Question about Hayward Pool & Spa
If(ignition failure) code on hayward 250 pool heater
Make sure gas is on if ok see if ignitor is glowing at cycle
Posted by Danny Montgomery on
5 Related Answers
Anonymous
  • 5 Answers
SOURCE: Error code LO
Is the heater installed indoors?? if so you'll need a vent pressure orifice kit.
if not check your water press. (below 18 PSI on filter) Place filter on "recir" if it fires and stays on . it's the pressure.
check to see if all connections a set tight hi-ltd switch wire harness etc.
Posted on Jun 07, 2009
Anonymous
  • 15 Answers
SOURCE: Hayward H Series 400,000 BTU Pool Heater Won't Ignite
You can not manually light it. Open the front cover look for the gas nozzles brass looking on a tube. on the right side you will see a wire going to a sensor above the next to last burner take the nozzle out for that burner. 7/16 wrench unsrcew the nozzle and see if it is clogged. use something soft to push it out. Spiders love to lay eggs in these. Spray with WD40 and reassemble should work now
Best of luck
Posted on Jun 23, 2009
Anonymous
  • 9 Answers
SOURCE: Hayward 250 heater won't fire up
Check the control circuit, specifically the pressure switch, for continuity with an ohm meter....any reading over 2 ohms needs to be investigated
Posted on Jun 28, 2009
thepool
thepool
  • 78 Answers
SOURCE: Hayward pool heater - p5 code
The code is "PS" for Pressure Switch and means there is insufficient pressure to operate (low flow) or the switch itself is bad.
Posted on Apr 22, 2010
Anonymous
  • 760 Answers
SOURCE: CE error code on hayward pool heater
CE= Communication Error between Control Module
and Display Interface Assembly
1. Disconnect and then reconnect power to heater.
2. Check for faulty wiring or connection.
Inspect Display Interface Wiring. Ensure Display Interface Plug is securely attached to Control Module. .
3. Control Module and/or Display Interface Assembly
are defective.Replace Control Module and/or Display Interface Assembly.
Here is a linkt oH aywardmanuals:
http://www.haywardnet.com/inground/products/manuals.cfm
Posted on Jul 05, 2010
Hayward H400 error code IF (Ignition Failure)
yes, make sure you order the correct part, youll need the model number and serial number. the ignitor has 2 wires wrapped with white fibers, usually 2 screws to remove it, and theres only one way to plug it back in. NOTE: Ignition failure does not always mean the ignitor needs replaced. make sure your ignitor doesnt turn on and glow when you start the heater. if it does, youll want to clean out the gas orifices.
Apr 10, 2014 | Hayward H Series Pool & Spa Heater 400k...
I HAVE PROBLEM WITH HEATER IS SWOING 1F IN THE SCREEN
YOur 1f code is actually a IF code which stands for "ignition failure".
This can be caused by many things, but the most likely is either the ignitor has failed, or the flame sensor has failed.
Make sure the gas manual gas valve is open. Remove from panel so that you can see the ignitor.
Turn off power, then turn back on. After 90 seconds, the ignitor should start to glow red hot. If this is not occuring, then it is likely the ignitor or ignitor wiring.
If the ignitor does glow, then the heater ignites, but still goes off showing the IF code, then it is the flame sensor.
If the ignitor glows, and the heater does not ignite, it is likely the gas valve or ignition control.
As stated above, the ignitor is most likely.
Dec 30, 2010 | Hayward H Series Pool & Spa Heater 400k...
I have problem with the heater is swow in the screen f1
Dec 30, 2010 | Hayward H400fdp Low Nox Propane Swimming...
Code 1F
"IF" or" Ignition failure", simply means you heater didn't fire. Be sure your gas is on,and if on propane be sure there is at least 30% in the tank (and the valve is open).Also check whether your "Glow plug" ignitor Glows, or your spark ignitor sparks (depending on which kind you have).
Oct 22, 2010 | Hayward H Series Pool & Spa Heater 400k...
Hayward pool heater Model CZ 250 will not ignite
if ignitor sparks i'd say its okay, more likely a gas valve problem.are you sure gas supply is on and purged of air?make sure gas valve(the one gas supply threads into) is in the on position
Jun 18, 2009 | Hayward H Series Pool & Spa Heater 400k...
Hayward h100id1 above ground pool heater has ignition failure. ignitor allumeur won't light (less than a year old"
Contact Hayward for a local warranty repair center since it is still under manufacturers warranty. http://www.haywardnet.com/locator/ Be sure to change the reason for search to repair/service.
Jun 08, 2009 | Hayward H Series Pool & Spa Heater 400k...
Pool & Spa Logo
551 people viewed this question
Top Hayward Pool & Spa Experts
john h
Marvin
Marvin
Paul Carew
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
