check travel path of the print head. Any obstacles there?
Does the purge station work well?
Is your power outlet fit enough, or did you had some lighting strikes the days before? It could be another indicator for a weak power supply (ac or dc!)
Error 41 refers to the printheads which is a common problem with Brother machines. The printheads will need to be replaced. On some machines, Brother has extended the warranty to cover printheads because of the excessive failure rate. Contact Brother to see if you qualify and they may send you new printheads along with easy instructions to replace them. Also please rate this solution with a fixya rating. Thanks!
!!!! Magenta ink error !!!!
The ink has run out or the ink cartridge is not set into place.
26: Black ink
27: Yellow ink
28: Cyan ink
29: Magenta ink
1. Reload ink cartridges, referring to the Owner's Manual.
2. Ink cartridge PCB defective Replace the ink refill ASSY.
3. Cannot detect ink cartridges.Main PCB defective Replace the main PCB.
I know your machine was not originally showing signs of main board fault or Ink supply issues, although main board can be killed by incorrect use of maintence mode.
I revolved an machine error 50, them i have machine error 36
any help?
thanks
