Question about Home
My seiko musical clock plays music and movement works but the clock doesn't keep time.
Posted by darlene on
5 Related Answers
Anonymous
  • 476 Answers
SOURCE: wont play music
Although the connections are very similar, the iHome is probably only for and iPod, and not compatible with Philips MP3 players.
The only dock I know of that is compatible is the AJ300D
Posted on Feb 08, 2008
Anonymous
SOURCE: My disney mix stick 2.0 doesn,t play music
My sister says there's a hold button that must be slid & this will release your mp3 player from being "frozen" Good luck!
Posted on Mar 28, 2009
mcdevito75
Michael C. De Vito
  • 1970 Answers
SOURCE: I have a seiko musical wall clock that no longer
mcdevito75 here, I'd bring the clock to a small watch repair shop in the area and have them look at it.
Posted on Jun 27, 2010
gemineye61
Janelle Schoonover
  • 842 Answers
SOURCE: I have an old Seiko model #seiko clock ref ej 105G
Thank you for contacting FixYa.
I highly recommend that you send to Seiko and I found you the perfect link with all this info.
http://www.seikoclocks.com/#FAQ
Best regards!!  Jewel
Posted on Sep 03, 2010
watchandpen
Watch and Pen
  • 45 Answers
SOURCE: My seiko musical wall clock
To test your Seiko Melodies in Motion Clock:
1) Check the volume knob in the back of the Seiko clock to make sure the volume has not been adjusted all the way down.
2) Make sure the on / off switch is set to on.
3) If it is extremely dark in the room, the clock will not play, it has a light sensor. Make sure the room is well lit.
4) There are separate batteries usually that operate the clock and the music. Change the batteries paying special attention to any acid / corrosion caused by old batteries. Clean out any acid and it should play. Also, be careful not to touch the positive or negative contacts on the new batteries, as this could inhibit proper connection.
If you have done each step above and it is still not operating, your clock is defective. Contact Seiko Service Center directly at: 800-722-4452 extension 3.
If you have had the clock less than a year, and it was purchased from an authorized dealer, it is under warranty, and any repairs will be free. Otherwise, there may be a charge for the repair.
Posted on Feb 23, 2011
Seiko wall clockNeed battery cover and repairs Model #QXM139SRH
I sent my clock off to Seiko for repair, useless, they said it was in the circuitry. I had them send my clock back. I ordered a new gear box $2.00, replaced that, it will work as long as it's flat. If you look you can see how the clock cycles I made sure it was "locked" in (you can hand force it) then I removed one of the gears so it doesn't cycle down but stays in the up position at all times. Music plays, lights go, just no motion now. Call Seiko for replacement battery cover.
Jun 22, 2014 | Seiko Melodies in Motion Clock
I have a limited edition seiko motion clock with holiday music , is it possible to buy and install a different musical program
Yes.... find another motion clock with music you like, swap out the internals. The programmed music in each movement can not be reflashed.
Nov 29, 2013 | Home
Joyful Crystal Bells Musical Table Clock Faux Wood with
The sensor/sending unit in the clock movement is bad. The movement needs to be replaced.
Nov 26, 2013 | Rhythm Clocks Joyful Crystal Bells Musical...
Motions will not work but time and music does
That just happened to me, check and make sure you have the batteries in correctly for the movement part. They are both supposed to be in the same direction on my clock for the movement and I had the AA batteries in opposite of each other!
Nov 12, 2013 | Seiko Melodies in Motion Clock
My seiko musical wall clock doesn't play music anymore
Feb 23, 2011 | Seiko Melodies in Motion Clock
My clock still keeps time, but no motion nor music? I pushed the reset button and it lights up but nothing happens. What's up?
I have a Seiko musical motion clock that I bought in Japan a few years ago. For setting the time it has a "A" and "B" button that you hold down? I dont have the instructions to set the time. It says "Radio Controlled" but the time was always manually set before by luck trial and error. How do you set the time?
Oct 05, 2010 | Seiko Melodies in Motion Clock
I have an Armitron Musical Quartz watch. Before, the watched "played" but did not keep time. I replaced both batteries and now the watch keeps time but doesn't "play." HELP!
It is likely that you didn't line up the music button with the indent. I needed to push my music button out and gently align th knob with the indent so that the connection was made. Also my watch has a plastic disk that had 2 holes for little metal tabs to stick through so that the watch grounded or something. It took me 5 times of trial and error, but mine works. My watch however plays 2 tunes and is the Taz & Mrs. Taz Armitron.
Jan 03, 2010 | Seiko Melodies in Motion Clock
Home Logo
117 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
