Hello Wayne, for what you describe you have a mechanical problem, which does not allow the CD holder tray to come out, it is usually the belts, which lose force capacity and do not pull the mechanisms
If you have technical knowledge, I am sending you the link so you can download the service manual, there on page 31, you have the exploded mechanism of the compactera, replace the belts, marked with the number 22 and 19, but go to a specialized technical service
I hope you can solve the problem
Greetings Franco Dosil
Hola Wayne, por lo que describes tienes un problema mec?nico, que no permite que salga la bandeja porta CD, por lo general son las correas, que pierden capacidad de fuerza y no traccionan los mecanismos
Si tienes conocimientos t?cnicos, te estoy enviando el link para que puedas descargar el manual de servicio, ahi en la pagina 31, tienes el despiece del mecanismo de la compactera, reemplaza las correas, marcadas con el numero 22 y 19, sino dirigete a un servicio tecnico especializado
Espero logres resolver el problema
Saludos Franco Dosil
https://www.vintageshifi.com/repertoire-pdf/pdf/telecharge.php?pdf=Kenwood-RXD-353-Service-Manual.pdf
SOURCE: My Xbox won't turn on
Do you have the replacement power cord (from the power cord recall)? If so, this has a built-in circuit breaker, and a button to reset it.
SOURCE: re-attach power source
Okay I fixed my camcorder. I did a ggogle search and came across this solution which worked...I strongly suggest you do this. I whacked it two times on each side with the palm of my hand. IT WORKS NOW! I guess sony is aware of this malfunction and this is probably how they fix it....The error code is gone the tape plays. And it didn't cost me a penny.... Good luck and let me know if it worked for anybody else......
SOURCE: Error Message Reconect Power even if power is connected
It sounds like the tape door is out of alignment, causing stress on the tape and the inside mechanical system. Requires a visit to the service shop.
SOURCE: Kenwood RXD 501
Do you already check the thermal fuse on the primary side of the transformer
SOURCE: CD stuck in disk tray of (original) BOSE 321
NO NEED TO TEAR APART OR REPLACE THE UNIT! JUST TURN OFF THE UNIT, LEAN IT FORWARD AND A LITTLE DOWNWARD AND HIT THE LOAD BUTTON AND IT WILL OPEN. THAT'S THE TRICK!
Si tienes conocimientos t?cnicos, te estoy enviando el link para que puedas descargar el manual de servicio, ah? en la pagina 31, tienes el despiece del mecanismo de la compactera, reemplaza las correas, marcadas con el numero 22 y 19, sino dir?gete a un servicio t?cnico especializado
https://www.vintageshifi.com/repertoire-...
