Question about Mercury Boating
Is there a oil filter on a 2009 90hp 2stroke mercury optimax
Posted by Jack vernon on
4 Related Answers
dttech
dttech
  • 4803 Answers
SOURCE: how do you change the gas filter on a 2007 115hp optimax mercury
The only way to do that is to replace the fuel pump module assembly in the fuel tank. The filter is built into the module.
Posted on Apr 14, 2012
steve
  • 3709 Answers
SOURCE: 2003 Mercury Optimax 225 hp. BEEPING than
sounds like a relay or other electrical device is noisy , only way to find out is to strip out instrument panel and try to locate the 'noisey' item, a good place to start is the fuel gauge as they have a resistor build in and they can cause a buzzing when the are getting worn out , fault finding at it's best , good luck and take your time and be patient and keep me posted if you wish
Posted on Jun 09, 2014
Fabrice Wolters
  • 331 Answers
SOURCE: 75 2 stroke mercury optimax motor problems
4 beeps every 2 minutes has 2 causes:
1) LOW oil level in the engine mounted reserve tank ( fill it up manually )
2) Water in the engine mounted water separator/fuel filter ( clean out )
Posted on Jun 15, 2014
  • 18520 Answers
SOURCE: 2011 Mercury optimax. At 3500rpm alarm goes off and goes in guardian mode. Water pump and pressure good. Oil level is good. Oil pump working correctly. Changed internal pressure regulator. Any advice?
This could be a lot of things. Have a computer scan done to see what the issue is. Could be a bad poppet or water pump. There is a sensor in the oil tank that can cause this too. Also the throttle sensor.
Posted on Apr 27, 2018
Testimonial: "Thanks for the info, I'll try these suggestions tomorrow!"
Mercury 150hp Optimax outboard
many mercury motors use a rubber mounted prop on the shaft which is a sacrificial idea to prevent gear box damage and prop damage in with under water objects
what you suggests indicates that at certain load situations that rubber has failed and allowing the shaft to turn but is not driving the prop as required
It is driving just enough to give you steerage to get home
Sep 01, 2018 | Boating
Apr 27, 2018 | Mercury Cars & Trucks
150 mercury starts sputtering after its been running for a few minutes but won't die.
Check for clogged fuel filter(s) and/or a bend fuel hose.
Check also for a good cooling pf the compressor. The pilot water jet must be a strong water flow!
Mar 07, 2015 | Boating
Outboard problems
It sounds like your high speed jet needs adjustment.
Aug 01, 2014 | Mercury Appliances Mercury 2-Stroke...
Jun 10, 2014 | Boating
Temperature of 2008 75hp Mercury optimax
You may be able to find the best answer on the Mercury Outboard Forum.
May 28, 2013 | Boating
How do you change the gas filter on a 2007 115hp optimax mercury
Apr 13, 2012 | Cars & Trucks
Boating Logo
141 people viewed this question
Top Mercury Boating Experts
Mike
ray gallant
john h
Are you a Mercury Boating Expert? Answer questions, earn points and help others
