower knob to make sure it wasn't stuck in the up position for the...
You will have water coming out of the shower head when you have really good water pressure. There might be more water volume coming out through the valve then what the tub spout can handle and in turn sends the water up to your shower head. When you fill your tub try turning the water only half way on not at full pressure, does this keep the water from coming out of the shower head? Most likely your valve has a 3/4" supply line while your shower head and tub have only a 1/2" supply line. Sounds like you have more volume to the valve than what the tub spout can handle. You might consider one of two things: 1) you can put a water regulator on the main supply line going into the house to lower your pressure, or 2) change out the supply line to the tub spout, increasing it from 1/2" to 3/4". Let me know whats going on.
Dec 03, 2010 | Delta Home
Installed new valve but when I screw the handle in I can't shut the water off completely. I can pull and turn the water on but when i push it in, it only turns off part of the way. To shut it off i have to...
On most moen single handle valves there is a washer that is supposed to fit over stem on cartridge.This washer has two flat sides to fit over flats on stem. The only other thing I can think of is that your valve face plate is mounted a little to far out and won't let back of handle go all the way closed. I would try tightening the two screws that secure face plate to valve a little and see if that helps. Good luck. Thanks
Nov 18, 2010 | Moen & One Handle Tub & Shower Faucet
When I turn the knob that directs the water from the tub faucet to the shower, half of the water goes to the shower head, and the rest still goes out of the faucet to the tub. How do I get the water to go...
just like the shut off valves, the washers need to be replaced on the "third" handle. sometimes you will need to replace the "seat" as well. this requires a special tool to remove.
you will have to remove the handle and trim, and remove the valve stem.
if you can't remove, or don't feel comfortable, call a handyman. should only take about 20 minutes to replace all the washers. be sure check the "seats" too.
Aug 30, 2010 | Home
Only warm water from the tub/shower
You can cap the lines at the tub faucet to rule out tub faucet. It maybe mixing there.
Faucet may be bad also the safety stop will alow you to change water temp it can be tricky to adjust water temp.
May 02, 2010 | Moen 1 Handle Lever Shower Faucet With...
My shower/bath control just turns and the water the does not turn on.It initially was dripping constantly then stopped working completely. (Moen)
sounds like the cartridge is stripped where it goes into the handle. If it is not coming on at all from either the hot or the cold....I would say there is a blockage inside the valve body.
Oct 21, 2009 | Moen 2919 Chateau Two Handle Tub and...
Apr 20, 2009 | Moen Chateau, Two-Handle Garden Tub Faucet...
Not able to pull up the shower valve
The valve is in upside down. Sounds like the shower head runs all the time and thats what fills the tub? The valve needs to be flipped OR the diverter in the valve needs to be switched to the other side of the valve. If this is a one handled valve it is installed upside down. UP is indicated on the valve.
The valve can be reused just turned over.
Dec 13, 2008 | Moen 2919 Chateau Two Handle Tub and...
Handle Removal on Chateau Style Bathroom Taps
the handle removal is a metric allen wrench some of the cartridge replacements come with an allen head wrench
I always plug the drains and completely remove the allen head screw then the handle comes off
Sometimes you have to pry it gently or take a hammer wrap a towel around the handle where it meets tthe cartridge base and tap up under the handle lightly and it comes out
God Luck
Nov 28, 2008 | Moen Chateau, Two-Handle Garden Tub Faucet...
Moen single tub shower handle insatll
The valve has a faceplate that attaches with two screws and depicts the hot and cold mixing scheme on it. in the center of this is where the valve stem is located. It has a chrome escutcheon that slides into the faceplate and over the stem.There is a small -U- schaped clip that slides into the top of the valve body where the valve stem is seated that retains the valve stem. With all this in place all you have left is the acylic handle that has a unique shape to it on the internal portion that corresponds to the shape and position of the valve stm. Align the handle and stem and push the handle on. A small screw goes into the center of the handle to attach it to the valve stem. LASTLY you should have the acrylic button that covers the screw holding the handle on. All you do is align it appropriately and push the button onto the handle. The chrome handle version is essentially the same but is retained by a small allen screw on the underside of the base of the handle. I hope this assists you and thanks for using Fix Ya. Please let me know if I can be of further assistance.
Oct 22, 2008 | Moen 3175 Legend One Handle Shower Faucet...
Home Logo
125 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
