Question about Frigidaire Dehumidifiers
Frigidaire washer dryer FEX831FS4. Washer worked fine. Put load in the dryer and started another wash. After about 10 minutes, both shut off at the same time. Didn't blow a fuse in the house.
All the other electric units still work in the bathroom where this is plugged in.
Posted by bernadette on
Jim Hicks
    Master:
  • 661 Answers
I don't know. be careful with electricity. if possible, try running normal washer load along with your dryer but with [no heat] 'cold air only' to see if they will keep running.
if they run OK, consider shutting off both washer and dryer. shut off main electrical panel and change fuses for both washer and dryer. turn hydro on and run both again
with your normal settings. if they fail again please call for repairs. my dryer would not run and although everything looked and tested out OK, i had to replace a small 6x8"
electrical box having 2 only 30 amp screw in fuses.
then it ran OK.
Posted on Oct 02, 2019
3 Related Answers
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: EVERYTIME I PLUG IN THE UNIT AND TURN IT ON IT
The compressor has locked up and will not start...this is terminal and will cost more to replace it then the unit is worth...
unfortunately you will have to replace the unit with a new one...
heatman101
Posted on Jun 30, 2011
mike cooper
  • 884 Answers
SOURCE: Does the Fan on a Haier HD456E always run,
I believe the fan is designed to run all the time, and no, it costs very little to run an 18w fan. You can use a timed socket, or switch it on and off when needed. I don't believe the Haier has specific switching times.
Posted on Apr 22, 2012
jasond1991
Jason Defebaugh
  • 4 Answers
SOURCE: blown fuse
Does the unit sound normal? Does it appear to be getting warm? More than likely the compressor is locked up and it is drawing locked rotor amperage which is high and will trip a breaker or blow a fuse.
Posted on Aug 01, 2012
Why does compressor continue running, even with dehumidifier turned off?
So I just had this happen with my Frigidaire fad704dwd dehumidifier. I went to basement and heard it running and sounded off. The compressor was running fan was off which is bad and humidity said 30. I then pushed the off button and it stayed running. I was able to fix it. To make long story short it was a bad ground. I took the plastic back, sides, and front off. There was a green ground (main ground) and Green/yellow ground (fan ground) on the front coil with a bunch of rust. Removed the grounds connected them both together and cleaned the surface area and used a new stainless screw nut and screw to remount the wires to evaporator coil. Everything started working fine after that and I put it back together. Good Luck
Feb 16, 2016 | Frigidaire a/c fad704dwd 70 pint...
I have a Frigidaire dehumidifer model FDL70S1 that wont stay running for more than 3 minutes and then it shuts the fan off, but still has power to the unit.
Hi lynn crisp, thanks for your post!
From my understanding you are having a challenging time with your Frigidaire dehumidifier shutting too quickly. It sounds like a possible problem with your sensor or control panel. Are you currently under warranty? I would contact your manufacturer for assistance to a proper resolution. -Matt
Oct 20, 2014 | Frigidaire Dehumidifiers
Dehumidifier freezes up
Good Afternoon Friend,
I understand your Frigidaire dehumidifier, model# FDF50S, is freezing up. I see that the compressor does not shut off, causing ice to build up on the coils, rather than water draining off. What can cause this is your dehumidifier has been turned on recently. This is normal due to refrigerant rushing through the coil. Frost will usually disappear within 60 minutes. Another cause is if the room temperature is too low or too high. Your appliance is designed to operate between 41 degrees F and 96 degrees F. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 29, 2014 | Frigidaire FDF50S Dehumidifier
I understand that there is no water coming out of your Frigidaire dehumidifier, model# FDF50S1. I also see that the filter is fine and the fan is running. If you have your dehumidifier set up to continuously drain through a garden hose, make sure there are no kinks or clogs in the garden hose. If that does not work, I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Turn the power back on and try any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully.
-Best Regards-
WP
Jun 20, 2014 | Frigidaire Dehumidifiers
Why compressor comes on for a second then shuts off
Good Morning Friend,
I understand that the compressor on your Frigidaire dehumidifier, model# FAD504TDD, comes on for a second and then shuts off. First, make sure that when you are first turning your dehumidifier on that you put it in continuous mode. After about 3 days of continuous mode, set your appliance to the humidity level you would like. Secondly, the "Compressor" circuit has an automatic 3 minute time delayed start if the unit is turned off and on quickly. This prevents overheating of the compressor and possible circuit breaker tripping. Thirdly, make sure the tank is fitted correctly otherwise your dehumidifier will not turn on. Lastly, make sure your dehumidifier has sufficient clearance to operate. There should be a minimum of 12 inches clearance around your dehumidifier. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dehumidifier status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 14, 2014 | Frigidaire FAD504TDD Dehumidifier
Why does blower wheel stop on Frigidaire dehumdifier?
Good Afternoon Desi,
I understand that the blower wheel is not spinning on your Frigidaire dehumidifier, model# FAD504DUD. I also see that the compressor will stay on unless the dehumidifier is unplugged. I suggest you contact the manufacturer for further assistance. They can possibly clarify why the compressor stays on and why the blower fan is not working. If not, they should at least be able to point you in the right direction of having your dehumidifier working. Hope this is helpful.
-Best Regards-
WP
May 30, 2014 | Frigidaire FAD504DUD White Energy Star 50...
50 pint Frigidaire dehumidifier trips a circuit breaker
Those units are essentially air conditioners and they can use a lot of electric current when they start. Make sure it is on its own circuit and the circuit has the correct breaker on it for the load.
Apr 13, 2012 | Dehumidifiers
I have a 2 year old Frigidaire dehumidifier model FDM7051 and this summer when I turned it on it runs continuously with the fan moving normal amounts of air. The air filter and coils are clean and I have...
Don, unless your dehumidifier is a Low temperature model, that very well may be the problem.
The air temp in a basement at floor level is colder than that chest level. Dehumidifiers don't work well at temperatures at 40 degrees F or less. Raising the unit up off the floor on to a sturdy table, counter top, etc, that is strong enough to handle it's weight, plus a full tank of water, will generally solve the problem. The higher up you can safely put it, the better. Also, lower the humidity extraction level to 35%. As 50% is just not low enough in a basement application.
Hope this helps you to solve the problem.
Jul 20, 2011 | Frigidaire Dehumidifiers
I have a Kenmore Dehumidifier Model # 580.53509300 that it runs but it won't pull out any water. What can I do to fix it?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 01, 2010 | Kenmore 54501 Dehumidifier
Dehumidifiers Logo
155 people viewed this question
Top Frigidaire Dehumidifiers Experts
Alan Chouinard
Andrew Taylor
Andrew Taylor
STEVE SPAM REMOVER
Are you a Frigidaire Dehumidifier Expert? Answer questions, earn points and help others
