SOURCE: dishlex dishwasher global 300
Its in flood mode you need to get into the base and soak up the water from the flood switch (front middle),then it will restart,but you may have a leak or just dirt buildup under the lower door seal
SOURCE: dishlex global dishwasher, stuck on
Try turning the taps on harder, I read that someone else had the same problem and this fixed it for them.
SOURCE: why is my dishwasher flashing on the eco 45 button
This doe seem that the anti flood system has triggered. This device puts the machiene in pump out mode and shuts off the input water supply.
The device is a safety device that triggers once it detects a water leak (pipe / clamp) and consists of a polystireene float and micro switch at the floor of the washer. First check to see if the float has activated the micro switch and then dry the machiene floor and check for leaks.
SOURCE: Hi there, we have had
Hi just read your posting.Now the reason these dishwashers flash ECO is because there is either water in the bottom tray or your drain pump is open circuit.Is the machine making a pumping noise when it is flashing the ECO light,or is it completely silent?Please reply on additional information and I am sure I can help you.Looking forward to your reply.
Testimonial: "Excellent! Got back to me within 12 hours.. Very helpful"
