Question about Hotpoint Washing Machines
Aquarius hotpoint wmf740 flashing f09. What is it
Posted by Sarah Edwards on
5 Related Answers
macgivor
  • 234 Answers
SOURCE: hotpoint Aquarius model number WF340P all lights are flashing
First, you need to stop the power to the appliance and wait 2 minutes before re-energizing; this many times resets the logic board and removes crazy actions. 2nd, are all the lights flashing continuously or are they flashing several times then pausing and flashing they same several times again? If they flash nonstop, this may indicate a control board failure. If they flash a certain number of times, this would indicate a fault occurance at some item in the appliance. Your owners manual would usually show this list of flash codes in the trouble shoot section. If you do not have a manual , Call GE (general-electric) and ask to have a manual sent to you; you could also ask about the flash code meaning since this is becoming a more and more prevelant problem and manufactures have been educating their phone help people to know some of these standard answers.
Good luck, Macgivor
Posted on Oct 14, 2009
barkencoa
Barry Coates
  • 3463 Answers
SOURCE: Error message F-01 & flashing lights etc
Error code F01 indicates a short circuit motor triac.
You need to check connections on the motor, the motor plug and the module.
Having said that, you really should ring the manufacture, as the washer is still obviously under guarantee, and should be fixed at no cost to you.
The point to bear in mind is that if you do anything to it yourself, then in theory, you could invalidate the guarantee.
So, unless it is anything obvious, then I would advise you ring the manufacturer.
Hope this is of assistance to you.
Please rate my solution.
Thankyou.
Posted on Dec 21, 2009
Anonymous
  • 110 Answers
SOURCE: The machine won't start as saying door isn't
1.the door may be worn at the point it presses the switch at 2.the door switch may be wired incorrectly 3.the door switch may be worn out and needs to be replaced
Posted on Mar 06, 2010
miket756
Michael Thorpe
  • 2702 Answers
SOURCE: Hotpoint aquarius WMF740 (1 year old) - noisey spin
its the drum bearings there worn out try opening the door and lifting the top of the drum with your fingers if there is any life and the drum drops back when you let it go its them bearings,, then spin the drum by hand is should grumble or growl,,,if it dont do any of this, it could be the "spider" broken off, its an ally part that holds the drum bearings and the drum up,
Posted on Mar 07, 2010
Daniel S
Daniel Scott
  • 4323 Answers
SOURCE: hi got hotpoint aquarious wmf740.
Hi
Error F5 means that the pressure switch is jammed on full. This may have happened due to blockage or obstruction in drain hose. To be sure check whether hose is plugged, if not then remove lower rear panel of the washer.
Now you would be able to see drain pump and a large black hose on bottom of drum. Remove the hose from the pump; remember to keep a container near you to collect the water from the filter/pump. Remove and clean the drain filter connected with the pump and hose. Clean the pump and let it dry for a while. Now restart the washer after 2-5 minutes and your issue would be resolved. Please post back for further assistance. Hope this helps...
Daniel
Posted on Aug 30, 2010
H0w do I clean the machine
put it on rinse add cup of bleach
Oct 06, 2014 | Hotpoint Washing Machines
Hotpoint aquarius wmf 740 has error code h20
Just had same problem with my hotpoint wmf740 showing h20 and found an easy fix was to clean out the detergent draw thoroughly and just behind it.to remove tray was easy and it does say to do this regulary in the manual
Jul 16, 2012 | Hotpoint Ultima WF860 Front Load Washer
Hi i have a Hotpoint WMF740 Aquarius washing machine which had a F-05 error which i have hopefully fixed. now the lcd display is saying f-09 error what do i need to do now.
For the F05 presumably you found and cleared/cleaned the drain filter ;-0)
F09 is rather a more difficult problem as it decodes as an 'incorrect or faulty EEPROM'. I presume you have tried disconnecting power and reconnecting again? If you have I'm afraid it will need an engineer to fix ;-0( Sorry, John C
Mar 20, 2011 | Washing Machines
My aquarius wmf740 has a blockage cannot undo the white water release valve on front bottom right hand side of washer to solve problem. Any help grateful.
tip machine right back and unscrew valve. It is probably caught on something. Hope this helps ( I had a kirby stuck in mine)
Audrey
May 21, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Mar 07, 2010 | Washing Machines
Mar 06, 2010 | Washing Machines
WD420, drying high heat, time saver and ON/OFF buttons are flashing, no function out of machine at all
this usually means that the main pcb has a corrupted eprom or eprom memory has been wiped... you either need a new pcb with eprom or a new board pre-programmed.
hotpoints terms for error
Setup error: check eeprom
F09
Flash
OFF
OFF
Flash
OFF
Dec 18, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Washing Machines Logo
80 people viewed this question
Top Hotpoint Washing Machines Experts
gbob59
Eric Taylor
Richard C Cohen
Richard C Cohen
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
