Question about Samsung Audio Players & Recorders
How to pair a replacement Samsung remote AH59-02758A to Samsung soundbar
Posted by Gordon Collen on
2 Related Answers
Anonymous
SOURCE: I have a new 8 series LED TV + I got the newly
Hi thanks, I got the Samsung customer support desk to assit me and fix the problem.. sorry for the bother -- I thought you were a samsung support site.
Posted on Oct 12, 2009
Deepanshu
  • 13 Answers
SOURCE: can you control the soundbar volume through a samsung tv remote and what type of cable is used to connect the soundbar to the tv
do u have red cable connect it to your tv and then to your settop box or what ever u have
Posted on Apr 26, 2013
No sound from tv. it says 'paired - not connected' How do I connect? Thanks
You have a soundbar?
And the soundbar is paired?
Next... go to your TV remote control ... navigate into settings... and change the sound setting to external device
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Mar 02, 2016 | iHip Audio Players & Recorders
How do i set up a new remote control for a samsung ht ws1 sound bar
2-Function Remote Stopped Controlling my Sound Bar - Verizon Forums
https://forums.verizon.com/t5/Fios...Remote...Sound-Bar/td.../559715
Apr 6, 2013 - It won't even control volume through the TV (Samsung). ... Did theremote ever turn on the sound bar, or have you been controlling ... Does the sound bar or TV have sound (sound but not volume control)? ... NO, UNFORTUNATELY THE FIOS REMOTE NEVER POWERED ON/OFF THE SOUNDBAR - I HAD ...
Your remote reprogramming woes solved - Rogers RedBoard
redboard.rogers.com/.../your-remote-reprogram...
Rogers CommunicationsJun 18, 2014 - Once the TV turns off, press the SETUP button once to lock the code.... the Rogers remote to turn TV on/off but can't get the remote to control volume. ...New Samsung smart TV and I have entered all the proper codes but the ..... Doesanyone have a code for volume control of Samsung Soundbar HW-J250.
Wireless Genie remote Doesn't turn on/off the soundbar - AT&T ..
Jan 08, 2016 | Samsung HT-WS1 Speaker System
Subwoofer not working.
Most likely, the "remote" wire to the subwoofer amplifier has come off or is not making good connection.
May 15, 2015 | JVC TH-BA1 Soundbar System with Wireless...
How do I connect my Sharp HT-SB30 soundbar to Samsung UHD7500 TV
Should be able to use Bluetooth. Need to "pair" the devices (the TV and the soundbar). On soundbar, press On/Standby to power it on, press Input to select Bluetooth (pairing indicator blinks), press & hold pairing button until pairing indicator blinks quickly. Now go to the TV's setup menus: Sound > Speaker Settings > TV Speaker > SoundShare Settings, Add New Device=On, select the Sharp GT-SB30 from device list. If passcode, password, etc is needed, enter 4 zeros (0000). After the devices are paired. the pairing indicator on the soundbar should stop blinking. The pairing information should be retained so you only have to do this one time unless you do a full reset on the TV or soundbar.
Dec 23, 2014 | Samsung Audio Players & Recorders
SOUND BAR IS ON BUT SUBWOFFER DOESNT WANT TO TURN ON RED LIGHT IS ON BLUE LIGHT NOT ON
turn the soundbar off, then press and hold the reset button on the back of the subwoofer until the blue light starts blinking fast. the point the remote at the soundbar and hold the mute button until"ID SET" shows on the display. Then turn on the soundbar and it should find the sub and pair with it.
Sep 12, 2014 | Samsung HWE450 Wireless AirTrack Sound Bar
How to pair my soundbar and wireless lg soundbar
Press and hold the reset button on the back of the subwoofer until the light on the front starts blinking. Then with the soundbar turned on, press the stop button on the soundbar and the mute button on the remote at the same time. The display should say "REMATE". The sub light should stop blinking then and should be linked.
Feb 03, 2013 | LG Lsb316 Sound Bar With Wireless...
Iphone 5 bluetooth wont connect to Samsung HW-E550 soundbar
My Samsung AirTrack soundbar was showing my iPhone 5 and my iPhone 5 was showing the soundbar was available. However, when I tried to connect them I got an error saying the connection was unsuccessful. So what I did was "forget device" and then paired them again. It worked right away. I hope this works!
Nov 09, 2012 | Samsung HW-E550 Crystal Surround Air Track...
I have a new 8 series LED TV + I got the newly released Samsung soundbar HT-BD8200 and connected them both up. I have wireless + DLNA etc and everything was working fine -- till yesterday -- when i used...
Oct 11, 2009 | Samsung Televison & Video
80 people viewed this question
Top Samsung Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
ThaMp3Doctor
ThaMp3Doctor
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
