Air Tools & Compressors Logo
Paul Hofle Posted on Apr 27, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Campbell hausfeld fp200201av starts up fine but stalls when i use air and it needs to refill the tank. What should i look for?
Lawrence Oravetz
Level 3:
  • Campbell Hau... Master 10,558 Answers
  • Posted on Apr 27, 2019
Lawrence Oravetz
Level 3:
Answers
10558
Questions
Helped
2700375
Points
29284
Try the start capacitor on the motor and the centrifugal switch inside the end cover of the motor.
1 Related Answer
Anonymous
  • Posted on Feb 01, 2010
SOURCE: Need new pressure regulator for Campbell Hausfeld
Friend had some pressure regulators and one of them fit. It is also a step up from a direct replacement OEM part. Thank you for your responce to my question.
1helpful
Campbell hausfeld wl600701an starts fine when you use it and pressure drops it tryies to star and kemicms breaker I seen are it said it ha a one way chem vlve that will cause thus are is it loated
I think you are asking where is the check valve or one way valve. There is a copper tube that takes the air from the cylinder head of the pump to the tank - the check valve is combined with the fitting that attaches that tube to the tank.Most of it actually stickes inside the tank.
Campbell hausfeld 20 gl 4h.p #VT620400AJ WHY IS THERE OIL N MY TANK COOD I PLZ GET N ANSWER
Please do not yell, and please proofread before posting.
My guess it was on it's side, oil from the crankcase slipped past the rings and the valve into the tank. Other guess is you have way too much oil in the crankcase. Drain it out the tank via the condensate drain. If you want to clean the tank, only use nonflammable cleaners. Look at the brake cleaner row in a car parts store. Remove the drain screw. Spray a lot in the tank. Swish it around, drain. Repeat till what drains out is oil free. Drain and refill the oil in the crankcase to the fill line, or to the required amount per the owners manual.
Campbell hausfeld problems
You have to change out the Seal and it will work fine..
2answers
their web site is chpower.com can order on line if not to old can check warranties also they can direct u to service location in ur area
Gas air compressor shuts down
IS IT BUILDING TO THE UNLOAD PRESSURE AND THEN STALLING OR JUST SHUTTING DOWN ANYTIME. IS THE UNIT SITTING AT AN ANGLE?
DOES IT WORK FINE WITH THE LOW OIL SWITCH UNPLUGGED? UNPLUG SWITCH AND LEAVE IT UNPLUGGED FOREVER.THEY'RE ALL P.O.S.
1helpful
3answers
Campbell Hausfeld compresser throwing breaker
There is a one way valve that only lets air from compressor to tank. If this isn't working the motor is trying to start under the pressure of the tank, and therefore tripping your breaker.
Tank size question
Tank size only becomes a factor for one reason – A larger tank for air. A compressor will run until the pressure in the tank builds to its high-pressure point. Obviously, the bigger the tank, the longer it takes to consume the compressed air. However, the downfall is that once the air is depleted, it takes a lot longer for the air tank to refill with pressurized air. I would only go with the bigger tank if I am concerned about the motor starting and stopping too often, or if I know that I will need a constant flow of air in longer intervals. You have a choice between a larger tank and a constant-run unit.
Top Campbell Hausfeld Air Tools & Compressors Experts
john h
ZJ Limited
ZJ Limited
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
