Question about Blaupunkt Televison & Video
My blaupunkt TV 40 inch model no: sty0640. When I switch my TV on it starts flashing red and blue and my input source is running up and down. The whole time I lost my remote what could be the problem. Or what must I do??? Please
Posted by Adolf on
antoniorojas
    Dedicated:
    Visited the website for 20 consecutive days.
  • 280 Answers
Remove all input cables now switch on your tv after on press menu and go setting display next restore it
if it was succesfull youre done
Posted on Apr 27, 2019
5 Related Answers
Anonymous
  • 579 Answers
SOURCE: 40 inch lcd blue line vertical
The display screen is made of a matrix of elements connected to cables along the side and top. On your unit, some of these many, tiny connections are making contact intermittantly thus losing the elements in that area. These contacts are held in place with just pressure and if that is disturbed, you lose that line of elements. Try squeezing the cabinet of the TV on the outside at the top in the area of the loss and see if that makes a difference. May have to go inside and see if the contact assembly is disturbed or warped or something.
Hope ya fix it!
Posted on Jan 06, 2008
ctf1800
Cary Farah
  • 4402 Answers
SOURCE: jvc 52 inch hd-ila hdtv widescreen
you have a bad lamp or balast
Posted on Jan 22, 2008
salsaurbana
Luis Rondon
  • 56 Answers
SOURCE: mintex 37 inch wide screen. remote is working however cannot change channel, input source or volum. only turns tv off. The buttone on tv doesnot work connot change input source or volume
Check if the remote is in TV position, that is, because most of the remote controllers have the feature that you can program them for use with another devices. Make shure that one button that says "TV" in pressed and released once before you try to change any function on the TV.
Posted on Nov 20, 2008
Anonymous
SOURCE: lg-ru44sz63d
Same thing happened with mine, I unplugged it and plugged in back in and now it works - hopefully for a little while longer
Posted on Jan 07, 2009
jaime vargas
  • 476 Answers
SOURCE: cannot change input source for tv
i would try the abvious first, unplugg the tv from the ac outlet and wait for a few seconds then try turning tv on see if the problem is solved, if not it might be that the key board panel needs replacing.
Posted on Aug 02, 2009
Can a symphonic TV model WF203 be put in video mode without a remote
Only if you have a source button on the tv itself. On many of the newer sets you have to have the remote to access your other inputs. Without the remote, nada. And forget universal remotes - they only provide for the most basic functions and video source is not one of them. And you get hosed on original remotes.
Sep 25, 2015 | Symphonic Televison & Video
Reset a sceptre tv
Hello
enter the Menu screen, slect Setup, select 'Advanced Selection" go to 'Service 1' ; select 'Restore Defaults' nd press 'enter'. User "Up' 'Dn" and " > " & "< " keys on the remote control to select these options.
http://www.dataentryjobs.us/67948.html
Feb 12, 2012 | Sceptre X370BV-HD TV
II HAVE A 13 INCH BRAND MODEL DWT 1304. I JUST WANT TO USE IT FOR A DVD PLAYER. I HAVE NO REMOTE ,HOW DO I CHANGE THE TV TO PLAY DVD OR VEDIO
Connect the composite video RCA (yellow) cable output of the DVD player to the TV's video input RCA (yellow jack). Connect the red and white RCA cable from the DVD players audio output to the TV's audio input (red and white jacks). Select the source input from the TV's control panel - if it has an input selector switch, set it to select the video source from the front panel input jacks if you connected the three cables - yellow, red and white on the front of the set. Or, change the channel to receive the video auxiliary input source instead of the broadcast station.
Dec 20, 2010 | Durabrand DWT1304 13" TV
Blaupunkt GmbH 12,1" lcd monitor in bus have 4 wires; one is black and it's ground but yellow, red and blue, wher is go?
black usually is ground the red is positive and the yellow is a constint power source that always stays on for memory and the other is blue and that is for remote. meaning a wire that is positive and only turns on with a stereo switch or a switch power now the red is a constant power to really coming from the battery and this is if these wires are power wires if not. if they are video then email me back and ill get back at you thanks nothing in wirs i cant figure or learn to. jokerstats
Apr 27, 2010 | Blaupunkt IVMR-1042 10.4" TFT Roof Mount...
TV doesn't turn on, three lights (blue, red, red) goes thru the normal start up, but stops with red lamp light on.
my samsung lcd 40 inches.power on blink contineoisly when we switch on LCD KIND GIVE SUGESTIONS
THANK U
BAKSHI
[email protected]
Nov 14, 2009 | Hitachi 50VG825 50 in. LCD HDTV
RED COLOR NOT coming on TV, showing green all over place
I also have a samsung 40 inch. Try hitting the menu button on the remote the scrolling over to the right once and scroll down and hit pictures reset to see if that works. If it doesn't check your connections coming from the back of the source and the tv itself.
Sep 03, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Component video signal between KLH DVD8350 & Vizio 32" PlasmaHDTV
If the Visio TV has more than one input, don't forget to use its remote to make sure the correct input is selected. It probably wouldn't hurt to put a DVD into the player, confirm its running from the front panel counters) and let it keep running as you troubleshoot. At least then you'll know there is an active video source once you find it. Another thing you can try is to put in a music CD, if the player accepts these too (most do). Then when you get the TV set to the right input, at least you'll hear music, and can then go back to trying a DVD.
I know you're using component video, so remember that unlike HDMI devices, the TV is unable to switch to the correct source automatically. So it may just be that you've never had to switch the TV's input source before. Good luck! :-)
Jun 02, 2017 | KLH DVD8350 DVD Player
Problem with tv
Pretty typical for lamp life. Buy a new bulb (not the whole lamp assy) from us (sedonix.com) or one of the many bulb sources on the net, install it yourself and save a lot.
Dec 31, 2007 | Televison & Video
Televison & Video Logo
61 people viewed this question
Top Blaupunkt Televison & Video Experts
Marvin
Marvin
Vernon Taylor
Andrew Taylor
Andrew Taylor
Are you a Blaupunkt Televison and Video Expert? Answer questions, earn points and help others
