Question about Watches
My yoho sport fitness watch isnt Holding charge what can I do. Please help
Posted by Mary Harrison on
Can a cloth "sport type" watch band be used on a
mcdevito75 here, As lomg as the watch band, no matter it"s material fits the watch lugs and your wrist, any band can be used. Your answer is yes.
Feb 09, 2011 | Casio Pathfinder AltimeterBarometer...
How do I turn off the alarm on my Armitron watch?
I don't know whether this is what you are looking for, as the watch comes with no packaged instructions OR general support, on their website, XD,
Nik.
http://home.earthlink.net/~eldonenew/armitron.htm
or
http://www.ehow.com/way_5786808_armitron-all_sport-watch-instructions.html
Armitron All-Sport Watch Instructions By Brian Walker eHow Contributor 9 Found This Helpful The Armitron All-Sport is a unisex style of watch made by Armitron that features a digital readout and four buttons around the outer dial for adjusting various aspects of the watch. It can set alarms, keeps the time as well as the date, and has a built-in backlight. Accessing and adjusting these various settings is a fairly simple process.
Other People Are Reading
Setting Date, Time and Alarm
  • To enter the date and time setting mode, press and hold the "mode" button, located on the top-left of the watch. Continue holding this button until the display begins to flash. This first display is the alarm setting, should you choose to set an alarm to go off. If you'd like to set the alarm, use the "alarm" button on the bottom-right of the watch to advance the hours to the desired one. Then press the mode button again; this will cycle through the minutes and seconds of the alarm to allow you to set those as well. Once you have set the alarm, you can press the "date" button at the top-right of the watch to proceed to the regular time setting. These numbers, which will now be flashing, also are adjusted by pressing the alarm button to change them. Pressing the date button again will now cycle through the hours, minutes, seconds and the date. As you continue to press the date button, the All-Sport will continuously cycle through these options; don't worry if you forget to set one, you can simply press the date button a few times until you get back to the setting you need to change. Once the alarm, time and date have all been set, you can press the mode button one more time to exit to the normal watch mode that will display the date and time.
Using Chime and Alarm
  • The Armitron All-Sport features both an alarm and an hourly chime. The alarm function will cause the watch to continuously beep at the selected time until you turn it off by pressing a button. The chime will cause the watch to beep once every hour. You can turn both these features on and off by pressing and holding the alarm button and while holding it pressing the date button. The first time you do this, the chime will turn on and a small house symbol will be displayed on the watch face. Performing this button-pressing sequence again will turn on the alarm, which in turn displays a small clock icon on the watch face. Each successive pressing of this button sequence will alternate between the chime and the alarm, turning them either on or off.
Backlight
  • The All-Sport also features a built-in backlight to help you view the watch in dark conditions. This light can be activated by pressing the "light" button on the bottom-left of the watch. Pressing this button is the only way to activate the light, and doing so will only cause the watch to illuminate for a few seconds at a time.
Read more : http://www.ehow.com/way_5786808_armitron-all_sport-watch-instructions.html
Jul 20, 2010 | Armitron Round Digital Sport 408089 Watch
Find a replacement battery CR161
These batteries are available in any high street.
Take your watch to a jewlery / watch selling shop and ask for them to fit a new battery they usually only charge for the battery.
Feb 21, 2010 | Columbia All Sport Digital watch
Timex WR 100 M Model. Sports watch. Need new strap
Not getting any help as promised; just hits to make me pay money. Please cease & desist. I want no further mail from you. I thought it was a friendly chat line to offer advice. It's not. Go away!
Feb 01, 2010 | Timex Watches
This watch comes with a Birthday Alert feature, I believe. How does one set the day of the birthday? Mine went off at 1:00 a.m. on 1/1...not my birthday! Thanks for the help
Go to the "Amitron" web site.
Select "support"
Select "watch instructions"
Scroll down illustrations to find the one that fits your model and download instructions.
Jan 02, 2010 | Armitron Digital Sport #40/8132BLK Watch...
What is the purpose of the rotating bezel on the Callaway CY2058? It has no markings, which it needs to be useful.
If you have no markings on bezel there is no practical use for this feature.
Bezels with markings are used as a tachymeter (for calculating speed of the moving object) or as a countdown timer for sporting events or diving.
In your case bezel is becoming loose and thats why it is turning as I can't see the point why the watch should be fitted with rotating bezel with no markings on it.
Rate me, please.
Jul 31, 2009 | Callaway CY2058 Sport Series Watch
Can't get back on watch
Some of the watch casebacks need a special tool (little press) to fit it back as human finger strength is not enough to close it back.
You need to find your nearest watch repair shop and ask for help. It is quick and easy operation, but without this tool allmost impossible.
Do not try to use any inappropriate tools (such as a hammer or similar) to force caseback back on as you can easily damage watch case, caseback or even movement.
Do not forget to rate, please.
Jan 12, 2009 | JCPenney Armitron Sport Link Bracelet...
Ks-100 sports watch
Here is the form used to contact lacrosse for a watchband; http://www.lacrossetechnology.com/watchband_form.pdf or you can use; http://www.lacrossetechnology.com/support/contact.php Here is the user guide for your watch if you need it; http://www.lacrossetechnology.com/k2100/manual.pdf Hope this helps :)
Dec 10, 2006 | La Crosse K2-100 Wrist Watch
Watches Logo
160 people viewed this question
Top Watches Experts
Janelle Schoonover
Janelle Schoonover
Bruce Robin
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
