Question about Home
Aeromax tub some jets not blowing air - Home
Posted by Claude Ostiguy on
NOEL
    Top Expert:
  • 8,546 Answers
Hi Claude.
If your spa jets appear to be pulsating or pausing, first check to make sure your filter isnot clogged. If your filter appears to be okay, you should next take a look at your hot tub's water level. If there is too little water, air could be working its way into the system through the jets.
Why are My Hot Tub Jets Not Working? ' Master Spa Parts
How to Replace Water Jets in a Hot Tub
  1. Turn off your hot tub. ...
  2. Reach into the tub and grasp the outside edge of the damaged water jet. ...
  3. Place your water jet face down on a level surface. ...
  4. Line up the notched tab on the back of the jet with the groove inside the jet housing. ...
  5. Turn on your hot tub.
  6. Things You Will Need. ...
  7. References (3) ...
  8. About the Author.
How to Replace Water Jets in a Hot Tub ' Home Guides ' SF Gate
How To Clean Bathtub Jets with Basic Household Ingredients
  1. Fill the tub until the jets are covered by 2-3 inches of hot water.
  2. Add 2 Tablespoons of a low-sudsing dishwashing liquid and 1/2 cup of bleach. ...
  3. Run the tub's jets for 15 minutes.
  4. Empty the tub, and refill it (cold water is fine this time). ...
  5. Drain the tub and rinse it well to get the gunk off.
More items...
4 Sep 2014
How To Clean Bathtub Jets with Basic Household Ingredients ...
or read up more at this link.
https://www.google.com/search?q=Aeromax+tub+some+jets+not+blowing+air&rlz=1C1AVFC_enGB797GB798&oq=Aeromax+tub+some+jets+not+blowing+air&aqs=chrome..69i57.7532j0j9&sourceid=chrome&ie=UTF-8
Posted on Apr 28, 2019
The jets on my aker Swirlbath are coming on by themselves in the middle of the night. What is the remedy for this problem?
Some tubs with air jets have a sensor that detects water in the piping and cycles the air pump to blow out the water in the air jets. Make sure the faucet is not dripping as the water leaking into the tub could be causing the pump cycling problem.
Hope this helps.
Bob
Aug 11, 2014 | Home
Jets not working
Check your breaker in the breaker box. Is this an air tub or a water tub?
Nov 10, 2013 | Neptune Home
I have a Neptune air tub and the motor turns on when I press on but the air is not coming out of the jets. The tub does not have an air knob
So you can hear the air blower turn on however there are no little bubbles coming out of the air injectors...
I would have you verify that the blower is blowing air out. Either the hose has come off and it is blowing air under the tub or the fan has disengaged itself from the motor and is not turning.
I will ask you to verify that one of those two things has happened or possibly the check valve in your system is closed and will not open.
US Parts Center
Nov 10, 2013 | Neptune DB60TAM Whirlpools and Air Tubs
Kohler led lighting and jacuzzi motor + jets stopped working but automatic line clearing air still blows when tub is emptied.
Air Switch Repair
It sounds like you have a bad air switch located in your motor.
The air switch is what the air hose connects to on the back of the motor or on the box on top of the motor. The other end of the air hose is connected to the air button on the lip of the tub.
This is a latching air switch and when you push the air button it latches to send power to the motor. When the air button is pushed again it opens the latch in the air switch and stops power going to the motor shutting it off.
US Parts Center
Bath Spa Replacement Parts Hot Tub Bath Parts Accessories US Parts...
Oct 06, 2013 | Kohler Home
Aqualux whirlpool tub how do I clean jets?
Try and blow the lines out with air, sounds like something is stuffing the water jet. Drain system and turn off power first.
Nov 02, 2012 | Jacuzzi EH0 / EH1 / EG9 Fuzion 6666 Corner...
Our "whirlpool" tub jets do
sounds like it may be either the air button or the air switch (on motor).
pull the pump and plug into an outlet. take a straw and blow into the air switch where the air tubing was connected. If the pump comes on then you know the button. If the pump doesn't come on then you will need to replace the air switch on the back of the motor.
Feb 07, 2011 | Home
Water coming out of adjustable air vent behind wall of tub
one or more of the jets are turned off. i would suspect someone is plugging the jets off which causes water to go backwards in the system and the water goes out the air controls. solution: check the jets to make sure the jet faces are turned on and/or tell someone to quit plugging off the jets when they are in the tub.
Mar 03, 2010 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Can not get the jets to work
Most of the control buttons on a tub are not electrical. These buttons are connected to an air line that runs to the motor. Sometimes an aggressive button push can literally blow the air line right off of the bottom of the button.
This problem is as easy to fix as it sounds. Find the loose air line and push it back onto the button. You will need to open up your access panel. Bring a flashlight.
Be sure to check the connection at the motor too. Good luck
Dec 02, 2009 | Home
Cold air coming from jets in a large garden tub indoors
jets pull outside air in thru the water jet in a natural Venturi action. If you are referring to the air bubbles in a bathtub then, yes there are air blowers that have heaters inside them to warm the air before if goes into the tub.
Feb 20, 2009 | Home
Home Logo
123 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
