Question about GE Home Security
How do I sync a GE wireless operated chime, model 1601S and a wireless doorbell which is a Lowe's model #SS-7303-04. The GE chime has 4 small tabs, with tabs 2 and 3 in the UP position. Help!
Posted by Sue long on
4 Related Answers
ohms
monk3ybidzness
  • 1879 Answers
SOURCE: I have Heath/Zenith wireless doorbell.
"sometimes out the blue it will chime"
if for example the doorbell runs on 2.4Ghz signal and then you have a wireless phone which is also on the same frequency, everytime you use the phone the doorbell will ring. got it?
Posted on Sep 08, 2008
Anonymous
SOURCE: door chime code for GE model 1601S &1602S
Hi there. I think I have the same GE chime. It has a series of 4 dip switches on the bell (base) and also in the switch unit. Just make them the same. On mine for example, switch # 1,2 & 4 are up (on) and #3 is down (off). Any combination of 16 codes should work as long as both units are the same. Just as an aside, I had a problem with mine working intermittently, then mostly not at all. It was the actual pushbutton switch inside the button unit. Luckily, I replaced the micro-switch and it's working again. Also during cold wet weather, the 12v battery gets depleted faster than normal probably due to moisture inside the switch unit. I taped a piece of plastic from a sandwich bag over the switch unit to help keep water out.
I hope this helps.....
Posted on Dec 16, 2008
jason
  • 905 Answers
SOURCE: my pushbutton doorbell activates my neighbor's chime
in the chime box and remote you can change the setting for the remote signal that is picked up( refer to your manual for the correct settings) these will be a set of pin connections in the chime box and in the remote switch that will have to be set to another selection
Posted on Dec 29, 2008
Anonymous
  • 111 Answers
SOURCE: Ge wireless Batery Opereted chime 1601s
From what I have researched it is cheaper to purchase another unit. Here's a link I hope this helps.
http://www.smarthome.com/2042/2-Entry-Plug-In-Wireless-Chime-Wireless-Doorbell/p.aspx
Posted on Jul 02, 2009
How do I change the batteries in my Carlon RC8800R doorbell
Do you need to replace the batteries in the chime button or the receiver? To change the batteries on the doorbell (chime button) for most Carlon models, you need a ballpoint pen first to remove the chime button from the back. Press the pen point in the small round hole at the bottom of the button. Then gently push in on the tab. Finally rotate the chime button cover up and away from the back cover. Next take the ballpoint pen or a small screwdriver and place it in the slot below the top battery. Lift the battery up. Repeat this with the second battery. Then place the replacement CR2032 batteries into the battery compartment one at a time with the positive side up.
For the most of the wireless receivers, press the center of the brass tubes and lift those free to replace the 4 D cell batteries (2 behind each tube). A few models have a more obvious battery cover for a set of 4 AA cell batteries.
Many Carlon wireless chime manuals are available here: http://www.lamson-home.com/WirelessChimes.php . The direct link to the manual listed for the RC8800R is http://www.lamson-home.com/ProductSupport/WirelessChimes/RC3304_4300IM_3.06_v2.pdf .
I hope this helps.
Oct 09, 2016 | Carlon Home Security
WIRELESS DOOR BELL BUTTON SL-1695-rx
Heath/Zenith SL-6166-C Wireless Plug-In Door Chime Kit ...
www.amazon.com > ... > Door Chimes & Bells > Kits
Amazon.com, Inc.Heath Zenith SL-6198-B Wireless Doorbell Replacement Battery. Total price: ... Plug-in doorbell chime, doorbell button/transmitter with battery, hardware pack ...
Oct 16, 2015 | Home Security
Id like to change song on my doorbell Dimango model 4330 r cd chime reciever
The webpage http://www.dimango.com/dc-cd-quality-doorbells.htm
shows:
Wireless Doorbell CD Quality Door Chime
Model RC4300
No longer do you need a wired door chime or traditional doorbell with brass tubing to get amazing, rich sound. Our Battery Operated Door Chime from Dimango has CD quality sound while remaining completely wireless...
  • Plays three selectable sounds
    1. Ding Dong
    2. Dong
    3. Westminster Chime Click To Hear Sound!
  • Set sound conveniently at button
It seems that there is a button on the receiver/speaker. Try press once and see if the sound changes.
Nov 27, 2013 | Desa International White Wireless Plug In...
I have a IQ America doorbell with 5 chimes and 5 tunes and the bell only plays a sorta gong which cannot even be heard How do I fix this problem so that it plays a chime/tune?
We had a similar problem with a wired doorbell. There is a diode in the doorbell itself that causes the chime to ring fully. If the diode is backwards, you get just a small tone and can only hear the full chime if you hold the button down. If this sounds like your problem, open up the doorbell at the button end (or have an electrician do it) and reverse the diode.
Nov 07, 2011 | Desa International White Wireless Plug In...
I changed the batteries on my door bell, and it still wont ring
Troubleshooting
Chime does not sound:
• Make sure the doorbell button and the chime codes are the same (See pages
2 and 3).
• Check orientation of doorbell button battery (See page 3).
• Check the doorbell button and chime batteries, replace if necessary.
Batteries seem OK, but the chime does not work when installed:
• Do not mount the chime or doorbell button on metal or near metal studs. This
reduces the transmitter range. Use 1/4" to 1/2" (6 to 13 mm) wood shims to
move the chime or doorbell button off the metal surface.
• Don't mount the chime too close to ground level concrete slabs. This may
also reduce the range. Mount the chime away from the floor.
• Try different locations for the chime closer to the doorbell button. Also try to
orient the chime at a different angle to increase the range.
The range of the doorbell depends on location, temperature and battery
condition.
Regulatory Information
This device complies with Part 15 of the FCC Rules and RSS-210 of Industry
Canada. Operation is subject to the following two conditions: (1) this device may
not cause harmful interference, and (2) this device must accept any interference
received, including interference that may cause undesired operation.
The user is cautioned that changes or modifications not expressly approved by
the party responsible for regulatory compliance could void the user’s authority
to operate the equipment.
Technical Service
Please call 1-800-858-8501 (English speaking only) for assistance
before returning product to store.
If you experience a problem, follow this guide. You may also want to visit our
Web site at: www.hzsupport.com. If the problem persists, call* for assistance
at 1-800-858-8501, 7:30 AM to 4:30 PM CST (M-F). You may also write* to:
HeathCo LLC
P.O. Box 90004, Bowling Green, KY 42102-9004
ATTN: Technical Service
* If contacting Technical Service, please have the following information available:
Model Number, Date of Purchase, and Place of Purchase.
No Service Parts Available for this Product
Jan 02, 2010 | Desa International White Wireless Plug In...
Jul 02, 2009 | Computers & Internet
Door chime code for GE model 1601S &1602S
Nov 22, 2008 | Home Security
Home Security Logo
177 people viewed this question
Top GE Home Security Experts
Sean
Bill
Level 1 Expert
Are you a GE Home Security Expert? Answer questions, earn points and help others
