Question about Wolverine Computers & Internet
What is the type of the USB port of my Wolverine 2100 100 GB
Posted by Duong Dang on
Stan Naramore
    Guru:
  • Wolverine Master
  • 531 Answers
what is the type of the USB port of my Wolverine 2 - 1-fywiog52uc2ssdn5xk2mhim4-2-0_1.jpg USB 2.0
Posted on Apr 28, 2019
The USB icon appears; but, cannot access the drive at all. Does not show up as one of the drives. Suspect the drive is toast. Can the drive in the box be replaced with another IDE drive? If so, is...
The Wolverine is a high-speed drive, so try also connecting it to an externally powered "dumb" USB hub. HS spindles may require a slightly higher current and the USB port may not supply it properly.
I have not been able to find the Wolverine's internal HD specs, but the device was reviewed in 2003 and at that date most 2.5" disks were EIDE. While some EIDE drives did have a limitation of 137 Gb of addressable space, this was mostly solved even in embedded chipsets (such as Cypress) by 2003.
So, my guess is that with all probability you can place any EIDE 2.5" drive in the enclosure; if I'm wrong (I think not), the drive will still work and you'll have to repartition it, to only access its first 137 Gb.
Let me know how it goes.
Mar 14, 2010 | Wolverine (3120) 120 GB Hard Drive
Seeking a power supply, User Guide, and USB cable for Wolverine 2020 20GB drive
Your best place to get your needs is from the company you originally bought the hard drive from.
Hope this helps!
Feb 04, 2010 | Wolverine Data (2020) 20 GB Hard Drive
Wolverine 7000 says HD Failed and is now frozen
get latest firmware:http://www.wolverinedata.com/index.php/site/pages/support/ then reformat using: use http://dl.dropbox.com/u/4040651/HPUSBFW_2.2.3_MASTER.exe
Dec 20, 2009 | Wolverine FlashPac 7000 120 GB USB 2.0...
Cannot turn unit off. Green light on, unit running continually. After downloading my 1.0 GB memory card into the Wolverine, I removed the card (and Sony Duo adaptor). When I tried to turn off the unit, it...
DID YOU USE THE RESET BUTTON ON THE SIDE? Put a paper clip into the reset button. also to read larger cards: get latest firmware:http://www.wolverinedata.com/index.php/site/pages/support/ then reformat using: use http://dl.dropbox.com/u/4040651/HPUSBFW_2.2.3_MASTER.exeReply
Aug 16, 2009 | Wolverine FlashPac 7000 120 GB USB 2.0...
Not enougn power
The limitation is actually imposed by the circuitry of the PC as supplied to the individual USB ports.  What you probably need is an externally powered USB HUB.  You will have to determine how much current your drive draws. An example of a max 1 Amp @ 2X500ma/Port is "7-port USB 2.0 hub" [AP-HUB207]. You can check out the specs here > http://www.mittoni.com.au/usb-20-powered-7port-hub-p-1920.html
Hope this be of some help/idea. Post back should you need additional information.
Good luck and kind regards.
Oct 20, 2007 | Wolverine (2100) 100 GB Hard Drive
S1 mp3 player
USB port woring but the player mode is not being detected. pease advise the solution. Ashok
Sep 13, 2007 | Wolverine S1000 (1 GB) MP3 Player
Computers & Internet Logo
Top Wolverine Computers & Internet Experts
Ekse
Marvin
Marvin
Are you a Wolverine Computer and Internet Expert? Answer questions, earn points and help others
