Question about Home
Smells coming from our low pro 41 pump when using water
We installed the Liberty low pro 41 pumping station in basement...toilet, sink, shower and kitchen sink...Smells of sewage emits from the pump when using shower of kitchen sink
Posted by Michele on
Tom Chichester
    Top Expert:
  • Home Master
  • 55,562 Answers
Incorrect installation. Missing one or more traps.
Posted on Apr 26, 2019
5 Related Answers
Anonymous
  • 63 Answers
SOURCE: water backing up into my basement ejector pump during heavy rain
I have seen this problem several times before. The ejector pump should be in a separate crock in the ground by itself. Someone has installed it in the crock that is meant to pump out drain water. Probably the result of adding a bathroom in the basement. You need to bust another hole in the floor and install a separate crock to solve this problem correctly. If it just started happening go outside and look at he gutters to make sure water is running away from the house and not up against the foundation.
Please rate if this helps-
Posted on Mar 24, 2009
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: My sewage sump pump has
I buy the Liberty pumps from my local HVACPlumbing Supply House. They work very well and hold up well...
Click here
You will want to size it according to head pressure needed and flow...but typically the LE40 or LE50 series will work for what you have there...
There is also a distributor locater there, along with an 800 number to call them directly...
You can also buy direct from an online store like this
heatman101
Posted on Sep 04, 2011
al_kupchella
Al Kupchella
  • 843 Answers
SOURCE: Bathroom sink smells strongly like sewer when water runs fast.
Suppose you plugged the drain of the sink and filled the basin with water, then removed the plug. I must think that only after the basin empties you would get the sewer smell, and the smell would persist until you slowly ran some more water. If you try this, and this is the result, then the problem is that the sewer vent (that is supposed to prevent the water in the trap under the sink from being sucked down the drain) is not working right. If this is a new problem then you may be able to clear what is probably a blocked vent pipe. If this bathroom has always had this problem, then you have a poorly designed or executed vent pipe setup that you can only fix it with some surgery to your plumbing. However, to clean the vent you can try pouring a good bit of drain cleaner down the vent pipe on the roof, followed by water. But because there may be several vent pipes sharing the same vent stack out the roof, the drain cleaner may not get to your blockage and may simply go down a different path. Good luck.
Posted on Oct 16, 2012
Mark Christ
  • 7 Answers
SOURCE: sewage backs into the shower when the toilet is flushed
Since you are in a basement, your plumbing may run into an ejector pit, which is a heavy duty type of sump pump pit that can grind up toilet paper and shoot it up into a main drain pipe at a higher level. That may be why the upstairs doesn't affect your plumbing. Look around for a steel lid, about 20" diameter with two pipes coming out of it (usually 2 inches diameter). See if the circuit breaker is tripped. Sometimes, a light tap on the pipes near the lid can get the pump float to turn on if it gets stuck. Good luck.
Posted on Apr 08, 2013
jabberwoky
  • 739 Answers
SOURCE: Shower in basement is backed up. Wondering if it's because a floor drain is covered up.
sounds more like the drain line is clogged between the shower and the main stack, and shares venting and drain with your kitchen sink. Have a plumber run a drain snake down from your kitchen drain (after the 'P' trap ) to clear the line. A covered over floor drain should have no effect on the back-up.
Posted on Oct 31, 2014
2007 Fleetwood Williamsburg fold down cassette toilet won't work
If you're using water out of the fresh water tank then the toilet gets water from the same water pump the sinks and shower does. If they work OK then there's an internal toilet part that has broken.
Sep 16, 2017 | Cars & Trucks
Liberty Pumps Pro370 Basement Bathroom
At this point, opening the access cover is the last thing you do if it is below the water level in the pipes. Your system has a partial blockage in the pipes between the pump and external septic tanks or sewage dump site, that is the reason why when you use the plunger , half of the amount of waste water comes up to the sink and bathtub. You to open up your pipelines to remove blockage , probably tree roots in the pipes.
Dec 31, 2013 | Liberty Pumps PRO370-Series, P372LE51, 41...
Sewage backs into the shower when the toilet is flushed
Obviously the drain line from your toilet to main drain out of the house ( used by upstairs ) has a blockage from your toilet line to "Y" in to main drain line. Depending on how it has been plumbed, there may be a clean-out between the 2 that can be used to remove the blockage. Your drain for shower is piped in to same line as toilet, thus when blocked at other end, overflows to shower. You can try some drain cleaner down shower drain if it will go. You might get lucky and release the blockage before plumber shows up .
Sep 16, 2012 | Home
3yr old saniflo + started making loud vibrating noise and smells also small black particles come out - husband opened top and looks like a mesh thing has disintegrated. Toilet is at end of sink, bath /...
Unfortunately the systems are desiged to pump out. The disintegrated screen thing is part of the maceration end of the system. Your going to have to clean the thing out and replace the macerator.
Jun 20, 2011 | Saniflo 002/003/005 Saniplus Toilet with...
My saniflo plus is making a humming noise but not draining any water away the sink has filled with water and so has the toilet and shower tray help
My saniflo-plus system is about 12 years old..recently it stopped draining the toilet, etc. I pulled the cover off the pump and checked for blockage and spun the cutter blades...The motor just hums....do I need to replace the entire encased pump assembly?? Help
Jul 07, 2010 | Saniflo 002/005/007 Saniplus Toilet with...
Saniflo Saniplus won't stop pumping
is it pumping against gravity? if so there is a non-return flap in the outlet spigot could be stuck or worn.
Apr 10, 2010 | Saniflo & Saniplus& Macerator Pump
Waste coming up shower trap
Installed in a basement I assume. You do indeed have a clog (before it reaches the maserator).
Aug 31, 2009 | Saniflo & Saniplus& Macerator Pump
Water backing up into my basement ejector pump during heavy rain
Mar 24, 2009 | Zoeller E282 Nonautomatic Waste-Mate
How to Install plumbing in the basement?
A sewer ejector pump is the answer. The waster line is run into the sump basin, pumped through a checkvalve into  the sewer line that grades with gravity.  A vent pipe needs to be run also, (you can't pump out without replacing the air, it's like trying to suck air out of a bottle) If you add a high water alarm, which is a good idea. It is run off of a separate electrical breaker (insurance) to let you know if the pump isn't working before it's flood time.  The check valve makes sure, that what you pump out, stays out. Otherwise the pump will keep cycling.
Aug 27, 2008 | West Brass WestBrass Faucet Master Large...
Home Logo
127 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
