Question about Radio Communications
I have got a Vibe E ssencial ultra slim bluetooth headset but its microphone is working only when you bring it close to your mouth and sometimes thats also not working. and if i use it like this, how will i be able to hear what the other person is saying as the microphone will be on my mouth and the speakr not in my ear.. any solutioons?
Posted by Saad Salman on
sadiq muhammad
    Champion:
  • Radio Commun... Expert
  • 228 Answers
Change the microphone of bluetooth head set.
Posted on May 23, 2019
5 Related Answers
Anonymous
SOURCE: Motorola HS850 Bluetooth
Whats most likely wrong with your HS850 is the connect button on the front of the headset (the larger oval chrome one with an inlay of a traditional phone handset on it)is stuck down. To repair this you will hold the hand set and pull up on lanyard attach point firmly. (This facia is held on by double sided tape). After pulling the facia you need to purchase or borrow a T-6 Torx bit to remove the screw that holds the headset together. Once you get to the circuit board you will see what the button and spring assembly are (all is is a round piece of foil and the "spring" is a piece of tape using tension to pull the foil up!) Reset the piece of tape so it does not rest on the board and reassemble that headset. Enjoy your HS-850
Posted on Jul 02, 2007
Anonymous
  • 3 Answers
SOURCE: Motorola HS850 Bluetooth headset
no u need to take it to phone manufactuer
Posted on Oct 08, 2007
Anonymous
SOURCE: Broke the ear hook for the Motorola h500 bluetooth headset
The ear hook on my H500 broke as well.  I called Motorola (866-289-6686) and they are mailing me a replacement.  Even though This bluetooth has a 1-year warranty.  I purchased mine in Jan. 2007 and was covered but the rep didn't verify anything regarding the purchase date so even if you're outside of your warranty, you might still give it a shot.
Posted on Oct 10, 2007
Anonymous
SOURCE: Dynex Earclip Headset with Noise-Canceling Microphone driver
ok umm....it is a noise canceling microphone, the earpiece works but when i talk into the microphone no one on the internet can hear me please help me with my dynex earclip headset
Posted on Sep 08, 2008
keekus
Wajid M
  • 83 Answers
SOURCE: USERS ARE SAYING PEOPLE CANNOT HEAR
1. Check the configuration dial on the left hand side of the base to see if another setting works better. The recommended setting for most phones is 1.
2. Make sure your speaking (transmit) level is not too low. First, try increasing the volume on the telephone. Secondly, the master transmit controls are the ABCD switch settings on the bottom of the base. A is the lowest and D is the highest setting. You can fine tune this setting with the Plus (+) and minus (-) buttons on the back of the base that are above and below the picture of the microphone.
3. Double check the battery has a full charge. To check press down on the headset into the base station to ensure it is in the base in the correct position.
The Amber Charge light on the base will flash while charging and will stay solid amber when fully charged.
3 hours = full charge
Posted on Jul 18, 2009
Sin cargador
Creo que el cargador es de mini usb y se puede conseguir en cualquier tienda electronica o de telefonos.
si no es mini usb, el valor del cargador sera mas que el valor de comprar un nuevo headset de bluetooth
Apr 05, 2014 | Samsung Ultra-Slim WEP350 Bluetooth...
Can not hear on bluetooth
did you check the volume?
may placing a call check the volume at that time for the Phone.
Jan 10, 2008 | Motorola Mobility H500 Wireless Headset
New user with Blue Parrot B250XT headset. Using it on Skype and PC with iogear bluetooth dongle, all seems to be properly configured. Tested the audio quality from the microphone and it is garbled. ...
It seems that there is a physical problem with the microphone of that headset, It rarely happens but it does, even brand new units sometimes would have defects.
In windows there is a sound recorder feature that you can use so you can try recording your voice from the headset and check if it will be garbled.
you can also test the device on another equipment, Pair it on a mobile phone that is bluetooth capable and try calling or receive a call and check if the same result would appear.
If the same happens for all these steps, if you have just bought the headset you would want to bring it back and ask for a replacement unit or a refund and get a different model.
Hope this helps!
Aug 24, 2011 | VXI Corporation Blueparrott B250-XT...
We have two headsets in the office Plantronics Supra CS351N - How do I cancel background noise. When the other user is talking my customer can hear it.
The CS351N is a noise canceling headset, one of the better ones at doing that and there is no special button to change that feature. You can try bringing the microphone closer to your mouth and bringing the volume down so the microphone is not as sensitive. You can try moving away from the other user (probably impractical) or ask them to tone down the volume.
Good luck from Headsets Direct!
Apr 01, 2011 | Plantronics Plantronic Supra Monoral Hdset...
When I try to connect my handset WEP350 with my mobile he ask me PINCODE but I don''t remember it? What can I do?
most blue tooth manufactures use a 4 digit pin pairing code they are as follows 0000,1234,1111 or 9999 i hope this helps
Feb 18, 2011 | Samsung Ultra-Slim WEP350 Bluetooth...
My ps3 found my samsung wep350 and says it is connected but when I try to use it while playing, I get nothing. Any suggestions?
did you try: Going to ps3 main menu go to settings tab in the settings tab go to: accessory settings make sure your correct bluetooth is active then go audio device settings (still in accessory settings)
make the output and input to the correct bluetooth device and press ok... try that
Jan 09, 2011 | Samsung Ultra-Slim WEP350 Bluetooth...
Reset wep350
there is a small reset hole on back
Oct 13, 2009 | Samsung Ultra-Slim WEP350 Bluetooth...
Motorola h350 blue tooth headset microphone does not work
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select H350 once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
May 30, 2008 | Motorola Mobility Bluetooth Headset H3...
Microphone
my bluetooth headset has the same problem. it could be the distance between the headset and the phone itself. try bringing the phone nearer the headset, chest-level, maybe. if that doesnt work, you may need another type of headset.
Nov 08, 2007 | Motorola Mobility H500 Wireless Headset
Radio Communications Logo
140 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Marvin
Marvin
Are you a Radio Communication Expert? Answer questions, earn points and help others
