Question about Tomtom RIDER GPS Devices
My tom tom rider cnt find my cardo scala headset even tho it is on, can you solve, thanx
Posted by yahomeboyjam on
Anonymous
I have the tom tom rider 2 its a great bit of kit but i disconnected the scala cardo headset for helmets so that i cold try a different bluetooth headset for use in a car and it didnt work i then tryed to recconect it to my tom tom and it cant find it when searching for it what do i do ? what have i done?
Posted on Sep 12, 2009
My scala rider g4 detects iphone but does not pair
All I did was clear it from the phone and made sure I had a full charge on my scala. Then I just reconnected it. That was it. Once I had made sure I had the full charge that was it.. Done. Hope this helped. Regards, Denise
Jun 09, 2014 | Cardo scala 700LX Bluetooth Headset
Scala rider connects to phone 1 and phone 2 and after 10-15 seconds it shut down
give it back. I also have problems with my Scala rider Q1 system. I would not pay R 200 FOR THIS TYPE OF RECEPTION and i have payed R3000. Bad deal.
Oct 29, 2013 | Scala-Rider Cardo Scala Rider Q1 TeamSet...
My scala rider G4 set has lost hearing in one of the headsets. Where is an authorized rapair shop?
Cardo had a problem in the firmware of the early models that caused the auto adjust on the volume to overload the speakers. Not knowing how old your unit is I have no way of knowing if this is the problem. If you still have the units you can buy new audio bases. I also have a source for replacement batteries.
Aug 26, 2012 | Cardo scala-rider Headset
Headsets won`t pair.
I am having the same problem. Did you ever find the solution?
Jun 02, 2010 | Rider Cardo Scala Q2 Multiset Headset...
My scala rider battery won't hold a charge in standby - typically goes flat in about 8 hours. And I cannot get a reply about it from Cardo
Guys, if you roll out a device that can detect the battery if you own a soldering iron it can be easily replaced by a similar or even greater capacity.
Oct 12, 2009 | Cardo scala-rider Headset
Volume
I had a similar problem when I first connected my Cardo Scala Rider set to the helmet. First off, make sure that the volume on the Zumo is set to 100% for BOTH guidance and mp3 functions. Then click the upper control on the Cado Scala to maximize the volume of the headset. When you've accomplished those two electronic hurdles, adjust the location of the speakers in the helmet - if location of the speakers is not optimized nothing you do with the electronics will have much effect. I typically run the mp3 volume at 20% and the GPS at 50% with the headset volume at halfway. My Cardo Scala unit is a Teamset and I sometimes have problems hearing my rider scream that I'm going too fast. I haven't bothered yet to tell her to keep the microphone closer to her lips.
Aug 07, 2008 | Garmin zumo 550 GPS Receiver
Tomtom RIDER GPS Devices Logo
695 people viewed this question
Top Tomtom GPS Experts
k24674
Marvin
Marvin
Ekse
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
